Old 05-08-2008, 05:45 PM   #5866
mr crum's Avatar
Send a message via Yahoo to mr crum
Default CA ING UR CHASSIS
CUT A VERY VERY SMALL TIP IN THE NOZZLE AND USE A LITTLE THICKER GLUE TAKE UR TIME GO SLW
mr crum is offline   Reply With Quote
Old 05-08-2008, 05:46 PM   #5867
PartTime's Avatar
Kraig..I see Bando on the belt but cant read the rest. Yes I have compaired both the diff and 1-way.. There the same. I have to put photo shop back in and shrink but I just took a couple of pics. Will post soon.
K. King...I just throw new bulk ($1) bearings in the axle's when they start to go away. get a little oil in them and they spin great.
Mr Crum.... thanks but I dont like the shafts on that hard of an angle. The straiter the better for me.
zake540... thats a good idea ! I might have to try that.
K. King.... Here is a setup thats pretty close to what Im running on cement. I gotta believe ashfalt would only be a tire change away.http://www.petitrc.com/reglages/asso...by20080309.pdf
The car rotates hard in the corners but its very balanced, witch makes it easyer to handle. put some d/r in the radio to smooth it out.
D. King
PartTime is offline   Reply With Quote
Old 05-08-2008, 05:47 PM   #5868
thanks, and found the proper thread too
Tips for chassis sanding
protocol_droid is offline   Reply With Quote
Old 05-08-2008, 09:18 PM   #5869
factory racer's Avatar
when will our lhs's be able to order in the new tc5 R spec chassis?? i called and they cant get them from the distributors yet?? does anyone no how long they will take???
thanks
factory racer is offline   Reply With Quote
Old 05-09-2008, 03:27 AM   #5870
mr crum's Avatar
Default ihs
wat is ihs plz explain dont know wat it is but curious 2 know
Old 05-09-2008, 03:51 AM   #5871
keepitmovin504's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to keepitmovin504
lhs= local hobby shop
AE T5M/B5M/B44.3
TLR SCTE 3.0
keepitmovin504 is offline   Reply With Quote
Old 05-09-2008, 11:45 AM   #5872
AE-Reedy
AE has made a new set of adjusters for the belt tension that has extra slots for more adjustment. Part # 31184 they are available now.
Sean Cochran is offline   Reply With Quote
Old 05-09-2008, 12:03 PM   #5873
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
thanks
There is no new spec chassis, its just the ITF chassis and deck thats been out for awhile.
The TC5R is just a combination of parts that have been out for awhile combined into a kit to make it easier.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 05-09-2008, 12:20 PM   #5874
Trader Rating: 19 (100%+)
Dagg! I just bought a yokomo bd belt from ebay
But way to go AE for being on top of customers demands and wants.
zake540 is offline   Reply With Quote
Old 05-09-2008, 09:37 PM   #5875
So what are the doing to turn the front diff into a spool with the new cars? Sandpaper on the diff rings?
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 05-09-2008, 09:45 PM   #5876
mo
mo's Avatar
AE #31179 Spool kit
http://aedownloads.com/downloads/item_photos/31179.jpg
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 05-09-2008, 09:46 PM   #5877
the tc5R already comes with the front spool
AE T5M/B5M/B44.3
TLR SCTE 3.0
Old 05-10-2008, 05:34 AM   #5878
PartTime's Avatar
Awsome !!! I will check into it. Thanks.
DK
Old 05-10-2008, 06:40 AM   #5879
From what i read it is not the spool. It says the diff can be converted to a spool.
FT B44 - FT J82
Old 05-10-2008, 08:16 AM   #5880
oh i just read it from redrc were it said
Factory Team TC5R features
- Belt drive with adjustable differential heights and belt tension
- Blue aluminum outdrives
- Hardened steel CVAs with cross-pin retaining clips
- Blue aluminum clamping wheel hexes
- 20 Precision ball-bearings
- Blue aluminum bulkheads and motor-mount
- Woven carbon fiber battery strap included
- ITF 2mm woven carbon fiber chassis and top plate
- Front & rear anti-roll bars included
- VCS2 shock package
- Titanium turnbuckles
- Genuine Kimbrough 48 pitch spur-gear included
- 3mm inner hinge-pins and 2.5mm outer hinge pins
- Adjustable roll-centers hinge-pin angle
- Vertical ball studs
- 3mm woven carbon fiber shock towers
- Mono-bellcrank steering with adjustable servo-saver
- Indexed balancing holes in shock towers
- Spool option included
AE T5M/B5M/B44.3
TLR SCTE 3.0
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
