Old 04-29-2008, 12:21 PM   #5776
katfish317's Avatar
Hello guys,
I'm from Brazil, and I'm running a TC5 with a Mamba 5700.
I tried to find over the posts but there are so many that I decided to post it.
Changing the caster blocks what kind of change will I have on the car.
Adding caster to the front will help if they front end needs more grip, but too much you give up acceleration and breaking potential. Also it helps with the steering to self center after taking a curve. Also the more caster you add you will also add to the camber angle when turning, So it has it's good and bad points. I personally only run at 4 degrees right now since I am running on outdoor tracks that are asphalt or cement pads. Experiment till it feels right with your setup.
katfish317 is offline   Reply With Quote
Old 04-29-2008, 12:40 PM   #5777
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Originally Posted by rezenclowd3 View Post
There ARE limits as far as being able to mesh the pinion and spur. IE I need a 9.5-7.8 FDR for my LRP 4.5. (just starting out, then Ill find the appropriate FDR for the track) I tried 96 spur and 23 pinion to start out as it is a larger track. That would be an 8.35 FDR. That FDR does not work in the TC5, but it does work for a Novak 13.5 using 96 spur and 42 pinion: 4.57 FDR which is perfect for my track.
For the LRP 4.5 I ended up using a 116 spur and 26 pinion for a FDR of 8.92.
BTW I am using 64 pitch gears. There are many ways to use the same FDR, so you should find a combo that works. I do wish the TC5 motor mount had the motor mount holes milled closer to the spur, so that there was a wider mesh range.
thanks but my bro isnt running brushed OR 64pitch. What i want to know is whats the smallest and largest pinions that correctly meshable using a 72 spur and a 78 spur, respectively. I can figure out FDRs and all that other stuff myself, thats just calculations.
so, if i can get any help figuring out whats the biggest and smallest pinions that the tc5 can use with both 72 and 78 spurs, that would be best. Thanks.
Syber Serulean is offline   Reply With Quote
Old 04-29-2008, 06:28 PM   #5778
RAT-BOI's Avatar
hey guys just out of curiosity how mny of you guys r usinf the standard shock i am using them with no problem but the r alot of guys in australia use tamiya trf shocks on there car as the standard once leak but i have had no problem with shocks leaking.
cheers
m.stone
TEAM ASSOCIATED FT TC5
SPEED PASSION
MUCH MORE
ATLAS BATTERIES
TWISTER HOBBIES
RAT-BOI is offline   Reply With Quote
Old 04-29-2008, 07:13 PM   #5779
katfish317's Avatar
I am still using the standard shocks, but I do have to check them every once in a while as there is a little leakage once is a while. I just top them off and go from there, nothing unusual to me.
Old 04-30-2008, 04:36 AM   #5780
getpip's Avatar
yep they do seem to be a bit leaky .. seem to have got on top of it now .. use shock slime when you build them..... someone suggested ptfe tape around the cap and make sure u tighten the cap right down.
getpip is offline   Reply With Quote
Old 04-30-2008, 06:16 AM   #5781
M,Stone's Avatar
Send a message via MSN to M,Stone
i found if you didnt get them foam pieces in perfect the leaked a little but nothing over the top compared to most other shocks my mate has had a problem of the o ring giving out but i think it may be just a one of thing.
m.stone
TEAM ASSOCIATED/KM GROUP/ORION/REEDY/SAVOX/HOT RACE
ACE HOBBY DISTRIBUTORS
M,Stone is offline   Reply With Quote
Old 04-30-2008, 09:40 AM   #5782
bigl's Avatar
Trader Rating: 24 (100%+)
anyone know what size bearing is used in the hubs is it 6x10x3 or 6x10x4 i remember reading somewhere in this forum that there was a misprint in the instructions but i cant find the post
bigl is offline   Reply With Quote
Old 04-30-2008, 10:11 AM   #5783
Verndog's Avatar
Trader Rating: 16 (100%+)
Manual says 6x10x4....but you need 6x10x3.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 04-30-2008, 10:46 AM   #5784
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Originally Posted by Kraig View Post
Rick posted this on the Reedy thread.
The rubber car comes with swaybars, standard suspension components, and the top deck o-ring modification. Plus springs that are typically run with rubber tires.
The foam cars comes with hard suspension parts, no swaybars, and foam specific springs.
Both cars some with diffs front/rear but each kit is equipped with parts to turn the diff into a spool.
Here is from the press release.
Factory Team TC5F Features:
- Belt drive with adjustable differential heights and belt ension
- Blue aluminum outdrives
- Hardened steel CVAs with cross-pin retaining clips
- Blue aluminum clamping wheel hexes
- 20 Precision ball-bearings
- Blue aluminum bulkheads and motor-mount
- Woven carbon fiber battery strap included
- Rigid 2.5mm woven carbon fiber chassis and top plate
- “Hard” suspension rears, 6° caster blocks and 1° rear hubs
- Front & rear anti-roll bars included
- VCS2 shock package
- Titanium turnbuckles
- Genuine Kimbrough 48 pitch spur-gear included
- 3mm inner hinge-pins and 2.5mm outer hinge pins
- Adjustable roll-centers hinge-pin angle
- Vertical ball studs
- 3mm woven carbon fiber shock towers
- Mono-bellcrank steering with adjustable servo-saver
- Indexed balancing holes
Factory Team TC5R features
- Belt drive with adjustable differential heights and belt tension
- ITF 2mm woven carbon fiber chassis and top plate
- Indexed balancing holes in shock towers
- Spool option included
As you can see lots of duplication of items but in different thickness and component compounds (hard suspension pieces to soft pieces).
Does anyone have a link to the top plate o ring modification?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 04-30-2008, 01:21 PM   #5785
so im assuming nobody knows?
Old 04-30-2008, 02:45 PM   #5786
robk's Avatar
Trader Rating: 22 (100%+)
It's gonna be a pretty giant pinion. The smalllest you can get on an 88 is like a 50 or 51.
Old 04-30-2008, 02:49 PM   #5787
robk's Avatar
Get 4 o rings. Remove the 4 screws that hold down the layshaft/spur part of the top deck-the 4 rearmost screws. get 4 button head screws, and 4 washers. Put on a washer and then an o ring on each screw. Replace the flat head screws with the 4 button heads and washers. Tighten enough to start compressing the o rings, but don't squash them.
Old 04-30-2008, 03:08 PM   #5788
Sean Powers's Avatar
the problem that i found with the shocks leaking was the shock bladders, i bought some from GS and didnt have any problems after that. I read some where that HPI bladders work with the AE shocks too, hope this helps.
Sean
Sean Powers is offline   Reply With Quote
Old 04-30-2008, 08:10 PM   #5789
katfish317's Avatar
Here is a pic of the o-ring setup!
Old 04-30-2008, 10:15 PM   #5790
what gearing are you looking for ??? ..
Mark Barden .
mb racer is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
