Old 12-30-2007, 04:30 PM   #4951
STLNLST's Avatar
Trader Rating: 17 (100%+)
Rubber tire carpet set up.....I tweaked my ITF chassis so I went back to the stock chassis and top deck. Ran the Ryan C. Reedy race set up but took the spool out and ran a oneway. The car was dialed. I was 3/10 off of the fastest lap turned but I have a pretty good idea as to why. The car was easy to drive and could have used just a touch of on power steering but certain chages I made to get it caused the car to traction roll so back to the standard set up. I'm not set up guru but I can hold my ownbut if my boy Mo was there it would have been lights out. The bomber belt is something I'd like to try for the next time out as well. Body testing was also done and we stuck with the regular mazda 6. What conditions should the speed 6 be used for? I always seem to put it back on the shelf in favor for the standard mazda 6. Anyone local car for an unpainted speed 6???
STLNLST is offline   Reply With Quote
Old 12-30-2007, 05:19 PM   #4952
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
George, just racing against those guys is tough no matter what car they drive.
As for chassis thickness items. I am no graphite expert but there are different grades of graphite (I forget the correct name) sheets available. Each has their own set of properties and how they react. Perhaps Jason from BMI or Josh from CEFX can explain all of the differences because that is something that I have not looked into.
Personally I would like to see stronger (less flexible) suspension arms and caster blocks and even possibly rear hubs. If they accomplish that then I think the car would be killer on foams. Look at the last Cleveland race, they ran different pieces and were competitive with the $450 plus cars. Lap times were almost the same minus a few ticks of the clock. I haven't run foams for awhile now (because I can't afford to anymore) and in fact never have with the TC5 but I have seen Robk's car and Wallstreet's run and those changes wouldn't hurt.
This is just my opinion and I am very happy with my TC5 running rubber tire.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-30-2007, 05:54 PM   #4953
Super Moderator
Kraig's Avatar
STLNLST, why do you keep going back to the Mazda 6? What differences did you notice?
Old 12-30-2007, 06:42 PM   #4954
LOW ET's Avatar
Trader Rating: 91 (100%+)
how do you tweak a chassis? if it's tweaked can't you just adjust it out? now if you broke the chassis i can see going back to the original.
LOW ET is online now   Reply With Quote
Old 12-30-2007, 07:30 PM   #4955
robk's Avatar
Trader Rating: 22 (100%+)
I tend to go along with Kraig's thoughts on the chassis. I feel that stronger arms will help the car. I have made thin graphite plates to stiffen the arms, attached with CA glue. I think it makes quite a difference, along withTC4 caster blocks. At a race a couple months ago, I broke a TC4 block, was out of tc4 stuff, so I went back to stock parts. Just changing the caster block I lost steering. I understand the new stiffer parts will be produced, so that should be a great help.
Team Associated TC5-graphitearmtop.jpg   Team Associated TC5-graphitearmunder.jpg
Old 12-30-2007, 07:36 PM   #4956
Maybell's Avatar
51....you have pm...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 12-30-2007, 07:58 PM   #4957
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by C_Money View Post
is it a nessesity, to sand and ca the chassis? it looks like a ton of work and I dont want to mess it up
I guess it's optional, but I did and am glad. I didn't use CA, I used clear fingernail polish and it looks great and is holding up well after 5 months use. It's much easier to work with, and the brush makes application a breeze.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-30-2007, 09:45 PM   #4958
Trader Rating: 27 (100%+)
Ok so I have noticed ever since maybell said something to wall street people really havent been helping each other out, and well thats the main reason we are all here. Wall street has been kind enough to help me out a lot, and well I could use all the help I can get cause these cars are way different than the off road trucks im used to. So maybe maybell can be a little nicer next time dont you think.
C_Money is offline   Reply With Quote
Old 12-30-2007, 10:14 PM   #4959
STLNLST's Avatar
The car just seems a bit more stable for me and the lap times are more consistent with the regular Mazda 6. The rear end seems too wishy washy with the speed 6. It turns in hard (which isn't a bad thing) but the rear end breaks loose sometimes. Could be my driving sometimes but take that body off and I will know what the car will do 100 out of 100 times.
The chassis isn't broken but it is tweaked. I thought that with a double deck car you could just loosen the top deck and hold down the shock towers retighten the screws on the top deck and everything is fine. this wasn't the case. I did something to this chassis that it doesn't sit flat anymore. I stripped the car down to kit form and put the chassi on a flat surface and it has a slight rock to it. The stock chassis doesn't have this rock when placed on the same surface. Once asphalt season comes back around I'll put a new ITF chassis and top deck on the ride.
Old 12-30-2007, 10:17 PM   #4960
Maybell's Avatar
yup, I can be nicer...and I will....sorry about that....I get a little fired up about some things sometimes...but I think you got me all wrong...
Verndog...HELP!!!!
Old 12-30-2007, 11:38 PM   #4961
Verndog's Avatar
Well, I'll say this, Sean Maybell is one of the elite top racers in the Pacific Northwest. And he has helped a ton of people in our area get TC5's competing very quickly (along with about any car). He worked with me at the track and got my car dialed in about 1/2 hour, then went out a couple days later and put down a couple of the fastest laps 13.5 rubber (without ITF chassis mind you) has seen at SIR without ever driving my car prior (I asked him to run my car in race 3 to test ). I've gained over 1 lap+ (from 30-31 to 3 of 4 runs @ 32) in the 2 weeks since. My point is, I think that post just struck a chord with him (not giving credit for team wins IIRC), and he wanted people to post the correct facts when big event credit is due.
Anyway...I dont see less help going on, and if WallStreet has been around these forums long, I'm sure he'll be back to continue his work. Giving him a thanks now and then (as you just did), should far outweigh a little ribbing we all get now and then.
---Team Hoarders---
Old 12-30-2007, 11:41 PM   #4962
PutAwayWet's Avatar
You may have done what I did to my 415 recently. One of the front bulkhead screws pulled up through its countersunk hole a little bit and caused a small radius of delamination. It's hard to see by just looking at it, but if I sight down the bottom of the chassis just right, I can see a shadow around the hole. It rocks on that spot. It's a subtle break, but it's there. I'm not sure if there's a fix, it's pretty hard to fix graphite plate once it's delaminated.
Anyway, you're right, if the plates aren't broken and you haven't bent a bulkhead (check for that, too) then you should be able to loosen it up, put it on your setup board, tighten it up, and voila, straight car.
PutAwayWet is offline   Reply With Quote
Old 12-31-2007, 12:32 AM   #4963
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Lebatek View Post
Hey Wallstreet,
You can't tell from your photos, but are the Tamiya hex shims aluminum? Do you happen to have the part numbers for the .50mm and the 1.00mm? The ones I have been using for years are teflon...and have seen better days!
Thanks,
John
TAM53646 is what you're looking for. I'm fairly certain it comes with 4 1mm and 4 .5mm shims. They're aluminum and blue. :-)
http://www3.towerhobbies.com/cgi-bin...&I=LXFSD2&P=FR
syndr0me is offline   Reply With Quote
Old 12-31-2007, 12:48 AM   #4964
corallyman's Avatar
Trader Rating: 97 (100%+)
Carbon Fiber chassis are made from many layers of the carbon and also the resin. Its intirely possible that in a severe crash and even sometimes when it appears to not be a severe crash the layers have been damaged. Sometimes we all need to buy new chassis plates which is another reason why the TC5 is a very good deal.
Steve
P.S. This post wasn't really aimed at STLNLST as I am sure he knows this but aimed more at the newer racers reading this.
corallyman is offline   Reply With Quote
Old 12-31-2007, 12:52 AM   #4965
corallyman's Avatar
I also double what Verndog said, Sean is a well repected long time racer who is helping many people. Sometimes Internet talk is crappy because there is too much reading between the lines and not understanding jokes or actual intention.
I believe from the beginning this thread has been one of the better threads going and actually has far less "Bad" stuff in it.
Steve
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
