Old 05-12-2008, 05:54 AM   #5911
Send a message via MSN to ammo
I'm considering running the TC5, but there's zero parts support at my place.
So just to have an idea, what are the common things that you guys stock up?
ammo is offline   Reply With Quote
Old 05-12-2008, 06:04 AM   #5912
keepitmovin504's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to keepitmovin504
I like to keep some extra caster blocks (you will probably break a few of these), a few steering blocks, rear hubs, and an extra set of suspension arms
AE T5M/B5M/B44.3
TLR SCTE 3.0
keepitmovin504 is offline   Reply With Quote
Old 05-12-2008, 12:11 PM   #5913
If you can find a Hard Wide Bumper such as the CEFX or P-dub it will drastically reduce breakage. Luckily i have yet to break a single part since installing my wide bumper. Things I have broken before getting a wide bumper were few castor blocks mainly, 1 steering block, and 1 suspension arm in about 4 months of racing. I would say this car is fairly durable considering the fact that the TC5 was my first hobby grade RC and I had never raced RC cars before. I raced 2-3 times a week at a small technical track.
naggalowmo is offline   Reply With Quote
Old 05-12-2008, 01:03 PM   #5914
Rick Hohwart's Avatar
You should have a set of axle bearings on hand.
Rick Hohwart is offline   Reply With Quote
Old 05-12-2008, 07:46 PM   #5915
Originally Posted by flatovercrest View Post
Hey guys, the TC5 is almost ready. This is actually the RC car built for Subaru Rally Team USA Factory driver (and DCshoes co-founder) Ken Block.
I need to gear this thing, he will use it mostly for parking lot fun and to keep it on the shelf at his office.
Setup it's:
-Mamba 5700
-Reedy Lipos 5000mha
I have a 20pinion 87spur but I don't think it will be the right combo.
This car needs to be reliable and fast, so a gearing that takes care of both would be ideal. Any suggestions?
Thanks a lot.
I have attached a pic of Ken's real ride.
anyone..?
flatovercrest is offline   Reply With Quote
Old 05-12-2008, 08:54 PM   #5916
Verndog's Avatar
Trader Rating: 16 (100%+)
anyone..?
I'd start a MM5700 around 7.0-8.0 FDR. With the 87T spur that would be from 22-25T pinion. I run a MM7700 at around 9.0 FDR. Most importantly, check temps at 4-5 min range and try to keep around 160 at the end of your run...180 max. You can push 200 with a MM but I'd recommend not to if you want it to last.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-12-2008, 08:57 PM   #5917
factory racer's Avatar
i also have a mamba 5700 kv setup in my tc5......i switched to a 64 pitch spur...im using a 114 tooth right now i think....how do i calculate my final drive ratio??? why do u suggest a 7.0 - 8.0 final drive....what does that mean and how do u calculate it??
thanks
Mike
factory racer is offline   Reply With Quote
Old 05-12-2008, 09:03 PM   #5918
Verndog's Avatar
thanks
Mike
Tell me your pinion size and I'll show you where you are running and how to calculate it.
---Team Hoarders---
Old 05-12-2008, 09:06 PM   #5919
umm i think i have a 35 pinion on it right now...havent ran it at a track yet just to test it out and stuff....
Old 05-12-2008, 09:10 PM   #5920
Verndog's Avatar
Then your not far from what I've recommended.
Spur / Pinion x 2.0 (TC5 drive ratio) = FDR
Your at
114/35 x 2.0 = 6.514 FDR
You may get away with that depending on how you drive and drag brake settings ect (more drag = more heat). Watch temps like posted above and go from there.
---Team Hoarders---
Old 05-12-2008, 09:11 PM   #5921
Thanks Verndog. Always great info!
Old 05-12-2008, 09:20 PM   #5922
hey verndog...thanks for all ur help.......couple more questions since u no a lot about the tc5.....does the normal tc5 come with the soft or hard plastic components.....is the tc5r for outdoor rubber come with the soft or hard...will it be a noticable difference between the two...if i run outdoor ashphalt rubber witht he hard???
thanks in advance
Mike
Old 05-12-2008, 09:37 PM   #5923
Verndog's Avatar
thanks in advance
Mike
Stock TC5 comes with the standard (softer) arms right now. I would think they'd put the hard arms with the stock kit , and soft with the new R for grip, but haven't read which they are doing. The stock chassis does real well on asphalt too, and doesn't suffer near the tweak issues from what I've read. The softer arms give you more traction while you loose a small amount of "predictability". I'd personally recommend the stock kit, with ITF top deck mounted with 4 rear orings to dampen it a bit.
I'd like to see what some of the factory guys would recommend in that situation.
---Team Hoarders---
Old 05-13-2008, 07:32 AM   #5924
thanks in advance
Mike
The current TC5 comes with the soft/standard suspension components. The TC5R will continue to come with these parts. The TC5F will come with the hard parts.
I think you can run the hard parts on asphalt with no problems. And they may be an advantage of very high grip asphalt tracks. The caster block seems to gain the most rigidity (relative to t he other parts) in the hard plastic compared to the soft. So if you are going to run the hard plastic outdoors, going to the a stadnard caster block will be a turing option you should have with you.
Old 05-13-2008, 02:11 PM   #5925
PartTime's Avatar
Ok, here are some pics. Finally got a chance to put photo shop back in.
Let me know if you see somthing.
DK
Team Associated TC5-tc5-4.jpg   Team Associated TC5-tc5-3.jpg   Team Associated TC5-tc5-2.jpg   Team Associated TC5-tc5-1.jpg
PartTime is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
