Old 03-21-2008, 07:04 AM   #5536
beta bob's Avatar
Trader Rating: 2 (75%+)
Use Team Associated Factory Team Green Slime (Part #LXSF70) on your O-Rings it works wonders.
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 03-21-2008, 08:24 AM   #5537
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Make sure that everything is seated in the bottom of the shock. It is a very tight fit and requires some extra force to get everything to seat.
Kraig is offline   Reply With Quote
Old 03-21-2008, 08:56 AM   #5538
cutjo3's Avatar
I have tried the green slime too and it didn't work on my shocks. I noticed in the manual that it just tells you to pull on the shock shaft to 'seat' all the parts. I noticed people at the local track using a tool to compress the parts inside the shock body. The tool was just a molded piece of plastic that had a shaft that resembled the thickness of the shock shaft with a piece of flat plastic that pushed against the shock internal components.
I purchased a new set of shock shafts and have yet to put them. I am thinking maybe they are scorned somewhere? I don't see any damage, but at this point I will try anything. It is only one shock out of the 4. I have replaced all the internal parts a couple times now. It is becoming frustrating.
Current Rides
MGT 8.0
Old school RC10
Old School Losi JRx Pro
Previous Rides: B44, RC18MT, RDX PHI, FT RC18T, RC8, TC5(2), RC8T :(
cutjo3 is offline   Reply With Quote
Old 03-21-2008, 09:06 AM   #5539
Trader Rating: 38 (100%+)
That tool comes with the kit.
or8ital is offline   Reply With Quote
Old 03-21-2008, 09:43 AM   #5540
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Same here...I;ve tried replacing the o-rings, and will try a double o-ring set up...I'll see what happens...I've rebuilt many shocks before and these have been the most anoying so far...
yyhayyim is offline   Reply With Quote
Old 03-21-2008, 11:59 AM   #5541
yyhayyim's Avatar
Thanks bro...it seems now the leaking of oil from the bottom has been cured. Now I'm having trouble adjusting rebound. For example, I'd like to set them to 30% rebound, but these shocks have no bleed holes on the caps. How do you adjust shock rebound on these shocks? On the Losi Type R shocks or the Schumacher MI3 shocks they have tiny bleeding holes on the shock caps, which lets excess oil out, and you can adjust rebound very easily.
With the TC5 shocks, there's no bleed holes, and I'm trying to figure out how to set shocks at around 50% rebound...Bleeding them its very triky, and maybe these shocks are adjusted with the blue rebound foams on the caps? How do you adjust rebound on the shocks?
Old 03-21-2008, 12:06 PM   #5542
cutjo3's Avatar
Yeah, I bought my TC5 used. I need to pick one of those up. I have looked at the molded tool kit that AE sells and don't remember seeing it in there. I will have to check again.
Thanks!
Current Rides
MGT 8.0
Old school RC10
Old 03-21-2008, 01:40 PM   #5543
Maybell's Avatar
Thanks!
Shock Assembly Tool
pt#ASC6429
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-21-2008, 03:19 PM   #5544
Originally Posted by corallyman View Post
Hello,
Try Stormerhobbies.com. They are located here in the states, and I think they ship Internationally. They appear to have everything your wanting and great prices. I have known the owner for 15 years and he's a great guy and fellow racer, like us.
Steve
Thanks Steve,
They don't use Paypal, but that's ok. And they have all in stock
Nuno
Nalves is offline   Reply With Quote
Old 03-21-2008, 03:30 PM   #5545
robk's Avatar
Trader Rating: 22 (100%+)
Generally, you have to control rebound by the amount of shaft in the shock as you assemble it and by bleeding the shock by loosening the cap.
I try to always have the shaft almost completely in the shock. Usually, putting the bladder on first helps to get the shock close as well, by displacing excess oil.
A lot of times, you have to slightly loosen the cap, as you push in the shaft, to let some oil out and get the rebound the way you want it. It can be frustrating, but keeping fresh bladders in the car makes this a lot easier.
Old 03-21-2008, 03:36 PM   #5546
Default Diff problem
Hello again,
Today i've made 12 minutes x 8 times = 96 minutes, a hour and half, with the TC5
The problem that i have with the TC5 is that after each run i have to tighten the front diff, because it end always to loose...i run the front diff about -1/8 turn or less.
Is this normal? When i'm working on the diff the phrase ".. the diffs are something to be lusted after..." that XRC-Cars Mag said just comes up to my mind
Nuno
Old 03-21-2008, 04:06 PM   #5547
yyhayyim's Avatar
Thanks Rob...these shocks are tricky and more difficult to deal with at first than my MI3 or Type R shocks...just got used to the bleeder holes on the shock caps and its sooooo hard to get the exact rebound settings on all 4 shocks with these AE TC5 shocks.
I've cured the leaking from the bottom pblm and have them at around 40% rebound...its closest I could get them to w/o making a mess so that's what they'll be staying at for now...but wow, once they're set , they are suuuuuuuuuper smooth
Old 03-21-2008, 05:05 PM   #5548
J_P
J_P's Avatar
I am looking to run 13.5 with a FDR of 4.40-ish. What size spur are people running (64p)? What is fitting, as far as having room to change up and down a few?
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 03-22-2008, 02:09 PM   #5549
t4mania's Avatar
Whats the easiest way to set droop. I'm using a setup from the AE website and have a droop gauge just need to know what is the best way. Are blocks needed to raise the car.
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 03-22-2008, 04:03 PM   #5550
katfish317's Avatar
The way that I do it personally and it might not be right is to measure the ride height of the car, and then adjust it to where I can pick it up to the height that I want the droop set too and adjust the screws till they touch when I lift the car to that height.
katfish317 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
