Team Associated TC5
#5491
How's the hole spacing on the xray spurs? Can you fit more than 2 screws?
#5492
No problem here running Kimbrough spur gears. Run true, last, and mount to all 3 holes.
http://www3.towerhobbies.com/cgi-bin...?&I=LXS457&P=7
#5494
Hey Guys
I am having a nightmare with the shox on my TC5 .. however I build them I cant stop the bloomin things leaking ...
I have tried with and without foams.
Any tips?
Any tips?
#5496
Hello everyone, I am new here and I am racing a TC5 and have a few questions about gearing with 64 Pitch spurs. I will be running in the stock class and using a 27T motor. Where should I start with this motor, from what I can tell most of the tracks I will be racing they are all a good size, not really short. Any help would be appreciated. All are also asphalt with rubber tires.
#5497
One of the most annoying things with my TC5 is when I have to change arms or what the change the roll center. I have to basically take the entire end of the car apart so that I can get to the 2 screws that hold the arm mounts in (since they are on the inside of the bulkhead).
Anyone tried moving the screws to the outside of the bulkhead and using a washer on the inside to keep it from coming out? This screw also has a tendency to start to back out after racing and its rather difficult to tighten(unless you have a rounded hex driver) or use a L-wrench.
Anyone have any suggestions?
#5499
anyone running brushless and have stepped up there gearing to use the Kimbrough 90T, 93T, or 96T 48p spurs?
#5500
#5501
There are probably better expert stock guys on here then me, I am more a "Mod" guy than stock, but I ran a indoor carpet rubber tire race recently on a small track. I ran a 112/30 64p on a Epic CO27 motor. For outdoor on a bigger track maybe run a 112/32 or 33. Just make sure the motor doesn't get too hot.
Steve
#5502
In order for this to work, you would have to drill out the threads in the current "nut" portion. You can tighten up the screw as much as you want and it will feel tight once the head meets the mounting nut. You would still have to tighten the nut on the other side with a nut driver.
#5503
#5504
Thanks alot Steve I appreciate it alot!
I will try those as I plan to go and test at one or two of these tracks.
Tim
Tim
#5505
are they leaking while on the car or lying on a table? when i built mine they seemed to leak when lying on their sides when they were on my table. now if they were leaking or maybe oil was just running out from every nook and cranny from the oil over flowing when assembling, i don't know. what i do know is when they were put on the car and setting up right, there was no leaking.
