Old 01-08-2008, 04:27 PM   #5071
robk's Avatar
Trader Rating: 22 (100%+)
BTW Kraig may be able to fill you in on the good rubber tire setups, as he was very fast in 10.5 rubber. Beavis, too
Old 01-08-2008, 04:31 PM   #5072
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
rob i believe jucha was running full hard parts on his car.
bob brought hard arms, steering knuckles, caster blocks and rear hubs.
Hopefully all the hard parts are in and not just the arms.
Just like rob said everyone who ran a TC5 including rob cars looked awesome. The TC5 carries unbelieveable corner speed
wallstreet is offline   Reply With Quote
Old 01-08-2008, 05:39 PM   #5073
carbon madness's Avatar
So are we going to get one of those deals like AE did with the RC8 on the new parts for the TC5 for the people who already have one?
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 01-08-2008, 06:29 PM   #5074
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
What was wrong with the RC8 parts? If there was something wrong with the material such as a manufacturing defect then who knows. These are more of an option/tuning part.
Rob or Wallstreet, are you guys going to try the Losi pistons in your shocks for rubber? Just curious to see what kind of difference they make.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-08-2008, 06:33 PM   #5075
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
consider that with the rc8, the newer parts were to help with durability and functionality. With these newer parts, they are just made to suit one type of surface better. The original parts are not "wrong", and are better suited for rubber tire racing. This isn't a "running change" like the RC8, but more so a tuning option if needed.
Brandon Melton is offline   Reply With Quote
Old 01-08-2008, 06:51 PM   #5076
Mitchell's Avatar
Trader Rating: 15 (100%+)
it would still be nice though
___ _________________________
___ |__|__|__|__|__|__|__|_____\
____ |__T Associated fan bus _|_| __\_
____ |_________________ |_| ____|
____ |_(@"@)____________|_|(@)__|
HOP ON BOARD!!
Mitchell is offline   Reply With Quote
Old 01-08-2008, 07:25 PM   #5077
Jsaves's Avatar
Dave W.
I bought this TC5 lightly used and I went through the whole car and rebuilt the diffs, checked the shocks and changed the oil and made sure everything worked well. I have a queston about the diff rebuild. Do the diffs break in like the old TC3-4 ones that had to be tightened after a battery pack? Because as far as I could tell from the " no info in the manual " and rechecking them myself they did not loosen much at all.
I have in one weekend made more progress with the TC5 than I ever did with the TC4. I used Juho's Cleveland set up with a few changes. I softened it up a bit because our carpet does not have the traction that the big events get. I went with losi 45wt., # 2 pistons and copper springs in front and 40wt., #2 pistons and blue springs in rear. I could not get the camber link 4 postion to work in front with out the tie rod bottoming out the ball cup and binding the front suspension. The car handled better than my one year lay off could handle. I think it has the potential to be very fast. I wish we had a stock touring class I could run it in, but I did alright in the 19t.
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 01-08-2008, 07:41 PM   #5078
Super Moderator
Kraig's Avatar
Chances are that the spring has been compressed unless you used a new one. If you used new pieces I would check them after a couple of runs just to make sure. It is easy to do, just hold the spur and the tires and try and turn. If it slips you know you have to tighten it up. I now set my plastic diff's at 1/8 of a turn and they feel fine.
If it feels gritty then I would start looking at the diff halves as you may have slipped a ring. This happened to me last weekend when running a loose diff with a 10.5.
Old 01-08-2008, 07:56 PM   #5079
DaveW's Avatar
<--waiting a little longer to get a Tc5.
I want these few little bugs to be worked out before i get one. My Tc4 is doing well locally with rubber tires on carpet. Im actually swapping it all to the Tc3 tub with the Tc4 arms/shock towers/camber mounts intact. The arms mount up with modded Tc3 hingepin mounts to accepts the Tc4 arms and modded Tc4 pins. The Tc4 tub is still twisting too much for the grip we have on the carpet... hopefully this will get me by till AE gets all of the running changes in line for the Tc5.
JSaves- Im glad you got a car that inspires confidence. Something ill handling and inconsistent definitely slows progress. Its nice to see the good results of the Tc5, and all of the positive feedback here too. Im looking forward to a new season behind the wheel with a car ill hopefully be happy with.
Im looking at batteries... do i get 4600's or what??? So much has changed. Do they fit the Tc5 with no modification too?? Thanx...
DaveW is offline   Reply With Quote
Old 01-08-2008, 08:19 PM   #5080
Jsaves's Avatar
Dave W.
I bought the EP 4600's and they fit with no problem at all. I think the 4200's and 4600's are the same size. They both fit the TC5. Plus you can probably run two runs with the 4600's or almost.
CRC GT-R
CRC WTF-1
Old 01-08-2008, 08:20 PM   #5081
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
not positive, but while we were at dinner sunday night, i talked with Bob Stellflue for a bit and he said that Jucha's car was straight outta the box as far as components... flexy parts and all. ill give him credit, his car looked great all week!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 01-08-2008, 08:25 PM   #5082
wallstreet's Avatar
jucha was running the hard parts, i know while he was practicing before the novak race he was running the hard arms and caster blocks. He races with us locally so we knew what he was running and have been salivating over the hard arms and caster blocks cause they did make a noticable difference on the car in foam tires.
Old 01-08-2008, 08:56 PM   #5083
GSP
Default Hard Parts
What do you mean when you say hard parts. I am sorry but I have been out of it for awhile and just getting back into it. Also are the hard parts more for foam or for rubber tires! Thanks for the info!
GSP is offline   Reply With Quote
Old 01-08-2008, 09:17 PM   #5084
robk's Avatar
They have a new material that is much stiffer than the original parts. It seems to help most with foam carpet racing, though I tend to think the caster blocks would be helpful to anyone.
This is sort of like Corally who offers varying degrees of stiffness for their parts, or Xray, or HPI/Hotbodies, who have soft arms and harm arms.
Also, Jucha ran the hard stuff, because he told me he needed to tap the shock holes due to the stiffness of the material.
Old 01-09-2008, 03:56 AM   #5085
Phroz's Avatar
Sorry guys.. i know i kind of asked already but which chassis is suited to rubber on ashphalt best, The ITF or the standard. Also how have people gone mounting lipo packs.. i noticed that the screw holes for the battery retainers are inside the battery "zone" or area that the battery sits in which looks like it would be hard to modify the retainers to allow a lipo to sit flush with the chassis.
Thanks,
Ben.
Phroz is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
