Old 12-09-2007, 10:12 PM   #4786
gixxerman's Avatar
Originally Posted by twistedone View Post
itf top deck is more movement loosens up car for asphalt and rubber tire running
stiif for foam
loser for rubber
is what I was explained
Originally Posted by Maybell View Post
the ITF topdeck creates more chassis flex and therefore more grip....often popular for rubber-tire racing...if you add the o-ring trick that increases that effect..
Thank you!!!!!!!! New to the TC scene, and trying to learn all I can!!!
gixxerman is offline   Reply With Quote
Old 12-10-2007, 03:03 AM   #4787
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Originally Posted by Dasupacat1 View Post
Is there a part# for these orings or are they the std. shock orings? I got my car used so they were missing. The shock orings seem too big and bind up the oneway a bit not letting it freewheel like it should.
Anyone?
Dasupacat1 is offline   Reply With Quote
Old 12-10-2007, 06:29 AM   #4788
beavis353's Avatar
You can use the small blue foams that are provided as options for the shock bladders. I think these might work a bit better, because they break in after a few runs. Otherwise you can use the red o-rings for the shocks. They should also break in after a few runs.
Good luck.
beavis353 is offline   Reply With Quote
Old 12-10-2007, 11:09 AM   #4789
emulberry's Avatar
+1 I do the same thing
www.NobodyLikesOnions.com
Check it out, edgy, hilarious internet radio, FOR FREE
Associated: TC5 FT w/GTB/13.5
Xray: T1 FK05 w/GT7, CO27
Tamiya: F103GT w/ Cyclone 2
HPI: RS4 PRO 2 (semi-retired)
CEN: Matrix 1/8 scale buggy
S&N Trackside RC
emulberry is offline   Reply With Quote
Old 12-10-2007, 11:19 AM   #4790
Delyt's Avatar
Trader Rating: 16 (100%+)
edit... found my answer
Delyt is offline   Reply With Quote
Old 12-10-2007, 01:12 PM   #4791
SoCalMitch's Avatar
Default oil
Is there a difference in oil weight between the older smaller shock oil bottles and the newer taller bottles. Wanted to check what I heard at the track.
SoCalMitch is offline   Reply With Quote
Old 12-10-2007, 01:14 PM   #4792
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
I believe there is
I wanted to go up in oil weight at the track sat night and i pulled out an 80wt bottle ( new design ) and the oil looked like it was 60 wt. So i ended up not making the switch and a buddy brought 80 wt ( older bottle ) and it was alot thicker than the 80 i had
wallstreet is offline   Reply With Quote
Old 12-10-2007, 03:27 PM   #4793
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Don't even use the orings in the oneway, it binds up the front end during suspension travel. Doesn't hurt anything not to use them, they won't bottom out.
Brandon Melton is offline   Reply With Quote
Old 12-11-2007, 10:41 AM   #4794
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
Would someone explain the difference between the ITF chassis and the standard kit chassis?
loopedout is offline   Reply With Quote
Old 12-11-2007, 11:55 AM   #4795
they look the same but the ITF is 2mm instead of 2.5mm. The top deck in the ITF is cut down the middle.
Old 12-11-2007, 01:40 PM   #4796
what is the functional difference, just allows more flex?
Old 12-11-2007, 01:55 PM   #4797
PutAwayWet's Avatar
Since the ITF question is in the air, does anyone know whether we can expect an ITF rubber tire kit soon ? The cheaper TC5 thing sort of evaporates with the purchase of decks and one-ways/spools. With the '008 out, the TRF416 coming, and a very interesting Serpent to consider, it would be a shame to see AE surrender the "value" initiative on the rubber tire side.
PutAwayWet is offline   Reply With Quote
Old 12-11-2007, 02:02 PM   #4798
wallstreet's Avatar
there is still alot of value in the tc5
Parts cost is amazing . even though you may have to get the rubber tire stuff... the cost is far less than any other company.
Old 12-11-2007, 03:35 PM   #4799
robk's Avatar
Trader Rating: 22 (100%+)
AE TC5 $348.95 @ Stormer
ITF chassis 39.95
One way 44.99
total 433.89
Corally phi EU kit 479.99
Andy Moore Cyclone 449.95
Above prices from Stormer
Tamiya TRF416 $439.99
Xray T2 008 EU-Rubber Spec 6-cell Competition TC $449.99
above from speedtech rc
The TC5 is still cheaper than all those cars, and you don't have to shell out the dough all at once. Not to mention parts are available anywhere (name a shop that can't get AE within 2 days in the US). Also, I am doubting the TC5 will be replaced next year....
I realize that they could do a kit for rubber, but I'm just pointing out the car is still a deal.
Old 12-11-2007, 04:01 PM   #4800
RCpurplecow's Avatar
if you do spend the extra money on itf parts, then you have a great setup for both carpet and asphalt
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
