Old 12-08-2007, 07:50 AM   #4771
LOW ET's Avatar
Trader Rating: 96 (100%+)
can someone suggest a setup for my tc5 ft? the car will never see competition it's just for fun on an asphalt street. it has a mamba max 5700 and 3 cell lipo. i would like the car to handle like a competition race car. should i run foam or rubber? and why? suggestions on gearing, but i would like to stick with the 48 pitch gears.
LOW ET is offline   Reply With Quote
Old 12-08-2007, 09:23 AM   #4772
ooliganRC's Avatar
Send a message via MSN to ooliganRC
just run the kit set up if your just gonna do that.
secondly...
I have my TC5 for sale with lots of spares and hop ups.
will send from UK worldwide, accept paypal......150 or $300 +postage.. pm me
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 12-08-2007, 06:16 PM   #4773
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Does anybody use an o-ring in between the oneway outdrives and bones? It seems that whenever the front end "free wheels" The outdrives move out and away from the oneway bearings. This can't be normal?
Dasupacat1 is offline   Reply With Quote
Old 12-08-2007, 06:41 PM   #4774
There are two o-rings just like the ones in your shocks.They go in the out-drives before you put in the dog-bone/cvd.It acts as a cushion also.
TC5-TC4-KSG-Tekin-Novak-3PK-Hitec-PRS-Gears-John's BSR-Racing-Tires Tri-State Raceway In Hamilton ,Ohio-Much More-Spektrum Associated-Team Magic-APS-SMC Competition Electronics-Ice.
8up-Club Dayton,Ohio
108% Certified 8up
8up-racing is offline   Reply With Quote
Old 12-08-2007, 07:23 PM   #4775
what is everyone gearing the 13.5 sintered rotor motors at i am at a 4.1 and i am running on carpet i still get beat down the straightaway i am geared 48 pitch with 72 spur and a 35 pinion thinking of going to a 36 pinion that will make my final drive a 4 any suggestions
SHAUN GRIDER is offline   Reply With Quote
Old 12-08-2007, 07:56 PM   #4776
Verndog's Avatar
Trader Rating: 16 (100%+)
Are you talking about an LRP 13.5 sintered? If so, I think your quite a bit too high, your temps must be running high also. Once you get to 180 degs., expect performance to drop, I'm at 5.03 right now (31/78) and keep up with all the Novaks I've come across, temps 150-155 in 8 mins. You may want to compare the batteries that are beating you also IMO.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-08-2007, 08:10 PM   #4777
it is the novak motor and the temps are between 118 and 125
Old 12-08-2007, 10:09 PM   #4778
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
you are temping that low at 4.1?!?! im impressed... I'm at 4.7 on carpet and temps are in the 150 range. I've got about as much speed on the straights as anyone else. Maybe the timing ring is in the wrong position? that really the only thing I can think of.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 12-08-2007, 10:57 PM   #4779
yeah it is temping 118 on the in the middle of the motor and 125 on the end
drive train is very good will be better when i get some avid bearings from avidrc.com
Old 12-09-2007, 06:12 AM   #4780
Dasupacat1's Avatar
Is there a part# for these orings or are they the std. shock orings? I got my car used so they were missing. The shock orings seem too big and bind up the oneway a bit not letting it freewheel like it should.
Old 12-09-2007, 09:08 AM   #4781
Dasupacat1's Avatar
What kind of difference will having toe-in on the hub have rather than having it all in the arm mounts?
Old 12-09-2007, 03:54 PM   #4782
mainracer's Avatar
Send a message via AIM to mainracer
Dasupacat1 - Having your rear toe on the Hub will generaly give you more steering in the middle of the turn. It is more suitable with foam tires while having all your rear toe inboard won't give as much rotation in the middle of the turn and should be better with rubber tires
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 12-09-2007, 03:57 PM   #4783
gixxerman's Avatar
Originally Posted by gixxerman View Post
Just got a one- way for the front of the TC-5. I know it's problaby in here somewhere, I just don't feel like looking through all the pages of posts, ok here's the question, where do the included o-rings go that come with the one-way kit? And what is the difference between the top plate that comes with the kit and a ITF top plate? We run rubber tired 13.5 with lipo on carpet and I noticed that the set-ups on Associated web site for rubber tired carpet call for the ITF top plate. Thank you (in advance) for the help!!!
Ok I now know where the o-rings go, but could someone please explain the itf top plate??????
gixxerman is offline   Reply With Quote
Old 12-09-2007, 04:02 PM   #4784
Trader Rating: 139 (97%+)
Send a message via AIM to twistedone
itf top deck is more movement loosens up car for asphalt and rubber tire running
stiif for foam
loser for rubber
is what I was explained
twistedone is offline   Reply With Quote
Old 12-09-2007, 04:16 PM   #4785
Maybell's Avatar
the ITF topdeck creates more chassis flex and therefore more grip....often popular for rubber-tire racing...if you add the o-ring trick that increases that effect..
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
