Old 11-28-2007, 07:37 AM   #4666
Rick Hohwart's Avatar
Originally Posted by nitro neil View Post
what is everyone running for a servo in there car. I'm in the market for a high end servoand i'm not sure what to get. since i have been out of the loop for ahwile looks like a few things have changed. looking at jr, airtronics and futaba. any help will be appreciated.
I have been using AE's XP Digital Servo 1015 in my TC5. Good speed, torque, and price! Street price is under $100.00.
Rick Hohwart is offline   Reply With Quote
Old 11-28-2007, 07:52 AM   #4667
KO's low profile servo. It doesn't hang over the chassis and you can mount your transponderon the side if it.
Kane-o is offline   Reply With Quote
Old 11-28-2007, 07:53 AM   #4668
KO's low profile servo. It doesn't hang over the chassis and you can mount your transponder on the side if it.
Old 11-28-2007, 07:54 AM   #4669
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Hmmm I just checked Losi Parts House ($89.95) and that is not a bad price. I've have had my S9550 for almost 5 years and I am in need of a new servo. Other that the size the specs are similar to the S9550.
Does AE make these themselves or are they rebadged? ...not that it matters.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-28-2007, 09:33 AM   #4670
HI GUYS,CAN ANYONE EXPLAIN TO ME THE REASONS BEHIND CHANGING THE DIFF HEIGHTS?
tony6187 is offline   Reply With Quote
Old 11-28-2007, 09:57 AM   #4671
It is the ACE 1015 with some cosmetic changes. This is one of the most popular 1/8 off-road servos - durable.
Old 11-28-2007, 10:32 AM   #4672
mainracer's Avatar
Send a message via AIM to mainracer
Kropy- Thank you. It was a very good week end. The car ran really good ! I am looking foward to next races.
Tony6187- Changing the diff height can change the way your car handle drasticaly. Moving both at the same time let say from middle high to middle low won't be as big of a change compared to moving one at a time. having a front diff higher than a rear diff will give your car more steering and vice versa.
I never run my diff higher than mid high. I like to run my diff low as it usualy makes my car easier to drive.
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 11-28-2007, 10:43 AM   #4673
Keven, congrats on making the show in Cleveland with TC5. Great racing!!!!
Martin P
duckman996 is offline   Reply With Quote
Old 11-28-2007, 02:40 PM   #4674
Trader Rating: 68 (100%+)
Keven H. you got pm
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 11-28-2007, 03:11 PM   #4675
51
51's Avatar
Default Cleveland Update
Hey guys...just wanted to drop a quick note to say thanks to the Team Associated drivers at the US Indoor Champs. Both Juho Levanen and Keven Hebert made the modified "A" main finishing a respectable 5th & 6th. Juho was also able to make the ultra competetive 19 turn main and again finish 5th.
We have now posted these two setups on our site for you, the customers to test out. From what I've been told, these setups are quite a bit different than what they've ran in the past and are based on a setup that was developed for the stock class. So just cus it says the setups are for modified, give them a try in stock. I'd be interested in hearing what everyone says. Have fun!
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 11-28-2007, 04:57 PM   #4676
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by 51 View Post
...From what I've been told, these setups are quite a bit different than what they've ran in the past and are based on a setup that was developed for the stock class. So just cus it says the setups are for modified, give them a try in stock. I'd be interested in hearing what everyone says. Have fun!
Interesting....you confirmed what others have been posting...the team drivers went back to the stock chassis. Plus went from from one way to dif. ( I recently changed from one way to diff also) I've been considering switching over to the ITF, and have been reading several people that have now switched back to the stock....so I decided to stay stock, for now.
Whats up with the #56 pistons though? "Piston kit" doesn't come with those IIRC. Is that a special order item?? Looks like springs, camber and shock oils are all a bit different then other similar condition setups.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 11-28-2007, 05:14 PM   #4677
Maybell's Avatar
Kevin, these are foam-carpet setups that Brent just posted....rubber setups are totally different, even if you are running on carpet...
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-28-2007, 05:36 PM   #4678
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
56 and 57 pistons are Losi pistons, three holes. 56 are red, 57 are black.
Brandon Melton is offline   Reply With Quote
Old 11-28-2007, 05:37 PM   #4679
Trader Rating: 7 (89%+)
Mad props. Congrats Keven, breaking your big race jinx.
Johnny Carey is offline   Reply With Quote
Old 11-28-2007, 05:46 PM   #4680
Hey everyone,
I'm still trying to figure out the whole tuning thing with TC cars since Ive only been in this hobby for 2 months so I'm looking to you guys for advice. I've been doing pretty good racing at my local RC shop, but still looking to doing even better. I've made it into 3 out of 4 A mains but I want to finish higher
I'm basically using Brandon Meltons RP30 carpet setup with minor tweaks. I've been getting a lot of push lately and I'm attempting to correct it. Reading through the xray setup book there seems to be MANY different ways to get more off power steering. What do you guys think is the best? change springs? change diff height? diff tightness? change ride height?
naggalowmo is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
