Old 11-28-2007, 06:32 PM   #4681
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Share your setup and everyone on here can help.
Let us know if you are pushing going into, middle, or out of the corner. Depending on where the car is pushing will help figure out which end of the car to make changes to.
Kraig is offline   Reply With Quote
Old 11-28-2007, 08:03 PM   #4682
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Maybell View Post
Kevin, these are foam-carpet setups that Brent just posted....rubber setups are totally different, even if you are running on carpet...
Woops...my bad...just noticed that Sean, thank you. I'm not about to make any drastic changes at this point anyway. As far as the change from one way back to diff., I still like my diff better on rubber / carpet, but then again I'm pretty damn green compared to pro's like you!..
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 11-28-2007, 08:54 PM   #4683
I'm using the setup that Brandon posted in this thread post #4274 on page 143.
I'm pushing going into the corner. I have to slow down A LOT to be able to make the turn. Middle and out of the corner has plenty of steering and i can accel out pretty easily. If i could go into the corner faster i think i can lower my times.
naggalowmo is offline   Reply With Quote
Old 11-28-2007, 08:58 PM   #4684
Super Moderator
Kraig's Avatar
My fault, I will have to go search for that and let you know but I am sure others will chime in to help.
Old 11-28-2007, 09:12 PM   #4685
Verndog's Avatar
I'm not far from that setup now except I went back to diff, and have stock chassis. I had similar push issues also. First the front camber at 1.5 is an error. It's suppose to be -1.5 (I PMed and asked). You might go with a little - front toe...thats listed at +.5, plus I added a bit more rear droop, and thats all mine needed.
Are you running the 6 deg. castors also?? I'm running 4.
Here is a shortcut to his setup for others to help.
---Team Hoarders---
Old 11-28-2007, 09:58 PM   #4686
robk's Avatar
Trader Rating: 22 (100%+)
More rear droop travel (like from 5 to 6)- you'll get more transfer to the front
Kick up in the front- more weight transfer off power, and additional caster into the front end.
Old 11-28-2007, 10:02 PM   #4687
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Robk up this late ?
Brent just a reminder about the vegas setups for the rubber tire ... maybe juho and mathias larson please
wallstreet is offline   Reply With Quote
Old 11-28-2007, 10:27 PM   #4688
IMO, TC5 seems easy oversteering than understeering with 5cell.
G2B Anthony is offline   Reply With Quote
Old 11-29-2007, 12:30 AM   #4689
I forgot to add that I'm only running the ITF deck but not the chassis. Yes I'm running 6* castor blocks but I will try and add a bit more droop as you guys suggested. Thanks for the help!
Old 11-29-2007, 04:07 AM   #4690
JuhoL's Avatar
I'm not sure what Mathias ran but my setup was 100% same as the LRP race setup.
Associated/Reedy/LRP/Muchmore/Sanwa/Protoform/Jaco/Xenon/Parma
JuhoL is offline   Reply With Quote
Old 11-29-2007, 06:27 AM   #4691
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
I just went back to look at that post to see which one it was. Based on just what you have described, try the 2 deg castor blocks and that should be real close to what you are wanting.
As far as the droop, you may not be able to run anymore droop, I think at that setting the spring was just barely touching the preload collar. You don't want the arm to droop far enough that there's a gap bewteen spring and collar.
Brandon Melton is offline   Reply With Quote
Old 11-29-2007, 06:50 AM   #4692
HappyHippo's Avatar
I'm building my 3rd tc5 now and this is the funny stuff about it
It's missing som parts and I have moore of some others, like bearing cap, shock bushing, and rear shock tower
the parts that are missing is servo saver spring, arm mount nut
Any one else who has the same experience?
HappyHippo is offline   Reply With Quote
Old 11-29-2007, 08:11 AM   #4693
Thumbs up
Originally Posted by mainracer View Post
Kropy- Thank you. It was a very good week end. The car ran really good ! I am looking foward to next races.
Tony6187- Changing the diff height can change the way your car handle drasticaly. Moving both at the same time let say from middle high to middle low won't be as big of a change compared to moving one at a time. having a front diff higher than a rear diff will give your car more steering and vice versa.
I never run my diff higher than mid high. I like to run my diff low as it usualy makes my car easier to drive.
CHEERS KEVEN
tony6187 is offline   Reply With Quote
Old 11-29-2007, 08:40 AM   #4694
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
Juho can you send me your Cleveland 19turn setup?
bigemike is offline   Reply With Quote
Old 11-29-2007, 10:42 AM   #4695
JuhoL's Avatar
It's posted on the previous page. I ran the same car in 19T and mod without any changes. Bob Stellflue also ran almost the same setup in stock.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
