Team Associated TC5
#4891
The low friction belts will be a running change in production. I'm not sure which belts the new kits come these days. The older belt says UK on it, the newer one is UG if I remember correctly.
Even the stiffer belts are fine after they have been run for a while. I know it might take a while to run them in with a stock motor though. On the positive side they will pretty much last forever.
So, a loose belt still will not free it up from my experiance, it's almost as if the gear pitch on the belt, is slightly different then pulley.
Will there be a different part number on the new belt...how will we know when to order??
#4894
I went and looked at my local hobby shop and all the replacement belts they had there were the UG belts so i just went ahead and got them for myself.
You can see right on the belt. So if you have to order from somewhere maybe order from a shop you can call and see if they can look on the belts for you
#4895
servo saver
i know this has been on here and asked before but to go through will take me all day. I'm having trouble with the servo saver staying together. has anyone tried trimming a little off of the spring to get the servo saver nut on farther? It seems that if you tighten it up it will not work very well and I don't want to hurt my servo. Any tricks will be appreciated and knowledge on the saver.
thanks, Neil
thanks, Neil
#4896
Neil are you going to be at "the track" or trackside anytime before the novak race i could probably help you out with this problem.
I have always had mine as tight as it gets and havent had a problem.
#4898
Ill see if i can stop up there on my way to trackside.
shouldnt be a problem though
#4900
thanks, Neil
thanks, Neil
http://www3.towerhobbies.com/cgi-bin...gh+servo+saver
I wasn't sure if my steering was gonna be responsive enough,but i have got fastest lap at my track.Those servo savers are used on 1/12 all the time.Try one,i don't think you will be disappointed.Mine has not come apart since i did this minor mod.
#4901
Super Moderator
My son busted his servo save assembly up this past weekend. Seems like the nut could not screw all the way on. I noticed what used to be a lip on it (nut) that would stop you from screwing it all the way onto the threads of the shaft. So I just got rid of that and now I have plenty of the threaded part after the nut. I hope that makes sense.
#4903
Got a TC5 for Christmas. Man it's a very nice looking car. I had only one issue when i was putting it together. Those Damn diffs were a pain in the a$$. Took a little work getting that tiny nut in that T-cup and getting it catch the bolt. I got it to work after about 30mins. I compressed the spring so many times it wasn't funny. I used BOB STELLFLUE set up at the reedy race for 19t(thats what we run here) and i cant wait to run it. The only thing i was wondering was the springs. Blue fronts and silver rears. To me i thought that was soft, but i'll try it and see what happens. I want to thank all you guys for the tons of info and help on here. I've been following this thread since it started. Anymore would be great since this is my first belt driven car. I've been running Associated for the last 7 years and love how they don't discontinue cars when they come out with a new one. Keep up the great work guys.
#4904
I also got my TC5 for christmas and man do I love this car everything went together well, and the belts weren't too tight..can't wait to race it this saturday
#4905
I've been running my TC5 for a few months now and also started with the Bob S setup. Blue/silver may have been good at Tamiya, but the track I race on has very good traction. Blue/silver was WAAAY to soft. The car was very dumpy in turns and really bad in the ESs. I changed to gold/blue and it was much better. When bite is really high, Red/gold is dialed.
