Old 03-31-2008, 01:00 PM   #5626
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by bvoltz View Post
Yep... I will use a dremel, but I thought if someone had a more adjustable motor mount, it would be better... I guess I need to find someone that can mill me one...
What FDR are you trying to get down to?
Kraig is offline   Reply With Quote
Old 03-31-2008, 01:40 PM   #5627
Hi all. This is a video of the last final in our track. Itīs difficult to say what car is mine because of the quality of the images. After all, we were fast
http://www.youtube.com/watch?v=SYRRcPfpeUc
Whith an incredible exercise of viewing there is a car in white/black/slightpink.
cochecito is offline   Reply With Quote
Old 03-31-2008, 03:30 PM   #5628
geeunit1014's Avatar
a 90/53 fits in with no mods (around a 3.5 FDR) with plenty of room for bigger pinions
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-31-2008, 03:39 PM   #5629
xtrememadness's Avatar
Send a message via AIM to xtrememadness
yo sean whats up? just finished building mine and im gonna start with sean cocharans setup for stock. its on the ae website. also ygpm.
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 03-31-2008, 04:09 PM   #5630
Jsaves's Avatar
Robk,
When you push out the front arm mounts the 2 degrees, how do keep the bones end pins from binding on the alum. rings on the out drives. Am I doing something wrong or is there something I should be doing to get the bones farther in the out drives?
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 03-31-2008, 04:33 PM   #5631
Gain Time's Avatar
I know I have posted this before but has anyone figured out what is causing the wheel bearing to fail so much?
I have been very careful NOT to hit the boards so I am sure this is not the issue. I just got through running the Texas State Championships in Dallas and I literally replaced the outside wheel bearing after each run. This is kind of negating the whole parts are cheaper theory.
I am running the stock class with all hard parts, 3 degree toe in on rear, 0 degree in front. All 4 bearing seem to be crunchy after each run. Are the factory boys replacing bearing each run?
Btw this also causes me to replace ball cups more often because I have to keep popping them off to either replace the bearings or at least check them. Any help on this would be helpful.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 03-31-2008, 05:02 PM   #5632
just get some quality bearings like from boca or aps racing. the kit bearings are so so.
Old 03-31-2008, 05:53 PM   #5633
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Jsaves View Post
Robk,
You can dremel down the ends of the pin very slightly. You should be able to get it flush with the diameter of the outdrive. I did that, and it made the binding a non issue. Going to the aluminum and bone setup also works if you gots the $$$.
Old 03-31-2008, 05:57 PM   #5634
robk's Avatar
Originally Posted by Terry M View Post
Are you guys noticing a slight drag on the steering on the initial build? I've just about got mine done as of last night and it seems like the steering from side to side seems a little tight. Do you guys leave the screws that hold the steering post slightly loose or snug them down? I've got the servo servo setup exactly as the manual states.
Also...I'm using a Robinson Racing 64p spur and could only get 2 "shorter" screws to line up correctly to hold it on. Will it be ok using 2 instead of 3?
2 screws = ok. Are the screws on the steering knuckle really tight?
Old 03-31-2008, 07:26 PM   #5635
Jsaves's Avatar
robk,
Thanks for the info.
CRC GT-R
CRC WTF-1
Old 03-31-2008, 11:14 PM   #5636
bvoltz's Avatar
Trader Rating: 44 (100%+)
with 13.5 4.5
with 17.5 3.7
I have a 66T spur, but the motor mount does not allow enough adjustment to have this spur in the car...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 03-31-2008, 11:16 PM   #5637
bvoltz's Avatar
I'm running 48P because I run outside and I hate when rocks get in the 64P and take me out of the run... 48P is more forgiving....
Old 03-31-2008, 11:35 PM   #5638
HB Moose's Avatar
Changing the pulley size would work too. One tooth bigger center and one tooth smaller front and rear would get us to 1.86 internal. Then a 66 spur, 35 pinion would get you to 3.5 final. Now we just need some one to make after market pulleys.
HB Moose is offline   Reply With Quote
Old 04-01-2008, 10:28 AM   #5639
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
What part number should I look for from Acer or Boca for the outer wheel bearinigs. I cant find the 6x10x4 size on their website. Any help would be appreciated.
I have been having problems with the stock bearings as well.
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 04-01-2008, 10:47 AM   #5640
Terry M's Avatar
Trader Rating: 24 (100%+)
Robk...I'll check that out but they seemed really "free" when I was assembling them?
I'm shooting for a 4.44 FDR with a Novak 13.5 SS BL using a 100/45 64P running rubber tires on asphalt. Has anyone tried this combo and is it safer to go with a lower FDR with this motor?
Terry M is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Henry#40
