Old 02-10-2008, 08:56 AM   #5311
Any of you guys running Lipo? Do you really have to add almost 300 grams to get to weight?
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 02-10-2008, 09:04 AM   #5312
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by LOW ET View Post
why would you want to use the optional rear hubs (0.5, 1.0 degree), when you can change toe with the shims at the bulkhead?
Running more toe at the hub is:
*More aggressive as you add toe to the hub
*You do not change wheelbase like with toe at the bulkhead
Old 02-10-2008, 10:02 AM   #5313
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
the toe at the hub is supposed to make the rear end rotate better
bigemike is offline   Reply With Quote
Old 02-10-2008, 11:10 AM   #5314
Verndog's Avatar
Trader Rating: 16 (100%+)
Are you talking in addition to the lipo your running? You should not have to add that much in addition. Of course this will vary with the electronics your running also. But mine with 13.5, LRP Sphere 2007, PT, and Mazda 6 balanced comes in 34g (1559 gr.) over.
Best thing you can do for your TC5 and balancing a LiPo is add the balancing system listed --HERE--.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 02-10-2008, 12:17 PM   #5315
Mine is at 1339 with all the electronics? 1550 is minimum with rubber tires right?
FT B44 - FT J82
Old 02-10-2008, 12:38 PM   #5316
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
My TC5 with Verndogs products :
Team Associated TC5-p1010054.jpg   Team Associated TC5-p1010031.jpg   Team Associated TC5-p1010049.jpg   Team Associated TC5-p1010033.jpg   Team Associated TC5-p1010064.jpg
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 02-10-2008, 01:24 PM   #5317
I forgot about those! Just placed an order. Do you still have stock for the TC5 Verndog?
FT B44 - FT J82
Old 02-10-2008, 05:07 PM   #5318
I know you posted this a while ago, but I built my shocks as per your instructions and they worked out great, thanks Rob.
Originally Posted by robk View Post
Since it sounds like you have a problem with the shock tops-
1. fill with oil as normal
2. place bladder on top of shock, making sure to let out any air trapped under the bladder.
3. Stack plastic shock end on bladder, then the aluminum blue cap over that.
4. Slowly start to screw on the cap, enough to get the threads started. Push the shaft in almost to the threaded portion. Oil/air may come out.
5. Screw on slightly more, making sure the shaft is not rebounding/sliding out. Everything should feel seated correctly. Continue holding the shaft in as you finish screwing on the cap.
6. Check rebound. You may need to partially loosen the cap if the rebound is too fast/too much, and let some oil out. You'll notice the cap gets to a point where you can feel it's not tight, then you can push in the shaft to get some oil out.
I had to play with the shocks a lot, and I also built a TON of shocks to be able to get a good feel for everything. Once you get the feel, it goes together pretty quick. It's not really hard, but if you just play around a bit, you'll get it.
outlandr91 is offline   Reply With Quote
Old 02-10-2008, 06:31 PM   #5319
Verndog's Avatar
Yes I do...and more coming Wednesday if there is a sudden run...Getting pretty steady orders as it is though.
Yes...1550 is correct...I thought it was 1525 for a moment...I'm still over barely with the EZ LiPo balance by a measly 9 grams. Is your 1339 with something like an Orion 3600?
---Team Hoarders---
Old 02-10-2008, 06:59 PM   #5320
Trader Rating: 38 (100%+)
I thought it was 1525 for ROAR?
or8ital is offline   Reply With Quote
Old 02-10-2008, 08:58 PM   #5321
Verndog's Avatar
I read that also, 1525 in the 2007 ROAR, then at the track today I saw GT2 and 13.5BL posted at 1550. Not sure whats up with that. Guess I'm in on both, but I suppose I should read just what the posting at SIR is regulated to.
---Team Hoarders---
Old 02-10-2008, 09:21 PM   #5322
Yep, I have a couple 3200's as well though. The 3600 is actually borrowed.
FT B44 - FT J82
Old 02-10-2008, 09:21 PM   #5323
Anyone have a good starting point for gearing for a Novak 10.5 w/lipo on a short & technical asphalt track with rubber tire (Bending Corners in Orange, CA)?
bread is offline   Reply With Quote
Old 02-11-2008, 01:26 AM   #5324
fathead's Avatar
Just wanted to post to say the TC5 did very well at this past weekends New Zealand Nationals in the mod class, taking 4 out of the top 5 places in the A final, 1st, 3rd, 4th, & 5th.
Slavich Design
fathead is offline   Reply With Quote
Old 02-11-2008, 10:00 AM   #5325
Greetings all,
Can anyone tell me the difference in wt. b/t trinity shock oil and associated? many setups use associated oil, but I already own all the trinity oils. What would 30wt associated be equivalent in trinity oil?
Cheerz
Obsidian is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
