Old 12-14-2007, 02:18 PM   #4831
Suspended
Originally Posted by WingZero View Post
so i can use the regular chassis for asphalt and just concentrate on springs and setup??
you can start with cavs reedy set up, minus the antidive in front, with the stock chassis, an maybe take out a little rear toe should be good for the 13.5
i am cornholio is offline   Reply With Quote
Old 12-14-2007, 11:56 PM   #4832
Trader Rating: 27 (100%+)
Ok well I think I will be doing mainly carpet racing so I will try yhr small stuff first then the chassis. So a spool and one way and the spring set is the most important? Do I get both the spool and one way? and which goes in the front and which in the back? I am new to the touring car seen so please bear with me haha.
C_Money is offline   Reply With Quote
Old 12-15-2007, 07:28 AM   #4833
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
The spool and or one way should only be installed in front. I would suggest just getting the one way at first, as a spool will in most cases will cause more parts breakage if you are new and will be hitting stuff. Also even more important is the spring kit. Most guys running rubber tire are running the blue springs in front and silvers in the rear. rc10.com has alot of setups you might want to try on your car as it will give you a starting point setup that should work pretty good. Also if you are new to this, you should get a buds tc3 plastic bumper and install that on your car along with the regular kit bumper it will help cut down on breakage of the front end parts.
wallstreet is offline   Reply With Quote
Old 12-15-2007, 03:06 PM   #4834
Ok cool. Now I have been told my car will handle good without the new chassis but will have a little less grip in the rear. So Would it ok to get the car set up so I can drive it good and consistant then get the new chassis and the will work out the remaining bugs? Isnt the new chassis for rubber tires? or is it for pavement?
Old 12-15-2007, 04:22 PM   #4835
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by C_Money View Post
...Isnt the new chassis for rubber tires? or is it for pavement?
The ITF is for increased traction as pointed out. That could be asphalt or carpet but the most benefit is rubber on asphault, and rubber on low-med grip carpet. The stock chassis works fine on asphalt just run with 3 1/2 degs rear toe to start and work from there.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-15-2007, 07:49 PM   #4836
Ok so then will the stock chassis work for ruber tires on carpet if needed?
Also is there a tool that acuratly measures toe? besides a setup board and useing rpms camber gauge
Old 12-15-2007, 08:30 PM   #4837
Verndog's Avatar
You'd need a setup station to measure it but you dont need to measure it. The kit comes with 1.0 1.5 and 2.0 deg shims. Just use the 2.0 and 1.5 shims = 3.5 and it will be there. You prob. should pick up some slightly longer screws to be safe. The stock ones will get you by for a while.
---Team Hoarders---
Old 12-15-2007, 09:56 PM   #4838
bearings trying to find some good cheap bearings looked at avidrc but they did not have any 6x10x4 bearings anyone know where to find some
SHAUN GRIDER is offline   Reply With Quote
Old 12-15-2007, 09:59 PM   #4839
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
They are actually 6X10X3. There is a typo in the manuals. I buy my bearings from Avid also....
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-16-2007, 07:05 AM   #4840
Registered User
Default Ball Studs
What's the difference between the silver and black ball studs?
I see the most recent setup sheet call for silver studs on the rear outer holes.
Thanks!
Reznor88 is offline   Reply With Quote
Old 12-16-2007, 07:37 AM   #4841
Trader Rating: 16 (94%+)
Thanks!
The silver balls studs are taller. The "ball" part is about 1-2mm higher than the black ball studs, therefore minimizing the amount of shims needed.
KSN
kn7671 is offline   Reply With Quote
Old 12-16-2007, 08:43 AM   #4842
Old 12-16-2007, 09:06 AM   #4843
Alright sweet, I always thought you changed toe by adjusting the turnbuckle? am I wrong there or what?
Old 12-16-2007, 09:22 AM   #4844
Front toe you adjust with the turnbuckles. The rear is adjusted with shims.
Old 12-16-2007, 02:37 PM   #4845
Ok well also I thought for the rear you would change hubs? Now the shims are they the anti squat shims or where do these shims go?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
