Old 12-13-2007, 02:03 PM   #4816
Has anyone found a way to get this car to run well on asphalt with the stock chassis??
WingZero is offline   Reply With Quote
Old 12-13-2007, 02:26 PM   #4817
Ivan Dickson's Avatar
Trader Rating: 9 (91%+)
Questions??
Is the the TC5 a good car out the box?
SPECIAL THANKS TO ✦ MY WIFE ✦✦ GLOBAL PRIVATE FUNDING ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 12-13-2007, 02:39 PM   #4818
Send a message via MSN to TurboT
It's not just good, it's awesome! I switched from an RDX, and I had been fast with the RDX but I found it too brittle. Once I got the TC5, my confidence went up immensly. It is very nice to drive and I haven't found any phantom tweek issues yet.
I find that you can really feel the adjustments that you make to it, too. It reacts very nicely to tuning changes. And it is very well equipped right from the factory.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 12-13-2007, 02:40 PM   #4819
Suspended
what motor and 6 or 5 cells, also what degree of traction is the track you run on????
i am cornholio is offline   Reply With Quote
Old 12-13-2007, 02:56 PM   #4820
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Well I just got a LRP TC spec with the Vector 13.5. I run on a 74 x 40 carpet track with rubber tires. The info that came with the 13.5 said to gear at 7.5 on a small track and 5.5 on a large track. Anybody run this combo at a similar track? Just need a starting point. I have a 116t spur on there now.
Dasupacat1 is offline   Reply With Quote
Old 12-13-2007, 03:03 PM   #4821
I am going to try to run two cars one for mod 5.5 bl five cell and one for 13.5 bl six cell. Track is med to no grip asphalt (just blown off) on rubber or foams (running rubber).
Old 12-13-2007, 04:47 PM   #4822
Trader Rating: 27 (100%+)
Ok so I am between this car and the x ray. I will be doing a lot of club racing on carpet its similar to the track thats in the video above. Now do i need to get the new chassis for it when racing on carpet or will the stock one work fine? I will also be racing at competition hobbies in tuscon AZ on carpet so some please let me know.
C_Money is offline   Reply With Quote
Old 12-13-2007, 05:15 PM   #4823
Maybell's Avatar
the kit comes ready to go for foam/carpet racing....
for rubber tires....the top priority extras to think about would be the shock spring kit, the thinner chassis and topdeck(ITF), and a front spool and one-way...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 12-13-2007, 06:02 PM   #4824
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
For me the stock chassis and top plate worked just fine on the carpet with rubber tires. I would concentrate on springs, spool and one-way first before a chassis. Then maybe try a top deck and then the chassis but only if you feel like you need it.
Kraig is offline   Reply With Quote
Old 12-13-2007, 07:18 PM   #4825
t4mania's Avatar
whats the advantage of running a spool in the front on asphalt. Or would I be better off with a one-way.
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 12-13-2007, 07:37 PM   #4826
so i can use the regular chassis for asphalt and just concentrate on springs and setup??
Old 12-14-2007, 01:20 AM   #4827
stonedgti's Avatar
Trader Rating: 15 (100%+)
Hi Brandon, Yeah just a bit of bad luck, or we'd have another TC5 in the top 10. I actually built the car a couple of days before the IIC and it certainly proved to be a top competitor right out of the box. Plus with the added bonus of having you and the rest of the AE guys there to help. Best $330 I've spent on RC.
Hi BlueSilver, I don't warm up my tires for my particular track, I just calculate the time that I sauce the tires. I did try tire warmers once and it caused the tires to warm up too fast towards mid race and bogged down the car through corners.
I use the Futaba 9550 servo.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 12-14-2007, 01:25 AM   #4828
stonedgti's Avatar
Yes, just concentrate on the shocks and other set-ups first. Once you have a good baseline set up, than try the ITF chassis set.
Old 12-14-2007, 02:18 AM   #4829
Dasupacat1's Avatar
Old 12-14-2007, 07:41 AM   #4830
robk's Avatar
Trader Rating: 22 (100%+)
You need a smaller spur. We are rolling out 1.6" - 1.64" on foams with the novak if that helps. You should need a bigger pinion with the LRP due to the larger rotor.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
