Old 12-27-2007, 10:14 AM   #4906
GeorgePravata's Avatar
Trader Rating: 106 (100%+)
reds front gold rears or golds front and red rears
TEAM ASSOCIATED,REEDY POWER, AKA, TQ WIRES, SILLYBOYZ PRODUCTS.
GeorgePravata is offline   Reply With Quote
Old 12-27-2007, 10:18 AM   #4907
gold-front/blue-rear or red-front/gold-rear
DOTMAN is offline   Reply With Quote
Old 12-27-2007, 10:32 AM   #4908
BIG DADDY8's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to BIG DADDY8
Originally Posted by DOTMAN View Post
I've been running my TC5 for a few months now and also started with the Bob S setup. Blue/silver may have been good at Tamiya, but the track I race on has very good traction. Blue/silver was WAAAY to soft. The car was very dumpy in turns and really bad in the ESs. I changed to gold/blue and it was much better. When bite is really high, Red/gold is dialed.
Down here we race on a parking lot asphalt surface. They resurfaced it a few months ago so we have med/high grip. It is a little bumpy in some spots. Where we race there very few cars that park there so we dont have to worry about oil and stuff like that. We use grape soda for track spray and it works great and lasts all day long on the track. I can't wait to race it for the start of the new season. Jan. 5th. Here is a video that one of the guys down here does from time to time. That way you guys can see what i'm talking about.
www.promofo-racing.org/Elec-TC-A-Main-428.html
BIG DADDY8 is offline   Reply With Quote
Old 12-27-2007, 10:39 AM   #4909
Our track is also asphalt with a few bumps and we use grape soda as well. I'd start with Gold/blue. I don't run sway bars either
Old 12-27-2007, 02:28 PM   #4910
LOW ET's Avatar
Trader Rating: 95 (100%+)
can some one shed some light on the foam things that go in the shock? when to use them and which one to use? i'm building my tc5 now for rubber tire on asphalt and i'm not sure if i need the foam or not. i'm following the ae set up sheet for brent thielke, http://www.teamassociated.com/racerh...yrace_2007.pdf
LOW ET is offline   Reply With Quote
Old 12-27-2007, 02:40 PM   #4911
Maybell's Avatar
for most rubber tire racing...the ticket is to run no foam at all(0-25% rebound)
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 12-27-2007, 02:50 PM   #4912
knoxvillerocco's Avatar
well its been a little while but im back into racing strong now, here is the q? As of now i running a little diffrent then out of the box but not by much Im running gold springs in the rear and copper up front, stock oil, pistons, foam inserts ect. If I run silver springs in the rear I should get more side bite with less high speed steering? I have a big sweeper at the local and if i stay into the throttle i get a slight push...So i changed them from blue to silver, it got worse so i went to golds and it helped?
Chris
my ride-XRAY FK05
Sponsors-Full Throttle Team Driver
Monro muffler/brake
local, but not so local track www.richfieldracers.com
knoxvillerocco is offline   Reply With Quote
Old 12-28-2007, 07:22 AM   #4913
LOW ET's Avatar
can someone explain hex spacing to me? my set up calls for 0.5mm on the front and 0 on the rear. i see the diagram on the ae setup sheet but where are they taking the measurement from? the face of the hex to where?
Old 12-28-2007, 07:29 AM   #4914
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Hex Spacing is a term used when adding a washer type spacer( shim) that is almost the same diameter of the hex itself. I know tamiya makes them as well as others company's. All you do is just put it on the axel before you put the tires on. It is a simple way of lengthening the front width of the car.
They come in different sizes. Basically a larger shim . I will post some pics so you can see what i am talking about.
wallstreet is offline   Reply With Quote
Old 12-28-2007, 09:06 AM   #4915
LOW ET's Avatar
Originally Posted by wallstreet View Post
Hex Spacing is a term used when adding a washer type spacer( shim) that is almost the same diameter of the hex itself. I know tamiya makes them as well as others companys. All you do is just put it on the axel before you put the tires on. It is a simple way of widing the front width of the car.
thanks!
Old 12-28-2007, 09:12 AM   #4916
wallstreet's Avatar
Here are the pictures. the shims i have are tamiya and come in .50mm and 1mm shims
Old 12-28-2007, 10:05 AM   #4917
Scottmisfits's Avatar
Hey guys, I was doing some experimenting with this car and was driving it really hard. My local shop has no TC5 parts yet and I snapped a C-Hub. I don't do mail order. I was wondering if anyone knew another c hub that might fit. Hot bodies, Corally? I've already tried X Ray. Maybe even TC4 parts might wok?
Thanks guys.
Scottmisfits is offline   Reply With Quote
Old 12-28-2007, 10:22 AM   #4918
wallstreet's Avatar
TC4 caster blocks would work best and there would just be minimal dremeling . And if memory serves best you might have to drill out the hole for the hidge pin cause they are different sizes. A fellow racer runs these on his car and i believe this is all he does to them.
He will prob be able to give you a how to later on today
Old 12-28-2007, 11:18 AM   #4919
Old 12-28-2007, 12:29 PM   #4920
Trader Rating: 27 (100%+)
I know I have ask this before but I never really got a good answer to make my choice. I am between the tc5 and the xray 08, What are some problems with these cars and how has each one been doing in big races? I am ordering a car tomorrow so i would like to know whats going on with both of these
C_Money is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
