Old 02-22-2008, 11:02 PM   #5371
Diggity's Avatar
Trader Rating: 29 (100%+)
Originally Posted by wallstreet View Post
Another thing you can do to help the cause would be the diggity designs aluminum caster blocks. They are awesome and i got them as soon as they came out.
WORD!!
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 02-23-2008, 10:05 AM   #5372
I bought some Diggity castor blocks and they are very nice. No if it would just quit raining on the weekends in SoCal i could try them!
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 02-23-2008, 06:40 PM   #5373
LOW ET's Avatar
Trader Rating: 94 (100%+)
do the tc5 racers tape their batteries in or are they using the battery strap? it looks like the strap will tweak the chassis when the thumb screws are tightend down. what's your thoughts on this?
LOW ET is offline   Reply With Quote
Old 02-23-2008, 06:56 PM   #5374
I've seen batteries launched out of cars constantly with the battery strap where i race. I went to tape and it stopped happening to me
naggalowmo is offline   Reply With Quote
Old 02-24-2008, 10:01 PM   #5375
Knight Rider's Avatar
Originally Posted by Gain Time View Post
I started with the Juho Snowbirds Feb 2007 setup and tweaked it a little to get rid of the loose in and tight off condition I got with it. It is hooked up now. I shaved 3 full seconds a lap off from when I started with the car. Driving experience mostly but the final 1 was from adjusting the car.
What changes did you make to the setup... I ran that today and had the same problem. I was great in the sweepers but in the tight corners it tended to be loose in and tight out. It didn't seem to want to turn from the center of the car. I'm using the sandard parts, not the hard.
MHOR R/C Raceway - W.E.D. Paint
RC8Be - Tekin Rx8 - T8 2050kv - Reedy 4s 5500mah
B4.1 - LRP SXX V.2 - X-12 (8.5) - Reedy 2s 5500mah
B44.1 - LRP SXX-TC V.2 - X-12 (7.5) - Reedy 2s 5100mah
Knight Rider is offline   Reply With Quote
Old 02-24-2008, 10:16 PM   #5376
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
not sure how close your setup is but if my car was doing that I would take about an eigth turn out of the rear and it would fix that
loopedout is offline   Reply With Quote
Old 02-25-2008, 08:20 AM   #5377
Hey guys, I'm looking to gear my tc5 for a novak 10.5 with lipo for rubber tire asphalt. I understand I'll want a fdr in the range of 4.5 to 5.5 (maybe even down to 4.0?). I'd like to run 64p gears, what size of spur do you guys recommend? I guess it could also be asked as, what's the smallest and largest spur/pinion combo that will still mesh in the motors range of positioning?
bread is offline   Reply With Quote
Old 02-25-2008, 10:38 AM   #5378
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
hey guys. I need some TC5 help. Well I have the setup that robk posted on my car. I run 19t with rubber tires on carpet. The only change that I made (and it was due to me not knowing any better) was that the wheel base was increased by 1 mm (put the wrong size washer in the front of the arm). Also changed to the aluminum 6 degree castor blocks (problems occured prior to switch as well).
Now I am having tire squeeling problems. About half way through my race, the tires start to squeel around turns. I use Jack the Ripper compound on the entire rear wheel and half of the inside wheel for the front. I am using RP30 tires. Is it a tire problem? Any setup changes that may help.
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 02-25-2008, 11:40 AM   #5379
RCpurplecow's Avatar
hey guys, I haven't been racing in a while, but want to get back into it. I race rubber on indoor super high grip asphalt (similar to rubber on carpet), should I switch to the ITF top deck and chassis or just run standard. Does anyone have a good setup.
thanks
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 02-25-2008, 11:59 AM   #5380
100/44 is a 4.54, works great in mine, I run an 8.5 though.
Old 02-25-2008, 12:57 PM   #5381
Trader Rating: 68 (100%+)
You may want to add more rear droop,i am running 2.5 mm over ride height,and play with the ackerman this is a good setup to play with hope this help
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 02-25-2008, 01:53 PM   #5382
losithrasher's Avatar
hey guys, im gonna be running 17.5 and 13.5, what spurs and pinions should i start running?
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 02-25-2008, 02:25 PM   #5383
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
For 13.5 I use a 96 tooth spur (64 pitch) with 36-48 tooth pinions (64 pitch also) I have a 96tooth, 100 and 104 tooth spurs.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 02-25-2008, 02:45 PM   #5384
thanks
oval or on road?
Old 02-25-2008, 02:49 PM   #5385
on road
TEAM SRU
FT TC5
NoVak
rematch batteries
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
