Old 05-14-2008, 07:56 PM   #5941
katfish317's Avatar
oring #5407
screws #31531
itf top deck #31141
These are the parts needed unless you want to add the washers, you will not need them personally. I do not use any and have had no probems.
katfish317 is offline   Reply With Quote
Old 05-15-2008, 07:36 AM   #5942
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
I use a #4 washer, button head screws and shock o-rings. Add a little lock tight to the screws so they don't back out and forget it.
Kraig is offline   Reply With Quote
Old 05-15-2008, 08:04 AM   #5943
Gain Time's Avatar
Originally Posted by keepitmovin504 View Post
what gear ratio do you use
and what batts.?
-Thanks
I use the Orion Lipos. 3200 and 3600.
I am running 64p 47/96 combination. That is 4.09 FDR but I run the prizms straight out of the box at 60mm so my rollout is different than those running the tires at 58mm. I am on a tight track so my motor comes off the track at 150 to 160 degrees on the can.
I tried a 48/96 combo but the motor came off 172 degrees on the can and about 150 at the end bell.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 05-15-2008, 09:08 AM   #5944
Anybody ever use the Integy set boards?
http://www.integy.com/cgi-bin/webc.c...=3130&p_catid=
Or is there something better out there?
tc5basher is offline   Reply With Quote
Old 05-15-2008, 10:54 AM   #5945
katfish317's Avatar
Yes, I have one and it is very helpful when changing setup.
Old 05-15-2008, 12:54 PM   #5946
Terry M's Avatar
Trader Rating: 24 (100%+)
I have that same exact one. If you're serious about your car being "right" every time you go on the track then this is a must have! Keep in mind if you hit a board hard you will have to recheck your settings to make sure it's not out of line. I use mine before qualifying and then once again before the main.
Terry M is offline   Reply With Quote
Old 05-15-2008, 01:46 PM   #5947
i have an integy setup station that ive only used once for sale for $80 if anyone is interested
DOTMAN is offline   Reply With Quote
Old 05-16-2008, 08:25 PM   #5948
johnny55's Avatar
Send a message via AIM to johnny55
Thumbs up
Wanted to know if anyone is running SMC 5000 batts? Does it fit in the TC5? Thanks.
johnny55 is offline   Reply With Quote
Old 05-16-2008, 08:39 PM   #5949
mo
mo's Avatar
Yes, I am running the SMC 5000 and it fits with room to spare.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 05-16-2008, 09:44 PM   #5950
LOW ET's Avatar
Trader Rating: 94 (100%+)
smc 5000 hardcase fits for me too.
LOW ET is online now   Reply With Quote
Old 05-17-2008, 04:45 PM   #5951
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I have an issue with my car........Ive checked and checked and checked again, but my right rear seems to be toed in more than the left rear, or vise verse if you look at it like that. What could it possibly be?? Both shims are 2mm on the bulkhead, I dont get it?!
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-17-2008, 04:59 PM   #5952
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Are you checking this with a setup station? Did you check to make sure that you don't have different rear hubs on either side of the car?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 05-17-2008, 05:40 PM   #5953
Super Moderator
Kraig's Avatar
You can also check those little clips for toe adjustment. There is a possibility that one is off just a little bit. Otherwise, maybe you bent the aluminum. Remove them and put them on a piece of glass to see if they are.
Old 05-17-2008, 07:14 PM   #5954
PartTime's Avatar
You have to check those little deg clips. They get squished somtimes and that will do it also.
DK
PartTime is offline   Reply With Quote
Old 05-17-2008, 07:18 PM   #5955
K_King's Avatar
Im using 2mm blue washers on there, I put .5 hubs on there so we will see if that helps. I dont have a tweak station yet.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
