Old 01-02-2008, 04:25 PM   #5041
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Originally Posted by C_Money View Post
just ordered a tc5, spring set and a one way, should be here next week. i was wondering if someone would be kind enought to shoot me a pm and explain to me how to change toe, droop and well everything else this car has to be tuned jsut so I know. Thanks a lot
in the back of the manual is a description of each change and handling effects on the car.
Brandon Melton is offline   Reply With Quote
Old 01-02-2008, 08:28 PM   #5042
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Maybell View Post
I can see how the combination of the very large diff pullies, together with a belt material that is less "soft" than most TCs could fool some into thinking the belts are too tight...if AE is truly changing the belts, we dont really know why....I think the belts feel fine...just my opinion....
as for stock....the car did win a ROAR stock national already...
But all of us can't drive like Sean Tight or not........the belts show no signs of wear though. Perfect material belt wise but I'm just wondering if they could use a couple of extra teeth to make it a hair longer to somewhat make it freer (is that a word)
STLNLST is offline   Reply With Quote
Old 01-02-2008, 09:56 PM   #5043
zacabrandy's Avatar
The TC5 also won the Queensland State Titles in Stock
It finished 2nd in 19T class at the Gold Coast Cup and was won of the fastest cars in (540) complete beginners class using the Johnson 540 motors.
I've been running the car in Modified, but am making the shift backwards to stock for cash reasons and I don't see any need to change the belts, I think they are just fine
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 01-03-2008, 04:20 AM   #5044
Jsaves's Avatar
I think a 56 (red) would be like a 2 and a 57 (black) like a #3.
Brandon,
I have seen these pistons discussed before. Do you have a part #.
I have heard these are off road pistons or can I get them by color?
I will probably have to mail order them so it would be great to know.
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 01-03-2008, 07:35 AM   #5045
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
On the belt deal, mine has enough adjustment to make them too loose and too tight if I go all the way one way or the other. I run them kinda loose I feel, and the car spins really freely, as good as my shaft drive car did.
loopedout is offline   Reply With Quote
Old 01-03-2008, 08:14 AM   #5046
Maybell's Avatar
Originally Posted by Jsaves View Post
Brandon,
losa5047 Orange #55
losa5046 Red #56
losa5045 Black #57
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 01-03-2008, 02:26 PM   #5047
DaveW's Avatar
Brandon,
Losi 56 piston HOLE SIZE is close to AE#3. Losi 55 is close to AE#2. Losi 54 is close to AE#1. AE pistons have two holes and Losi pistons have of course three holes. A three hole piston allows for less pack, assuming the piston surface/piston to shock body wall clearance is the same by comparison. This is one of the reasons Losi suspensions have always statically felt so plush, and work so well "in the rough stuff". There is also a difference between a size 56 "drilled" and "molded" piston hole... the molded hole being a bit larger than a numerically drilled hole of the same size. A three hole piston will allow for greater adjustment in roll control (weight transfer) in a TC... allowing the use of thicker shock oils, with minimal loss of overall traction. Over the years i have used two hole for low bite and three hole for high bite (like Snowbirds high bite)... which sounds backwards considering my previous statement... but IMO the three hole pistons cope with insane amounts of grip better than two hole pistons. This can also depend on which class you run... modified transfers weight in a TC alot faster than stock does. Rubber tire/carpet and other "low grip" surfaces i use two hole AE#1 pistons front and rear with thicker oils (40-70wt mixing oils for half weights). How this transfers to the new Tc5 pistons i dont know as of yet, but this can be a general guide to help you find what works for you.
DaveW is offline   Reply With Quote
Old 01-03-2008, 02:28 PM   #5048
DaveW's Avatar
Brandon... congrats... i didnt know you went back to AE! Have ya talked to KT lately?? Boys runnin quads now!!!
Old 01-03-2008, 03:48 PM   #5049
Well, if getting shot at as a Navy Seal didn't kill him, maybe that quad will finish him off, LOL! He IM'ed me the other day and the laptop battery died, if you see him tell him I said happy new year. Good luck racing.
Old 01-03-2008, 10:35 PM   #5050
Diggity's Avatar
Trader Rating: 29 (100%+)
Default NEW Aluminum TC5 6 degree Caster Block Set
Team Diggity Designs will have aluminum Associated TC5 6 degree caster block sets in stock around the end of Jan middle of Feb. The prices are posted on the website. They will be anodized blue and labeled L6 and R6 and will include delrin pivot bushings. Here are some pictures of the prototypes. Mike Stewart and Rob King are using them at the Novak race this weekend. Good luck to them!!
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 01-04-2008, 04:20 AM   #5051
Jsaves's Avatar
Thank you Maybell for the part #s. That was a big help in getting my car ready for its maiden race.
Dave W. thanks a bunch for the great info. I will copy and paste that into my ever growing file of set up tips and info. I believe you are the one who helped me out with getting my TC4 running well a couple of years ago.
Thanks Guys
God Bless
CRC GT-R
CRC WTF-1
Old 01-04-2008, 08:18 AM   #5052
DaveW's Avatar
Originally Posted by Diggity View Post
They look good! Are there plans to offer all caster angles?
JSaves: I remember spending some time in PM's with you awhile back. The Tc4 was a pain to hook up for sure. Hows the Tc5 feel to you in comparison? Im just looking for justification of the cash it will take to get one. Ill probably be running just locally, so i dont know if i will need it to be competitive. Im not looking to be dominant with R/C anymore... just to have some fun.
Old 01-04-2008, 10:43 AM   #5053
Diggity's Avatar
Yes; we are starting out with the 6 degree blocks. We will offer 4 degree blocks as well as 1 degree rear hub carriers shortly.
Damon
Old 01-04-2008, 12:11 PM   #5054
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Hey guys, what is the minimum weight limit for stock AND, which scales are decent?
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 01-04-2008, 04:11 PM   #5055
Hi guys,
Been using my TC5 for a while now and found that I'm going threw gears in my servo like nobodies business. Gone through 3 sets now since the indoor season started! I'm not hitting things hard; it's just when you take a corner ever to tight and clip the hose it just kills the servo. My servo is nothing special but my TC3 never broke a servo and had many bad smashes over the 4 years Iíve used it.
After investigating I can't actually get the servo saver to kick in so I'm wandering how I slacken it off. Do you just slacken it off from the servo saver knuckle?
Cheers
Keiran
TC5
www.keiransmart.co.uk
Keiran is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
