Team Associated TC5
#5206
DAVEW
we all must be stupid then cause brent thielke posted on the ae forum, where there is talk just about associated cars and no bs or people ragging on the car and he also said the closest associated pistons are
associated 3 = losi 57
associated 2 = losi 56
also posted on the same forum under a different thread craig drescher also says the 57 and 56s are just like 3s and 2s
I guess everyone has there facts wrong
Youre right. I withdraw. Since the rest of us lowly racers that have spent years and years wrenchin on these suspensions arent sponsored, then our words carry no weight... or meaning. Noone says "... well, DaveW said blah blah blah..." and then the heavens open up, and ladies fall braless to their knees. Regardless, until you purchase the drill bits for yourself... and do the WORK yourself... you will continue to quote the words of other people... you flippin fanBOI. If everyone thought like you, then they would realize what YOU say is worthless, because NOONE knows who the eff WALLSTREET is. And your words carry no weight...
I'm not in charge here in any way, but this is retarded crap that needs to stop.
#5207
Jsaves, generally the Parma Alfa or Mohawk. The lightweight usually makes the car more reactive and faster on laptime, but they are flimsy. If your car gets too crazy twitchy on superhigh bite (yeah, i know this only matters if you're at a big race), the regular weight may actually be better. I was driving a guy's car at the Novak w/ a reg. weight, and it was very smooth, with a setup close to mine. The lightweights may be better on overall laptime though, due to the cg being a lot lower.
#5209
#5210
Spool / Oneway
For a returning racer after taking 6 years off is a spool or oneway needed on carpet with rubber tires in stock class?
Back when I raced a TC3 the oneway was the way to go but now with the TC5 and belts I have no idea if they are needed.
Can you please explain what a spool does and when do you use a oneway or spool and do you use them together?
Sorry about all of the questions but I am just getting back into it and I am learning all over again.
Thanks for all of your help in advance and trust me I will have more questions once I get my car and start putting it together.
#5212
You don't necessarily need either to start off, especially if you haven't run in 6 years. Usually the one way is faster, unless the traction is pretty low, at least on carpet.
The spool usually pushes into the corner, and steers a lot leaving. Good brakes.
The oneway will steer into the corner hard and be good out too.
Maybe some others can chime in, as I haven't been running much rubber.
IMHO
Good luck.
IMHO
Good luck.
#5213
The past few months I have been running my car with a diff in the front. But last week I felt like I was loosing out on some of the drive I needed off the corners so I switched to the spool. After some brief testing and a few setup changes, I pretty much have the car where I want it. I will post my thoughts on it after this weekend and try to give some sort of a comparison. But as of now, my thoughts are : One way or spool. Dif just seems to have less overall punch.
#5214
I have never in my life yelled "body tuck" but I feel it's coming next weekend at the Snowbirds.
#5216
I am gonna be running a 10.5 (Peak Vantage) with rubber tires on a smaller/tight carpet course. What is a recommended starting gearing for pinion and spur gear?
Also anyone have a link to a rubber (28R) setup for carpet. Gonna be using the one-way and the ITF chassis and upper deck.
Any advice would be appreciated.
#5218
Kraig - Found the setup. Thanks!
The track that I am running at is a 60' x 48' track. The long straight is 60'. Any starting pinion/spur gear for a 10.5 would be very helpful (i am assuming that I will be running 64 pitch).
#5220
G'Day Chris
I run a TC5 here in Sth East QLD and am have now got it to be very stable. There's a few of us running them in different guises but we are all having great success with them.
You say the rear end has no grip, is this on power or off. Also what classes are you guy's running and is the track large with sweeping bends or technical with a mix of tight and open turns?
Cheers
Aaron
Cheers
Aaron
