Old 01-01-2008, 07:52 PM   #5011
Trader Rating: 37 (100%+)
Kraig
I was so pissed I almost bought TC5 today....till I saw you car :P LOL
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-01-2008, 07:55 PM   #5012
DaveW's Avatar
Lightbulb
Originally Posted by STLNLST View Post
what types of problems is he having? My only complaint about the car is super tight belts......other than that the car has been pretty good on the rug for me. The same set up I run on asphalt works on carpet. Just swap the spool for a oneway.
His issues seem to be durability for the most part. I just didnt know if it was a problem for others as well. I know frequent visits to the boards compound the issue, and i think i read there is already an arm update on the way... are there any other weak parts? Do the tight belts wear in? Sounds like it could be an issue for stock class?
DaveW is offline   Reply With Quote
Old 01-01-2008, 08:14 PM   #5013
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Nexus View Post
Kraig
Mine was still faster than yours today so just imagine the possibilities.
Dave, the arm discussion that we had will probably not help your friend. It was just a discussion about stronger/stiffer/less flexible arms. When these are run and you hit something you will just put the fracture point to another part of the suspension.
Robk mentioned something about using a TC3 or TC4 bumper pieces for added front protection. I can't remember which one or the specific's. Doing this might help your friend's situation.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-01-2008, 08:19 PM   #5014
Verndog's Avatar
Trader Rating: 16 (100%+)
the bearing size in the manual is wrong. I believ the size should be 6x10x3
I know they are 3mm, I was answering a question about updated alum. rear hubs and he asked if we would want to go to a 4mm wide bearing.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 01-01-2008, 08:20 PM   #5015
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Well the new kits come with the low friction belts that are a little looser. I haven't had any major durability issues. I've broke a C hub or two and one arm in 4 months. There are some build tips that help the car, like using 12mm or 14mm screws through the arm mount nut to prevent them from breaking. I also use Schumacher ball cups...but that's a personal preference. From my understanding the new arms are going to be stiffer for foam racing, not stronger. The car works really well for rubber. You can always get the ITF chassis for rubber racing, but many people have had success without it.
PitNamedGordie is offline   Reply With Quote
Old 01-01-2008, 08:27 PM   #5016
DaveW's Avatar
Thanks for the input guys! Im a fan of the Schuie cups myself. Do they fit on the stock turnbuckles w/o modification? Has anyone tried any XRay springs on the Tc5 shocks to see if they fit? I really like them on the Tc4... the XRay springs really transformed how it handled. About the front bumper... does P-Dub still make his nice a$$ bumpers??
Old 01-01-2008, 08:39 PM   #5017
STLNLST's Avatar
Trader Rating: 19 (100%+)
This is my take on the situation so others may disagree but I do feel that the tight belts are an issue in stock. I hear that there has been a running change to the belts now. The belts do wear in some but compared to every other belt car I have ever run the broken in belts still remain somewhat tight. While running mod it's not that big an issue due to the power of the mod motor but a stock motor doesn't have that power to make up for the drag in the drive train from the belts. Again this is just my opinion. I have run the car in modified (3.5) and 19turn (10.5) and stock (13.5) and have crashed in all classes and I still have the original set of arms that came with the car (bought it used) Accidents happen so I'm not going to say the car is bullet proof but it can handle a beating. I'm unaware of any arm update but that doesn't mean there isn't one. This is still the best buy for the money and it works so I wouldn't be to gun shy when it comes to buying one. The set up help on here is great too.
STLNLST is offline   Reply With Quote
Old 01-01-2008, 08:39 PM   #5018
STLNLST's Avatar
Old 01-01-2008, 08:39 PM   #5019
STLNLST's Avatar
Old 01-01-2008, 08:40 PM   #5020
STLNLST's Avatar
Old 01-01-2008, 09:20 PM   #5021
Yes they fit with no mods. P-Dub does make one for the TC5 but I haven't seen it yet.
Old 01-01-2008, 09:41 PM   #5022
Trader Rating: 27 (100%+)
Ok so I havent got my question verified yet, lol. are the shock pistons used in the tc5 the same for all the off road cars and everything? I seen a pic and they dont look different but I could be wrong
C_Money is offline   Reply With Quote
Old 01-01-2008, 09:47 PM   #5023
STLNLST's Avatar
yes they are. I bought my spares from the off road track. It comes with #1, 2, & 3 pistons.
Old 01-02-2008, 03:48 AM   #5024
WopArse's Avatar
Send a message via MSN to WopArse
Hi,
anyone had a problem with the shocks ?
One of them won't hold the oil, just keeps leaking,
I have trid with and without the foam spacers,
no burr's on shocks or bladders either.
I have had to put TC3 one's on.
WopArse is offline   Reply With Quote
Old 01-02-2008, 07:07 AM   #5025
Super Moderator
Kraig's Avatar
Where is it leaking top or bottom? If bottom then the o-ring is possbly torn. If it is the top then the blue nut should go all the way down to the flat part of the shock just before after the threads. Perhaps a picture of your shock would help.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
