Old 01-31-2008, 08:13 AM   #5251
nutsisneat's Avatar
Default Gearing question
Hello
I'm running a Novak 4.5R on a medium technical highgrip track with 9.66 (rubber). How would you guys gear a 3.5R?
nutsisneat is offline   Reply With Quote
Old 01-31-2008, 12:16 PM   #5252
BARON P's Avatar
Send a message via ICQ to BARON P Send a message via AIM to BARON P Send a message via Yahoo to BARON P
Does anyone know what size pinion and spur (64 pitch) to start out with on a 40x90 track with 57mm tires and a KD 19?
BARON P is offline   Reply With Quote
Old 01-31-2008, 01:36 PM   #5253
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
After reading through Ken Pepe's setup and comparing it to other TC5 setups for rubber on carpet from the Team Associated website, I had a few questions.
1. Should caster read -1.5 not 1.5? Noticed that all the team drivers had -2 deg or more of caster.
2. What is the rear Belt Tension Number? Should it be 8? Didnt see it on the setup.
Just got my car and gonna put this setup on it.
Also, What is the largest 48 pitch pinion that they make? I wanted to get something in the 30-32 range but wasnt sure if it was possible.
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 01-31-2008, 01:53 PM   #5254
robk's Avatar
Trader Rating: 22 (100%+)
1. Yeah, it's -1.5. Nobody runs positive camber ever, so just assume -
2. I believe it's 8. the teeth on the cam should be up.
Old 01-31-2008, 10:36 PM   #5255
Also in Pepe's setup it said 2mm wheelbase in the front and 1 mm in the rear. Do you put the 2mm shim in the front of the front wheel or the back of it? same with the rear, do you put the 1mm shim in front or behind the rear wheel.
Chirag
Old 02-01-2008, 02:45 AM   #5256
getpip's Avatar
48 pitch pinions are indeed available in 32 teeth and beyond ... and much needed these days what with brushless and lipo and stuff! (check out some of the far east shops .. all in stock)
getpip is offline   Reply With Quote
Old 02-01-2008, 09:15 AM   #5257
Thanks for the help! The setup is coming together.
Is it possible to replace the shock end ball cup with the shock mount eyelet that they use in the offroad buggies? Can we use the offroad version and cut it down to the correct length? Does Losi make one that will fit? I just hate having to undo ball cups.
Also was thinking about switching over the ball cups on the turnbuckles to XRay enclosed styles from the T2 2008 that you hold in with screws. Seems to be easier to work with than ball cups and ball ends.
Any advice would be appreciated.
Old 02-01-2008, 05:01 PM   #5258
robk's Avatar
Chirag
The wheelbase shim is how much spacing is in front of the arm, with the front always being closest to the front of the car. I know that sounds stupid to say, but I just want to be clear
If you look at a setup sheet, they reference everything in the drawing. It is a bit clearer than text only
Old 02-02-2008, 02:41 PM   #5259
racing_jason's Avatar
quick question guys i have a car that is really pushing! what is the best way to free up the TC5?
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 02-02-2008, 02:49 PM   #5260
Maybell's Avatar
a few things you could try....
take some rear toe out..
more rear down-travel..or less front..
stiffer rear spring...
what setup are you running?
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 02-02-2008, 03:21 PM   #5261
robk's Avatar
http://www.rc50.com/modules/coppermi...8/PICT6609.JPG
Note in the above picture, Bob Stellflue, AE engineer and super-genius, has such mind power that small objects are pulled into orbit around his head. Note the Jaco rim to the right which has succumbed to his intellect vortex.
Old 02-02-2008, 03:49 PM   #5262
Maybell's Avatar
wow!!!! that prism is just hovering there!! weird...
Old 02-02-2008, 07:22 PM   #5263
carbon madness's Avatar
Lol that pic is too funny (although I can see who made the toss of the wheel)
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 02-04-2008, 07:03 AM   #5264
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
I am building a carpet / Foam tc5, I already have one that I love on rubbers, my new kit should be here tommorow, so if you can direct me to a good starting point on the setup that would be great.
bigemike is offline   Reply With Quote
Old 02-04-2008, 07:29 AM   #5265
Trader Rating: 16 (94%+)
Whatever Carpet Foam setup you decide on, be sure to order all the HARD suspension parts Associated recently released.
KSN
kn7671 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
