Old 04-23-2008, 02:36 PM   #5746
Default TC5 Foam tires
Hey,
I will be running (or trying to run at least) at SV raceway.
What foams you all using out there?
tc5basher is offline   Reply With Quote
Old 04-26-2008, 05:33 PM   #5747
Have you guys seen this, i have not been around much lately so i might have missed it.
http://www.redrc.net/2008/04/team-as...c5r/#more-9027
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 04-26-2008, 06:28 PM   #5748
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Nope those are new. It now gives the customer a choice to buy a full blown foam kit or a full blown rubber tire kit.
I want to see aluminum CVAs instead of steel.
Kraig is offline   Reply With Quote
Old 04-26-2008, 06:49 PM   #5749
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Very cool. One of the criticisms of Associated was that you had to buy extra stuff for runner tire racing. Good move on there part!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 04-26-2008, 09:53 PM   #5750
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Originally Posted by tc5basher View Post
Hey,
It is probably best to ask on their forum. My guess is there is a VERY limited number of electric kits out there as it is a nitro onroad track. Big enough that even 8th scales top out on it! You will probably have to do your own testing to find out what works best. Good luck, and hopefully I will run into you some time out there. I plan on bringing my TC5 with me when I run offroad at SV in the near future.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 04-27-2008, 05:41 AM   #5751
getpip's Avatar
Default Inboard or outboard toe?
Hi
Can someone please tell me the benefits or drawbacks of inboard and outboard toe?
Im really trying hard to sort out this badly handling car I have just built
PIP
getpip is offline   Reply With Quote
Old 04-27-2008, 06:43 AM   #5752
PartTime's Avatar
Originally Posted by getpip View Post
Hi
PIP
What is the car doing that makes you think it handles poorly? I know when I got mine it took a few days at the track to figure out how to make it turn. Im sure we can help.
Rear toe will make the rear stable. Front toe in will help coming out of the corner and toe out will help with going into the corner.
DK
PartTime is offline   Reply With Quote
Old 04-27-2008, 01:50 PM   #5753
getpip's Avatar
thanks
Yes i know about toe theory ...
On the TC5 rear toe can be adjusted at the hinge pin (inboard) or at the hub (outboard)
My question is .. what are the benefits of adjusting it either in board or out board?
Pip
Old 04-27-2008, 01:55 PM   #5754
losithrasher's Avatar
when does the tc5r and tc5f come out?
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 04-27-2008, 02:35 PM   #5755
Trader Rating: 24 (96%+)
shouldn't be long. Every part they are putting in these kits are already parts that have been in production, they are just 'bundling' them in a kit differently.
Tower has the sku on their website already, but price is still the 550 msrp. Means they dont have a date, or an invoice price yet for them.
I'd be very surprised if you couldn't pick one of these up before the end of may.
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
http://www.kolorsbykropy.net
nemix is offline   Reply With Quote
Old 04-27-2008, 02:39 PM   #5756
thanks
Pip
Someone correct me if I'm wrong...
Outboard toe will soften up you rear suspension compared to using only inboard toe. This is due to the angle of the arms in relation to the shocks. Inboard toe causes more friction on the shock shaft making it feel stiffer. When using outboard toe the arms are straighter and the shocks are at less of an angle which causes less friction making it feel softer.
Old 04-27-2008, 04:24 PM   #5757
factory racer's Avatar
can someone tell me the differiences between the new tc5r and the original
tc5???? i saw that someone posted that the tc5r was for rubber and the tc5 was for foam?? i was plannin on running the reg tc5 foam, and i already bought it and built it, what do i have to do do make it a rubber tire car??? if i have to do anything??
im sorry im new to electric
thanks
factory racer is offline   Reply With Quote
Old 04-27-2008, 04:28 PM   #5758
thanks
Well a lot of rubber tire drivers use the ITF chassis and one-way or spool. For the most part that is what the TC5R includes along with softer springs. If you want to convert what you have you can buy those options. But many just use softer springs with the original chassis and it works OK.
Old 04-27-2008, 05:03 PM   #5759
robk's Avatar
Trader Rating: 22 (100%+)
thanks
Pip
Toe at the hub tends to make the car more aggressive. Toe at the hinge pin is more mellow. I think the straighter arms lets the weight dump onto the nose easier with hub toe. Foam tends to be more toe at the hub, and rubber at the hinge pin, but you may want to fool with this to your taste.
Old 04-27-2008, 05:16 PM   #5760
Hi Guys, almost finished assembly of my TC5.
I was wondering, anything wrong in installing the radio received on top of the servo?
My ESC is a Mamba and I'd like to leave room on the chassis to plug the USB port for the software..I'm thinking of installing the radio receiver on top of the Servo and the ESC on the chassis..
Thanks,
Alex
flatovercrest is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
