Old 03-24-2008, 07:18 AM   #5566
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Nalves View Post
Hi,
Can you tell me how do you calculate the FDR (final drive ratio?)?
Thanks,
Nuno
http://gearchart.com/index.cfm?fuseaction=chart.create
Pick a car and put your spur gear and pinion
yyhayyim is offline   Reply With Quote
Old 03-24-2008, 12:52 PM   #5567
yyhayyim's Avatar
Default O-rings
Asphalt set ups from R. Cavalieri show he uses 4 o-rings on top deck...but where? The 4 outermost screws, 2 in front and 2 in rear? All 4 in front or 4 in rear?
Old 03-24-2008, 01:29 PM   #5568
PW
PW's Avatar
Send a message via AIM to PW
All 4 o-rings in the rear.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-24-2008, 04:10 PM   #5569
yyhayyim's Avatar
Thanks PW
Old 03-24-2008, 04:45 PM   #5570
LOW ET's Avatar
Trader Rating: 95 (100%+)
just so everyone knows, the smc 5000 hardcase will fit the tc5 with no problems.
LOW ET is offline   Reply With Quote
Old 03-24-2008, 09:39 PM   #5571
Hey guys. Great topic, I've been reading for weeks now, some great info indeed.
I'm at the early stages of building a TC5 for a friend of mine.
Car will not see the track, but will be used for pure speed and parking lot fun. Motor is a Mamba 6900kw and batteries will be Lipos 6000mha by Max or similar supplier.
I want to make the drivetrain as bulletproof as possible, what would you suggest as far as diffs?
One way, spool, aluminum diffs? front, rear?
Again, cornering will not be as crucial as a proper race setup (obviously it needs to turn fairly well), I'd just like to make the drivetrain as bulletproof as possible and have my friend go thru a lot of packs between eventual rebuilds.
Thanks in advance.
flatovercrest is offline   Reply With Quote
Old 03-24-2008, 09:53 PM   #5572
Verndog's Avatar
Trader Rating: 16 (100%+)
As far as bulletproof, Id do a one way in front and rear diff 1/4 turn back from tight. I've had very good luck with double diff, but building correctly is important. Just avoid a spool. Batteries you'll be limited to 6 cells...so I'd recommend the MM7700.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 03-24-2008, 10:15 PM   #5573
pekpekmaster's Avatar
anybody use the 13mm novak rotor on a 13.5 in their tc5. wondering what you are geared at.
sipsipthekengkeng
VIVID VIDEO / DUREX CONDOMS / HKS / BANGBUS / ALBERTO'S / SAN MIGUEL BEER / BEATROCK
pekpekmaster is offline   Reply With Quote
Old 03-24-2008, 10:23 PM   #5574
Verndog's Avatar
sipsipthekengkeng
I put a 13mm in about 2 months ago. Running from 4.8 to 5.2 on carpet with it (just switching over to asphalt now)
---Team Hoarders---
Old 03-25-2008, 06:43 AM   #5575
Vern, thanks for the tip.
I was actually thinking spool on the front..why you think is better to have one way compared to spool on the front, for reliability?
Thanks.
Old 03-25-2008, 08:25 AM   #5576
Terry M's Avatar
Trader Rating: 24 (100%+)
I'm building a TC5 now and I'm putting an aluminum diff in the front. The diff kit part #31182 comes with CVD blades but my original plastic diff doesn't require them. Is the slot on the aluminum outdrives wider and require the use of these? Should (or can) they be used with the rear plastic diff?
Terry M is offline   Reply With Quote
Old 03-25-2008, 09:00 AM   #5577
Hello, you MUST use the blades with the alu diff or they will eat it. don΄t need in the rear plastic diff.
cochecito is offline   Reply With Quote
Old 03-25-2008, 09:10 AM   #5578
Verndog's Avatar
Thanks.
A spool is locked, when you hit something or heavy power on with that Mamba you will go thru blades and outdrives way faster locked. Soon with that power you will see ditch markes in the outdrives since the grade alum. used in them does not hold up very long. Also the oneway outdrives are steel and not alumimum.
---Team Hoarders---
Old 03-25-2008, 09:46 AM   #5579
Very good, thanks for the explanation. I'll get a one way for the front.
Old 03-25-2008, 10:16 AM   #5580
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Hi,
Thanks,
Nuno
Nuno,
The best way is you built yourself a small spread sheet with some pinion and spur options to carry to the track.
You have to distribute some pinions in the column A and some spurs in row 2. In each field you enter a formula “=$B$2/A1*$F$1” where “$B$2” is one spur, “A1” is one pinion and “$F$1” is the TC5 final ratio 2.0.
......................................2,0
Pin/Spur 75 | 78 | 81 | 83 | etc
19
20
21
etc
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
