Old 12-03-2007, 04:38 AM   #4726
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Anybody ever have a problem with their subc batts coming out during a race. I had 2 bad crashes and in both casees the batts came out somehow. Both times the thumb screws were still very snug.
Dasupacat1 is offline   Reply With Quote
Old 12-03-2007, 04:46 AM   #4727
Trader Rating: 16 (94%+)
Originally Posted by PitNamedGordie View Post
I have seen some factory guys running about .5 mm more ride height in the rear of their cars. What benefit does this have?
Helps to improve rear traction during cornering. You should also try running about 1mm more rear droop if rear traction is an issue during cornering.
KSN
kn7671 is offline   Reply With Quote
Old 12-03-2007, 05:01 AM   #4728
When I had my TC5 I had the same problem. Be sure you have filed/sanded the chassis battery slots far enough to allow the Sub-C's to sit flat and level to the bottom of the chassis. The plastic retainers in the middle of the pack on the chassis are not tall enough to compensate if you have not filed the battery slots far enough.
KSN
Old 12-03-2007, 05:18 AM   #4729
Trader Rating: 68 (100%+)
At the same time be carefeul how much you run too much the car will drive drive like a school bus,will also effect off throttle steering as well
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-03-2007, 06:52 AM   #4730
dbmartin's Avatar
Originally Posted by fatbear View Post
Does anyone have an answer to this????
I asked this question long ago and was told that I had to buy the entire diff rebuild kit. I have tried to find the nut w/o success on my own.
It would be nice to know the answer
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 12-03-2007, 09:13 AM   #4731
SoCalMitch's Avatar
If anyone tried to use the Serpent TC gear diff let us know if it can be made to fit the TC5.
SoCalMitch is offline   Reply With Quote
Old 12-03-2007, 10:18 AM   #4732
Hi all.
Do the FT TC4 HD CVDs fit the TC5?
phresko is offline   Reply With Quote
Old 12-03-2007, 10:36 AM   #4733
Originally Posted by phresko View Post
Hi all.
No the tc4 stub axle is standard bearing and the tc5 is metric
SpeedZone Batteries
Old 12-03-2007, 10:53 AM   #4734
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
If I am going to be running brushless 13.5, what is the smallest spur I should use? I have a 64 pitch 96t, 100t and 104t, but even the 104t seems a bit small. I have pinions 38-44t. I do not have my motor yet to check for mesh...
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 12-03-2007, 10:58 AM   #4735
If you are running Foams, you will need the 96-Spur and 44-Pinion to get a 4.36 FDR. The trans ratio of the TC5 is 2.0:1.
KSN
Old 12-03-2007, 11:20 AM   #4736
I will be running rubber. So the 96t spur and 44t pinion should mesh up in the TC5? I planned on having the right gears to go from 4.5 to 5.5 for now.
Old 12-03-2007, 11:31 AM   #4737
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Not sure you'll get to 5.5 with the 96 tooth spur. But I use a 96 tooth spur and 41 tooth pinion and it meshes fine.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-03-2007, 11:47 AM   #4738
Good, then all of my pinions and spurs should work. (38-44t and 96t, 100t, and 104t.) Awesome thanks guys!
Old 12-03-2007, 11:50 AM   #4739
Verndog's Avatar
Trader Rating: 16 (100%+)
You can buy the nut sepperatly, I have the part number at home, comes in a pack of 4...I'll post later today. However to have to buy the diff nut plastic retainer from the stock outdrive kit for $5.00. Another option is to try to press the old nut out of your retainer and the new nut in.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-03-2007, 01:24 PM   #4740
fatbear's Avatar
Send a message via Yahoo to fatbear
opps, double post.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
