Old 05-05-2008, 02:18 PM   #5836
losithrasher's Avatar
what gearing setup are you guys using that will actually fit to get 3.5fdr with a 17.5?
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 05-05-2008, 03:45 PM   #5837
RcRacing4Ever's Avatar
Questions?? a tc5R ?
i went racing on sunday & my A.E guru said he was on the net & was getting ready to buy a TC5,then he disovered or read that a TC5R in sopose to come out...this is hear say? He said that its sopose to be the out door edition...front spool, aluminume rear diff, ITF chassis & top deck. Is this rumor true? And i run a 13.5 with the stock 72 spur & a 31 pinion(4.65) which keeps me in the A main. I had to dremel the motor plate to make work.
RcRacing4Ever is offline   Reply With Quote
Old 05-05-2008, 03:49 PM   #5838
LOW ET's Avatar
Trader Rating: 95 (100%+)
it's true. look here http://www.teamassociated.com/
LOW ET is offline   Reply With Quote
Old 05-05-2008, 04:08 PM   #5839
overflow's Avatar
you had to dremel the mount holes? i can fit a 72/35 in with no problem. thats weird...
Dennis Vice
[HOTBODIES] [SPEED PASSION]
overflow is offline   Reply With Quote
Old 05-05-2008, 04:29 PM   #5840
kdub's Avatar
AE # 89229 blue countersunk washer
kdub is offline   Reply With Quote
Old 05-05-2008, 06:06 PM   #5841
#88driver's Avatar
i am thinking of going to an associated tc5 and i was wondering how hard it is to build a kit and how hard is it to repair?
Colton Jaynes
*RC America*Hudy*Xray*Jaco*KO Propo*SMC*EA Motorsports*
rchobbiesstore.com
#88driver is offline   Reply With Quote
Old 05-05-2008, 06:15 PM   #5842
Trader Rating: 68 (100%+)
#88 driver you got pm
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 05-06-2008, 08:28 AM   #5843
Suspended
ran the promatch sw onraod touring car this weekend in scottsdale..in 17.5 class..are you ready for the gearing...64 pitch of course...96 spur gear with anywhere from 49 to 52 tooth pinion...had to use prs gears...that puts final drive from 3.9 to 3.5....rubber tire...crazy but they fit without no modifications...just have to find big pinions like that...12th scale stuff....good luck
i am cornholio is offline   Reply With Quote
Old 05-06-2008, 09:51 AM   #5844
geeunit1014's Avatar
90/53 is a 3.5 if im not mistaken with plenty of room for bigger pinions
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 05-06-2008, 12:29 PM   #5845
HB Moose's Avatar
For those trying to get low FDR with 48 pitch gearing. I have found spurs down to 66 teeth and pinions up to 41 teeth. That would get you to 3.22 FDR. Just need to look at suppliers besides the big boys.
For those looking for the countersunk washers to hold the o-rings on the top deck. Why not use a button head screw and a normal washer? Oh I forgot, it needs to be blue.
HB Moose is offline   Reply With Quote
Old 05-06-2008, 12:51 PM   #5846
Maybell's Avatar
Building is not too difficult. There are a few tools I would recommend that would make life easier. The TC5 is VERY easy to work on and repair so that wont be a problem. When building the kit, just take great care in the placement and orientation(cant spell) of everything and take your time.
Minimum tool list:
-Allen Drivers, 2mm, 2mm ball end, 1.5mm
-Needle Nose pliers and side cutters
-hobby knife
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 05-06-2008, 02:01 PM   #5847
PartTime's Avatar
Hi guys.
I tore my tc5 apart the other day, it was nasty and I got it used and needed it anyway. Well, when I was putting it back together I noticed a major flaw !! when I got to the front belt I couldnt believe how tight it was. thinking I had the adjusters on backwards I tried that. Hahaha, I could have played a song on it. Guitar string tight!!
Was there a problem with belts in early kits or somthing? Or is this just the way it is? Is there a replacement belt for it or maybe a yok belt or somthing?
thanks
dk
PartTime is offline   Reply With Quote
Old 05-06-2008, 02:21 PM   #5848
Maybell's Avatar
Originally Posted by PartTime View Post
Hi guys.
thanks
dk
The belt is fine. Start with belt tension #8 or 16 shown on the setup sheet. The belt wont be too tight if installed correctly...Also, check your pulleys for junk buildup because that could cause a tight belt...
Old 05-06-2008, 05:24 PM   #5849
PartTime's Avatar
A belts not that hard to install so not sure what you meant by that.
Yes I cleanded out the pulleys along with the hinge pins, bearings and any thing else I can think of. Sorry, thought I mention I cleaned the car.
The losest(sp?) I could get it was diff full up and lose. That is where I think I would like the belt tention but, dont like the dog bones on that angle.
Also....whats the trick to get the pulley for the one way centered? I took some shim stock and slide it inbetween the unit and pulley to help line it up. way better but still not good. The belt may losen up when i get that centered but, even when its at its losest now its not right.
DK
Old 05-06-2008, 06:05 PM   #5850
Maybell's Avatar
DK
Thats the thing with message boards, its easy to take something wrong in words...just trying to help...
I have to assume that something is built incorrectly because I have helped many with this problem and they were all built wrong... recheck the cams if they are in the 8 or 16 spot then the belt is not too tight...a couple times the guy thought it was too tight because they are used to TCs that have smaller pulleys and softer belts...that can fool you into thinking they are too tight...
one-way: mine fits perfectly with one stock shim on each side...maybe you have placed the gear on the wrong side of the oneway...also, make sure you dont overtighten the oneway screws to prevent warping...use a LITTLE blue threadlock on them...
good luck man
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
