Team Associated TC5
#4607
I have the same problem as Hebiki with the ITF chassis. My car is real tweaked with it and I can't seem to get rid of it. With the car sitting at 5mm ride height all around, my left rear tire weighed in at around 400 grams while the right rear was 310 grams. Right front tires was 398 and left front was 289
#4608
1) Check the arm mounts and make sure you have the same amount of shims on the left side that you have on the right side.
2) You can shim a little but not more than a millimeter
3) make sure the spool is installed correctly.
That should help...
#4609
I do suggest the ITF for loose conditions. But I personally have had no problems (tweak issues) or lack of performance with the stock chassis and upper deck, actually I have had increased cornerspeed and the car was alot more consistant. Let your suspension do the work.
Let me know how it comes out.
#4610
The car WAS better when using the stock chassis. I tried the ITF cause it appeared all the factory guys were using it and so I thought there was a good reason, but I don't like it. I'm normally fighting for the win in stock using my tamiya but I got lapped twice on sturday with the tc5 and the itf...just too inconsistent. I'll be going back to the stock chassis tonight.
#4611
Well like M8 said unless you are running in real loose conditions I wouldnt see the need for the ITF chassis however maybe try the ITF top plate w/the stock bottom. Are you using the O-rings on the top plate that might help you keep the car from tweaking....I would also try to get the tweak out balance the car so that all your shocks are adjusted the same and then make some laps and then put it on the tweak station again and see if having the chassis balanced doesnt help keep it from tweaking...
#4612
#4613
That SUCKS.....I am sure you will be much happier with the stock chassis....I just picked up another 5 I think I will throw the ITF on there just to see if I can figure it out....Hope I can been wanting a solid rubber tire car......I love this car on foams....Hope I feel the same w/rubbers
#4614
#4616
AGREE, I have also use the stock chassis with ITF top deck with very good result and no tweak issue even after crash, but my friend's ITF chassis was tweak and check it with a flat glass then found it wouldn't flex back.
#4618
How are the non team drivers feel about the TC5 on carpet?
Thanks and God Bless
#4619
Brostrom ygpm
