Old 11-30-2007, 09:16 AM   #4711
beavis353's Avatar
Originally Posted by 51 View Post
I've had a few requests for alternate setups for rubber tires on carpet. Craig and Juho went testing prior to the IIC and for Craig, Juho's setup was a bit to aggressive. This is what he showed up with at the IIC and I tested it with him and felt really confident driving rubber tires on carpet for the first time.
I tried a few things, but kept coming back to this. Give it a try and see what you think.
Thanks for the additional setup to try. Would you recomend any changes for 6 cell stock?
beavis353 is offline   Reply With Quote
Old 11-30-2007, 11:49 AM   #4712
51
51's Avatar
I think I'd just rock it...give it a try and see how it goes.
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 11-30-2007, 12:09 PM   #4713
51
51's Avatar
Originally Posted by JuhoL View Post
There's a small mistake in the setup sheet. I ran 3A blocks in the rear and 2A blocks in the front. The sheet says I had antisquat in the back but I didnt. 51 has just mistyped it
Okay, I've adjusted the setup. Sorry for the confusion.
Old 11-30-2007, 12:18 PM   #4714
Trader Rating: 19 (100%+)
I'm in the process of rebuilding my shocks. What is the best way to take out the black plastic piece that goes inside the shock body without doing any damage to it.
Also can anyone give me a part # for the shock rebuild kit.
zake540 is offline   Reply With Quote
Old 11-30-2007, 12:49 PM   #4715
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
31120
http://www3.towerhobbies.com/cgi-bin...?&I=LXMUP1&P=M
or this one is a upgrade
31123
http://www3.towerhobbies.com/cgi-bin...?&I=LXLTX9&P=M
Old 11-30-2007, 06:22 PM   #4716
fatbear's Avatar
Send a message via Yahoo to fatbear
Default FT Diff Nut
Can you buy the FT diff nut seperately? Mine stripped out while I was building it. If so what is the part #?
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
AKA www.raceaka.com
Ryper Hobbies www.ryperhobbies.com.au
fatbear is offline   Reply With Quote
Old 11-30-2007, 06:37 PM   #4717
emulberry's Avatar
hey all, I just got done building my new TC5. I have one problem. I was told to run a 69 spur and 28 pinion with my 13.5 brushless. I tried to put the motor in and I can't get the motor close enough to the spur there is about a 2mm gap at its closest, is there something that I am missing or what other gear numbers should I use? sorry if this has been talked about earlier in this thread.
www.NobodyLikesOnions.com
Check it out, edgy, hilarious internet radio, FOR FREE
Associated: TC5 FT w/GTB/13.5
Xray: T1 FK05 w/GT7, CO27
Tamiya: F103GT w/ Cyclone 2
HPI: RS4 PRO 2 (semi-retired)
CEN: Matrix 1/8 scale buggy
S&N Trackside RC
emulberry is offline   Reply With Quote
Old 11-30-2007, 06:45 PM   #4718
Trader Rating: 64 (100%+)
If you want to run 64p i have seen guys with rubber tire running anywhere from 42-44 pinion 108 spur
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-01-2007, 11:43 AM   #4719
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
I just picked up a LRP 13.5. Can someone give me a starting point on gearing for rubber tires? My local carpet track is about 40w x 75l. Any help would be great.
Dasupacat1 is offline   Reply With Quote
Old 12-02-2007, 06:12 PM   #4720
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I have seen some factory guys running about .5 mm more ride height in the rear of their cars. What benefit does this have?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-02-2007, 06:55 PM   #4721
5-5.5 fdr would be a good starting point our track is just about the same size.
SpeedZone Batteries
Old 12-02-2007, 07:28 PM   #4722
DRAG_ON's Avatar
does the steel outdrive and 1 way for TC5 Out yet???
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 12-02-2007, 07:30 PM   #4723
Verndog's Avatar
Trader Rating: 16 (100%+)
Im running 5.02 right now under similar conditions. I highly recommend the sintered rotor to keep temps down though. It will drop you close to 10 degs. If your running bonded rotor then prob. want 5.2 to 5.5 range.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 12-02-2007, 09:02 PM   #4724
The 1 way is available,ck out www.losipartshouse.com
SpeedZone Batteries
Old 12-03-2007, 12:34 AM   #4725
fatbear's Avatar
Does anyone have an answer to this????
AKA www.raceaka.com
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
