Old 11-29-2007, 11:22 AM   #4696
fatbear's Avatar
Send a message via Yahoo to fatbear
Originally Posted by JuhoL View Post
It's posted on the previous page. I ran the same car in 19T and mod without any changes. Bob Stellflue also ran almost the same setup in stock.
Juho, were you running any aluminium caster blocks, hubs etc? Or maybe some strengthened arms?
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 11-29-2007, 11:50 AM   #4697
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
Juho, also where you have that you ran 1 deg rear hub carriers with 2 degree rear toe per side. What shim does it take to get the other 1 deg. I would like to have my rear track width and toe the same, becouse it is where I am having the most difficulty tuning.
Also is there any mods needed to fit the losi pistons in the stock shock bodies? Also I take it that there is no foams in the shocks as well?
Thanks for the help
bigemike is offline   Reply With Quote
Old 11-29-2007, 02:49 PM   #4698
Originally Posted by Brandon Melton View Post
I just went back to look at that post to see which one it was. Based on just what you have described, try the 2 deg castor blocks and that should be real close to what you are wanting.
As far as the droop, you may not be able to run anymore droop, I think at that setting the spring was just barely touching the preload collar. You don't want the arm to droop far enough that there's a gap bewteen spring and collar.
Actually I have tried using less castor by going from 6* to 4* and the change was too drastic. I was having WAY too much push mid corner and trying to exit the corner. Would you have any other suggestions?
I'm running on a VERY tight high traction carpet track and most of the turns are U turns if that matters any.
naggalowmo is offline   Reply With Quote
Old 11-29-2007, 04:48 PM   #4699
corallyman's Avatar
Trader Rating: 98 (100%+)
Naggalowmo,
You could try a little front toe out, This can help turn in on entry.
Steve
corallyman is offline   Reply With Quote
Old 11-29-2007, 09:12 PM   #4700
Tim W.'s Avatar
I just finished building my new TC5, and will race it for the first time this saturday. My belts are kind of tight even when set in the loose setting. Is this normal?
Mugen Seiki, Werks Racing USA, Upgrade, AKA, Avid
Tim W. is offline   Reply With Quote
Old 11-29-2007, 09:43 PM   #4701
51
51's Avatar
Yes this is normal. Give it a few packs and it should free up quite a bit.
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 11-29-2007, 09:45 PM   #4702
51
51's Avatar
Thanks for the help
If I remember right, Juho used a 1* shim on the front arm mount of the rear arm and 2x1* in the rear arm mount of the rear arm. It sounds confusing, but think about it and it makes one degree total inboard toe with the track width spaced out.
Nope, no mods for the Losi pistons. Just make sure you get their "old" pistons...or the electric offroad pistons.
Old 11-29-2007, 09:45 PM   #4703
51
51's Avatar
As far as I know, no one used aluminum caster blocks.
Old 11-29-2007, 09:49 PM   #4704
bigemike's Avatar
what would you reccomend with the stock pistons, are they close, or are the losi's a must have?
Old 11-29-2007, 09:58 PM   #4705
51
51's Avatar
No, they are not a must. #2 pistons are close to the feel of #56 and #3 are close to the feel of #57.
Old 11-29-2007, 10:01 PM   #4706
51
51's Avatar
Default IIC Rubber Tire Setup
I've had a few requests for alternate setups for rubber tires on carpet. Craig and Juho went testing prior to the IIC and for Craig, Juho's setup was a bit to aggressive. This is what he showed up with at the IIC and I tested it with him and felt really confident driving rubber tires on carpet for the first time.
I tried a few things, but kept coming back to this. Give it a try and see what you think.
File Type: pdf TC5_2007_IIC_Drescher_Thielke_Rubber.pdf (413.6 KB, 194 views)
Old 11-29-2007, 10:21 PM   #4707
Suspended
if you are running stock or 19 turn you can cut every other tooth of the belts..there are a few of us in AZ doing this..helps free up drivetrain quite a bit..i dont know how it would hold up in mod though
i am cornholio is offline   Reply With Quote
Old 11-29-2007, 10:53 PM   #4708
Just change the front belt to the BD one, it help to free up the drive train a lot.
G2B Anthony is offline   Reply With Quote
Old 11-29-2007, 11:19 PM   #4709
sammy sakers's Avatar
sammy saks
brooklyn hobbies
sammy sakers is offline   Reply With Quote
Old 11-29-2007, 11:48 PM   #4710
JuhoL's Avatar
There's a small mistake in the setup sheet. I ran 3A blocks in the rear and 2A blocks in the front. The sheet says I had antisquat in the back but I didnt. 51 has just mistyped it
Right where it says which blocks I used it says the shims I had under them, which were 2-2-2-4(straight pins in front and 2 deg of toe in the back). In addition I had the 1deg rear hubs. I hope this clears it out?
About the belts: I'm not absolutely sure about this but I think the low friction belts will be included in the kits as a running change. You can tell which ones you have by reading the text on them. If they say UK they are the tighter ones and if they say UG they are the looser ones. Even the UK ones are fine after you run the for a few packs, I put new UK ones in my car at Cleveland and had no problems running them in 19T.
Associated/Reedy/LRP/Muchmore/Sanwa/Protoform/Jaco/Xenon/Parma
JuhoL is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
