Old 05-10-2008, 10:40 PM   #5896
Hey guys, the TC5 is almost ready. This is actually the RC car built for Subaru Rally Team USA Factory driver (and DCshoes co-founder) Ken Block.
I need to gear this thing, he will use it mostly for parking lot fun and to keep it on the shelf at his office.
Setup it's:
-Mamba 5700
-Reedy Lipos 5000mha
I have a 20pinion 87spur but I don't think it will be the right combo.
This car needs to be reliable and fast, so a gearing that takes care of both would be ideal. Any suggestions?
Thanks a lot.
I have attached a pic of Ken's real ride.
Team Associated TC5-kb_tc5-004.jpg   Team Associated TC5-tc5_ch-003small.jpg   Team Associated TC5-day1_lg2_7370.jpeg   Team Associated TC5-kb_tc5-006.jpg
flatovercrest is offline   Reply With Quote
Old 05-10-2008, 11:00 PM   #5897
sonic31's Avatar
belt tension in front is 7 using mid-low position and rear is 3 in mid-low position ... it feels ok
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 05-11-2008, 06:16 AM   #5898
PartTime's Avatar
Originally Posted by K_King View Post
What belt tension do you guys run?
Mid low or mid high gives the best drive shaft angles. Full loose on the belt tention. 1 frt 8 bck.
dk
PartTime is offline   Reply With Quote
Old 05-11-2008, 06:46 AM   #5899
mac853's Avatar
As i know the US cars springs are always stiffer than JP cars.
Could somebody tell me if tc5 springs are really in this case(ex:harder than the Atsushi Hara's ver.1 series hard, medium and soft).
If i want to use the another brand springs, then AHRP ones could fit on tc5's shocks?
mac853 is offline   Reply With Quote
Old 05-11-2008, 11:47 AM   #5900
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
dk
Ok so nobody is running 10 F and 7 R like Cav?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-11-2008, 11:51 AM   #5901
K_King's Avatar
Originally Posted by BIG DADDY8 View Post
what's the best way to make a spool? I bought 2 aluminum diffs and i have the original plastic one's in the box. I want to convert one of the plastic one's to a "spool' .
Technically you could drill holes in the plastic through the diff ball area in the gear, and then secure it.
Old 05-11-2008, 12:22 PM   #5902
To build a spool just take the diff balls out and glue some sandpaper to the diff rings. Works great.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 05-11-2008, 01:52 PM   #5903
J_P
J_P's Avatar
For $17, buy one. It's that easy.
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 05-11-2008, 02:21 PM   #5904
A bunch of us with TA05's put these where this diff balls go and it worked great (actually a little better then a spool b/c in a crash it would allow the wheels to go backwards slightly).
http://www3.towerhobbies.com/cgi-bin...&I=LXJK92&P=ML
I dont remember the size of the diff balls in the TC5 but they might work.
or8ital is offline   Reply With Quote
Old 05-11-2008, 02:30 PM   #5905
robk's Avatar
Trader Rating: 22 (100%+)
If what i have seen has not changed, the spool conversion will be 2 rings of a white plastic material that will go in place of the diff rings. Neat, and you should have better drivetrain life than the solid spool.
Old 05-11-2008, 02:32 PM   #5906
PartTime's Avatar
Any info on where to get one at that price would be cool.
DK
Old 05-11-2008, 06:16 PM   #5907
tomkelley's Avatar
Could someone help me put together a actual parts list to make a tc5r?
(I'm surprised AE hasn't done so already)
-Going from TC5 (original release) to TC5R
-Going From TC5F to TC5R
If I'm not mistaken, all that is required are ITF chassis and ITF top plate, and
spool option. Is that correct? What about the 'hard' (meant for foam) & 'soft' (meant for rubber) suspension components? Didn't the original TC5 come with the 'soft' suspension components even though it was released as a foam tire car?
Chassis components:
For converting from TC5 to TC5R
31140 TC5 FT ITF Chassis
31141 TC5 FT ITF Top Deck
31179 TC5 FT Spool Kit
Soft suspension components (only for for converting from TC5F to TC5R, I think the original TC5 suspension is the 'soft' set)
31205 TC5 Front Suspension Arm
31206 TC5 Rear Suspension Arm
31210 TC5 Caster Block, 0
31211 TC5 Caster Block, 2
31212 TC5 Caster Block, 4
31215 TC5 Steering Block Set
31218 TC5 Rear Hub, 0
31219 TC5 Rear Hub, .5
31220 TC5 Rear Hub, 1
Not sure, but which caster block and rear hub is standard with the TC5R (or all)?
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 05-11-2008, 06:18 PM   #5908
Trader Rating: 24 (96%+)
you'll also need to get the aluminum outdrives for either conversion. Those are upgrades in both new kits compared to the original tc5 kit
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
http://www.kolorsbykropy.net
nemix is offline   Reply With Quote
Old 05-11-2008, 06:19 PM   #5909
hopefully those white plastic pieces will get their own part number for spares and such
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
Old 05-11-2008, 06:55 PM   #5910
robk's Avatar
Chassis components:
Most rubber setups are the 4* caster block and 0* toe block. Foam is more like .5* or 1* toe blocks, 6* caster.
You may want to try hard caster blocks, it may give a different steering feel, even with soft arms.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
