Old 01-09-2008, 08:38 PM   #5101
DaveW's Avatar
Originally Posted by Jsaves View Post
Dave W.
I bought the EP 4600's and they fit with no problem at all. I think the 4200's and 4600's are the same size. They both fit the TC5. Plus you can probably run two runs with the 4600's or almost.
SWEET! Thanx for the input! We have actually been tossing around the idea of 7 or 8 minute stock TC at our track... a few have shown interest... but not a majority. 4600's are opening doors for electric w/o the issues of LiPo.
DaveW is offline   Reply With Quote
Old 01-10-2008, 12:05 AM   #5102
SammyZ's Avatar
Trader Rating: 138 (100%+)
do you guys know how much castor is good for a TC5 running foams on low-medium grip carpet...mostly low grip carpet.
SammyZ is offline   Reply With Quote
Old 01-10-2008, 09:41 AM   #5103
t4mania's Avatar
4* castor blocks work fine for me but any changes you make to your car has to fit your driving style too. Some people like more turn in and use 6* castor blocks, I prefer the 4* as I said. Experiment with both and see which fit your style of driving best.
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 01-10-2008, 11:13 AM   #5104
Rick Hohwart's Avatar
Originally Posted by SHAUN GRIDER View Post
is this what some of the guys and the novak race were they running the new arms and other parts?
I am sure some were, but I am not sure who or which parts.
Rick Hohwart is offline   Reply With Quote
Old 01-10-2008, 01:20 PM   #5105
robk's Avatar
Trader Rating: 22 (100%+)
Caster is faster. Most everybody runs 6* unless the grip is really high, some will go to 4* to make the car easier to drive.
Old 01-10-2008, 01:34 PM   #5106
Trader Rating: 19 (100%+)
What are the benefits of running 1 degree rear hubs opposed to 0 degree rear hubs?
TIA
zake540 is offline   Reply With Quote
Old 01-10-2008, 04:58 PM   #5107
robk's Avatar
TIA
Originally Posted by robk View Post
...ReaR
ride height 4.5
camber 2.0
toe hub 1.0, 2* overall toe (this is an aggressive setting, .5 or 0 toe at the hub mellows the car out/reduces rotation, when overall toe is the same)
hex spacing 0...
Besides the above, you also don't loose/gain length on the wheelbase when you change toe at the hub. It seems most guys use the hub toe on foam cars.
Old 01-10-2008, 07:16 PM   #5108
Maybell's Avatar
Hey Rick,
You heard any word on where the Reedy TC race may be held in 08?
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-11-2008, 05:51 AM   #5109
had a question about droop. I was looking at Juho Cleveland setup that list fwd 7 and aft 6 of droop. How is this measured? Is it above ride which means to me that with the tires on and on flat surface and measuring when the tires touch. Or it is with the the wheels off using the droop guage. This doesnt seem like alot of droop travel at all or is it the point. Still new at this thanks
hourocket3 is offline   Reply With Quote
Old 01-11-2008, 06:18 AM   #5110
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
the 7 and 6 are from the associated droop gauge.
wallstreet is offline   Reply With Quote
Old 01-11-2008, 07:43 AM   #5111
Originally Posted by Maybell View Post
Hey Rick,
Funny, we were trying to finalize this yesterday. We have two good options and are debating which is best for the drivers.
We should announce something shortly.
Old 01-11-2008, 09:03 AM   #5112
beavis353's Avatar
Shawn,
I believe most of the Foam TC5's that I saw at the Novak were running the stiff suspension components front and rear.
As for myself, I was running the stock arms and caster blocks all week in the rubber tire class. I also ran the ITF chassis and top plate. The car on rubber tires is incredibly balanced, and is easily tuned as the traction comes up (even for a 1/12th guy). One of the things I would have tried if there was more time, was the standard chassis and top plate. With wicked high grip associated with a big race where both rubber and foam tires are being used, I think it could have made the car easier to drive.
In the future, I will most likely keep running the standard suspension components for rubber tire, and use the stiff for any foam races i may attend.
Beavis
beavis353 is offline   Reply With Quote
Old 01-11-2008, 09:50 AM   #5113
Scottmisfits's Avatar
I put the droop of 6 and 7 on my car but it wouldn't let me get ride height. What was I doing wrong? It would only let me get about 3mm, not the 5 and 5.5 that he has posted.
Scottmisfits is offline   Reply With Quote
Old 01-11-2008, 10:21 AM   #5114
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
Nexus Racing now has the TC5 P-Dub Bumpers back in stock! There are not many left, so act fast!
http://nexusracing.net/product_info....oducts_id=1492
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 01-11-2008, 10:40 AM   #5115
Trader Rating: 17 (100%+)
Use the AE droop gauge and measure it at the bottom of the outer hinge pin hole on the a-arms. You can do this (droop 7 and 6) if you have new tires on your car. If your tires have a few runs on them they are a bit shorter and you lose ride height. When you raise your ride height to compensate you lose your droop. If this is the case then move your droop to 6 and 5.
YMMV
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
