Old 04-15-2008, 11:24 AM   #5716
stanislow's Avatar
Send a message via MSN to stanislow
are you sure? since the diffs are raised it should heighten CG and cause less traction whereas if the diffs are low it wont roll as much thus causing more rear traction?
anyone please step in if im wrong, thats just my understanding
Speedpassion, Team Trinity, AVID bearings, Titanium Racing
Eastridge Hobbies
RC Canwest Xray Jaco SMC
Mad Scientist Motors
stanislow is offline   Reply With Quote
Old 04-15-2008, 11:46 AM   #5717
geeunit1014's Avatar
when the weight is higher it causes more roll and more traction thats why we raise roll centers on ashplat to creat more bite, and lower them on carpet where there is tons of bite
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-15-2008, 01:29 PM   #5718
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by PartTime View Post
you really running the car that soft? I am running 50wt in front. I think it might be better with 40 but anything below that seems way to fast. I will get to oil on this car one of these days.
DK
It's not so much the oil, as #57 pistons are small, kinda between #2 and #3. i want to try a larger hole piston, as this was good in high bite, but I'm not sure about the local track...
Old 04-15-2008, 01:34 PM   #5719
stanislow's Avatar
well, now i know what to do for asphalt since we start this weekend, what else needs to be done to convert a foam car into an asphalt
Eastridge Hobbies
Old 04-15-2008, 02:33 PM   #5720
Ok, show me the light please
cochecito is offline   Reply With Quote
Old 04-15-2008, 04:02 PM   #5721
build the car to make as much grip as possible - ie high roll centers, soft springs/shocks, no sway bars, etc, then tune the car to the track and what it needs.
Mike Gee
Old 04-16-2008, 12:32 AM   #5722
LAPU-LAPU's Avatar
Trader Rating: 33 (97%+)
Send a message via Yahoo to LAPU-LAPU
Default Servo Saver
Need some help guys i've been using my TC5 for almost a year now and im having fun racing it in our local track here (outdoor Asphalt). My problem is the Servo Saver and i found it very stiff and it strips the servo gears 4 airtronics and 1 JR, all are standard servo. And when i change it into more powerful metal gear like HITEC servo it brakes the front arm when i hit the wall. well that's my error and mistake anyway. The question is, is there's a way to soften the actions of the TC5 servo saver?
■ Team DU30 PI ■
LAPU-LAPU is offline   Reply With Quote
Old 04-16-2008, 02:09 AM   #5723
isnt it with diff height adjustments, you either raise or lower CG?
correct me if im wrong
I found this on rcracing.com posted by Lex
Here's my basic rule for the diff heights:
Front - Lower is smoother to drive, higher is more responsive
at high speed
Rear - Lower plants the rear, higher makes the rear rotate
Those are the most basic instructions I can give. Hope that
helps.
Brent
naggalowmo is offline   Reply With Quote
Old 04-16-2008, 12:01 PM   #5724
There is a threaded adjuster that goes on the spring of the servo saver, make sure it is fairly loose, tigher = less saver action, looser = more. All ive ever run are high power mg digital servos and i have no issues with teh stock plastic arms. if you are still having trouble maybe get an aluminum servo arm or maybe a servo saver arm (kimbrough 201 is very good, not sure if it will fit)
Mike Gee
Old 04-16-2008, 02:08 PM   #5725
fatbear's Avatar
Send a message via Yahoo to fatbear
at high speed
helps.
Brent
Posted by AE team driver Juho Levanen earlier.
"Raising the diff will result in more onpower traction in the end you raised the diff. For example, putting the front diff to the highest position and rear diff to the lowest position will give you the most onpower steering and vice versa. I normally run mine mid low both ends, sometimes mid high in the front. If the driveshafts are straight your car will the more neutral on and off power. The driveshafts try to straighten out when accelerating which causes the handling effects.
The center of gravitys effect is minimal. The diffs weigh less than 10g. Try taping a 10g lead weight on the topdeck and see if it makes a difference That is 10x bigger change on the center of gravity than the diffheight and you probably wont be able to tell a difference"
fatbear is offline   Reply With Quote
Old 04-16-2008, 03:03 PM   #5726
fatbear's Avatar
Sorry, double post.
Old 04-16-2008, 07:57 PM   #5727
Roadburn's Avatar
Default ITF?
Hey guys, I was wondering if ya could fill me in on some past TC5 info. I've been running carpet for the past 7 months and now it's time to hit the blacktop. As I printed out some pro set-ups to find a base. I noticed something that must of slipped me in the TC5 news. As I looked down and seen Chassis and Top Plate. Allot of guys are running an ITF version. Can ya guys fill me in on whats the difference from the stock chassis and plate. Also I plan to try out a one-way Diff, since this will be the first time running the TC5 on anything other than carpet. Thanks guys
Roadburn is offline   Reply With Quote
Old 04-17-2008, 06:43 AM   #5728
stanislow's Avatar
I-increased
T-torsional
F-Flex
its a more flexible chassis to run, on carpet, the stocker is awesome becuase its super stiff, whereas if your running asphalt, the ITF is a great way to go because of the increased chassis flex you get
as for a one way, i hope you like not using brakes
Eastridge Hobbies
Old 04-17-2008, 08:40 AM   #5729
I would like to say I won but......My diving was a bit off tonight.
AHH there is your problem, you should not be diving on the track. It is not healthy and it can cause injury or even worse gross humiliation.
These damn thrill seekers these days....I swear.
(I know this was simply a typo but I just could not resist - all in fun)
Anyway, I am curious as to how much you can adjust ride height. I am looking for a nice parking lot runner for high speed thrills but I would need to raise ride height a few mm to compensate for the uneven surface associated with your typical street or paring lot. I don't race so I am not concerned race worthiness.
TomBlaze is offline   Reply With Quote
Old 04-17-2008, 08:49 AM   #5730
LAPU-LAPU's Avatar
Default Upgrade!
Thanks a lot for the tech tips, i think i really have upgrade my servos into a better one like high speed metal gears, coreless and digital to match the radio that i am using right now, i was using the vintage Airtronics XL2P and upgraded it to Futaba 2.4ghz 3PM which really awesome,However, forgot to upgrade my servo. i have disassembled the servo saver of the TC5 and loosen up a bit. But it's still stiff, maybe that's really for a reason for an on-road car. i have compared it to my RC10GT servo saver and the one on the truck is a bit softer.
Thanks a lot for your help....
■ Team DU30 PI ■
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
