Old 12-05-2007, 08:43 PM   #4756
Driftmon's Avatar
I tried to do a quick search through this massive thread, but I couldn't find it, so I'm sorry if it's been asked before, but does anyone know what size the screws are for the spool kit?
Driftmon is offline   Reply With Quote
Old 12-06-2007, 07:23 PM   #4757
emulberry's Avatar
Hey guys I just got done building my new TC5 and got a little track time with it but I have the problem of the back end being loose on power. my current setup is this
shock weight is 40w all around
associated blue in front and silver in back
2nd from top shock position all around
0deg camber in front, -1.5deg in back
0 toe in front
#3 roll centers all around
one way in front
Novak GTB/13.5
RP-30 tires on carpet
sauce full rear and small strip on front
any input on what I might change to get more on-power traction in the rear
thanks
emulberry
www.NobodyLikesOnions.com
Check it out, edgy, hilarious internet radio, FOR FREE
Associated: TC5 FT w/GTB/13.5
Xray: T1 FK05 w/GT7, CO27
Tamiya: F103GT w/ Cyclone 2
HPI: RS4 PRO 2 (semi-retired)
CEN: Matrix 1/8 scale buggy
S&N Trackside RC
emulberry is offline   Reply With Quote
Old 12-06-2007, 07:31 PM   #4758
DRAG_ON's Avatar
0 toe in front
one way in front
Novak GTB/13.5
thanks
emulberry
decreased your droop.........rear is lower than front..........give it a try using droop gauge given by associated TC4........ front 4 ,rear 3 or 2 .......... you got so much traction using one way in front..........with TC4 i'm using 40wt losi front with red associated spring and rear associated silver spring, 30 wt losi...., camber: -1 deg front and -2 rear camber rear toe block 2.5 deg ............
also dont forget to lube your rear ball diff and take care of the diff plate so there is no over tighten that can damage the diff plate........
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 12-06-2007, 07:48 PM   #4759
emulberry's Avatar
what is the 2.5 deg rear toe block are those the three different size parts one with one dot one with 2 dots and one with 3 dots? sorry for my ignorance but the manual was lacking in info about that
thanks
emulberry
S&N Trackside RC
Old 12-06-2007, 07:56 PM   #4760
DRAG_ON's Avatar
thanks
emulberry
i'm sorry i was talking about rear toe block on TC4......i dont owned TC5........but i got similar problems like you losing rear grip
Old 12-06-2007, 08:03 PM   #4761
Verndog's Avatar
Trader Rating: 16 (100%+)
Rear toe is achieved thru the double ended shims that have a C on one end and a hole thru the other. 2.5 degs is the thinnest shim and the medium shim together, behind the rear end mount blocks your talking about.
Shims are 1 deg.-- 1.5 degs.-- and 2 degs.
The dots on those blocks indicate the mount height of your arms. Read the last page on your manual, it shows all these things.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-06-2007, 08:09 PM   #4762
emulberry's Avatar
thanks for the info, which part (with the dots )should I use, the 1,2,or 3 dot?
thanks
emulberry
S&N Trackside RC
Old 12-06-2007, 08:16 PM   #4763
gixxerman's Avatar
Just got a one- way for the front of the TC-5. I know it's problaby in here somewhere, I just don't feel like looking through all the pages of posts, ok here's the question, where do the included o-rings go that come with the one-way kit? And what is the difference between the top plate that comes with the kit and a ITF top plate? We run rubber tired 13.5 with lipo on carpet and I noticed that the set-ups on Associated web site for rubber tired carpet call for the ITF top plate. Thank you (in advance) for the help!!!
gixxerman is offline   Reply With Quote
Old 12-06-2007, 09:01 PM   #4764
Verndog's Avatar
thanks
emulberry
You should be running 2A front and 3A rear. Again, refer to the last page setup sheet for arm mount A and B hole location. There are 2 different holes thru the bulkheads the screws can go thru.
Download the setup sheet in this post TC5 setup 13.5 BL rubber--carpet and use it to start. It will get you close.
I'm running that except no ITF chassis and 4 deg castor blocks...close everywhere else.
---Team Hoarders---
Old 12-06-2007, 10:04 PM   #4765
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default Arms
Any word on stiffer arms being released for the car.
Just hoping something eventually comes out.
If not does another brands arms fit?
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 12-07-2007, 05:54 AM   #4766
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by olhipster1 View Post
Any word on stiffer arms being release for the car.
At first they said you didnt need them.....now they ran them at Cleveland....so who knows.....good luck with that.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-07-2007, 05:56 AM   #4767
olhipster1's Avatar
hopefully they will release something..
the car definitely needs them a bit too much flex in suspension for foam carpet.
CAUSE and EFFECT
Old 12-07-2007, 08:44 PM   #4768
emulberry's Avatar
thanks verndog, I downloaded that setup and will try it next week.
emulberry
S&N Trackside RC
Old 12-08-2007, 03:19 AM   #4769
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Hmmm. Is there a team driver out there that can confirm this?
Dasupacat1 is offline   Reply With Quote
Old 12-08-2007, 05:52 AM   #4770
STLNLST's Avatar
Trader Rating: 19 (100%+)
For our carpet track (Stockton, Ca) Ryan C. asphalt set up works pretty well with a oneway installed. The only changes made so far were going to blue springs in the front (as the bite is coming up I may go back to gold today) and laying the rear shocks down one hole and droop is 2mm front and 3mm rear above ride height. Other than that I have a pretty good car. It's starting to push some in the corners and I think that might be due to the front springs being a little soft. For practice this morning I will try the golds again and then make droop adjustments. It's nice to know that a dialed asphalt set up works indoors as well. Just take out my spool and throw in a oneway. The high bite carpet set up's from the AE team guys don't really work too well out here. We have med bite at best on carpet for weekly club races. This was run in stock and 19 turn. This weekend is our little two day carpet race so I will get a ton of track time and with me running lipo practice wastimes were looooooooooooooooooooong yesterday
STLNLST is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
