Old 11-15-2007, 07:47 PM   #4576
here is my new tc5. This was one of the best quality cars i have built in the last 20 years of being in this hobby. I cant wait to get her on a race track!
prossi is offline   Reply With Quote
Old 11-15-2007, 07:57 PM   #4577
Special"ED"'s Avatar
try adding rear anti squat. FR 3 RR1 will give 2% anti squat.
Originally Posted by PitNamedGordie View Post
Has anyone tried some front arm sweep on their TC5? I've been told it will give you more turn in. Right now I have 2 degree caster block on my TC5 and I like the way it drove on most of the track. However, I am looking for a bit more turn in. When I had the 4 degree caster blocks on I had all of the turn in I needed, but when existing a turn my car wanted to keep turning. I was thinking if I add some arm sweep this would help. I won't be at the track for another week and a half so I won't be able to experiment soon.
I have attached my setup if anyone needed more info to answer my question. Thanks!
Special "ED "
LOSI SCTE; LOSI-22; XXX CR; Associated 18R; Associated TC5; Asscoaited SC10 4x4;
SDRC Raceway & SDRC-South
RCINSIDER.COM
Special"ED" is offline   Reply With Quote
Old 11-16-2007, 01:15 PM   #4578
Originally Posted by G2B Anthony View Post
I have the same problem, but it seems occurred on turn right only. Maybe the motor side too heavy than the battery side a lot and make the car rolling suddenly cause the rear not stable. Just my 2 sense
Man you sure your car isnt tweaked.....Just by adding about a 1/4ounce weight to the R/F of the chassis balanced my car and even without the weight it didnt act that way.....If your car was tweaked it would be loose left and push right or more aggressive one way or the other...
NUCRPTRACER is offline   Reply With Quote
Old 11-16-2007, 01:34 PM   #4579
Hebiki's Avatar
Trader Rating: 26 (100%+)
sounds like a similar problem i have. i will be purchasing 4 electronic scales and rebuild the car tonight. im putting back the ITF chassis. what i noticed was the car was uneven causing the car to be tweaked on the track. like you said.. push left, loose right.
after i rebuild tonight. i will do the scale test and if i can find my digcam... post pix.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-16-2007, 02:01 PM   #4580
I am running 13.5 w/LRP T/C spec sphere with the cap right next to it and spektrum reciever standing between the cap and servo 9550futaba and I was running the transponder on top of the servo however I found just by moving the trans to the R/F of the chassis does the same as adding the weights only problem is if your running 5cell or the type of cell for instance EP cells weigh more than IB cells.....This car keeps getting better w/every little change and its awesome when you get it perfectly balanced just takes time....
Old 11-16-2007, 02:05 PM   #4581
Default ITF Chassis?
Are you guys noticing any major improvements when using the ITF chassis on asphalt?
Colin F. is offline   Reply With Quote
Old 11-16-2007, 02:23 PM   #4582
I have not ran on asphalt myself....But I have heard guys having better luck w/the ITF top deck and o-ring setup and stock chassis...Are you having a certain problem...Cause I love the car and it seems to get better all the time just wish my driving did....
Old 11-16-2007, 02:55 PM   #4583
RCpurplecow's Avatar
a chassis shot would be nice
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 11-16-2007, 03:22 PM   #4584
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
how can provide a nice picture of the top deck mod to create more sidebite... using the washers and o rings.. and a quick detailed description of how it goes together
wallstreet is offline   Reply With Quote
Old 11-16-2007, 03:24 PM   #4585
Verndog's Avatar
Trader Rating: 16 (100%+)
What gear are you running and where? From my reading a std 13.5 setup w 6 cells should require 1 to 1.5oz of weight on the left side of car. I haven't scaled mine but am running 1oz left with improved handling.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 11-16-2007, 07:24 PM   #4586
My car does the same thing Hook left, push right I have done nothing as far as trying to get the balance yet although this was with a lipo.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 11-17-2007, 01:39 AM   #4587
I actually don't own a TC5 (or any touring car, at this point) but I'm considering a TC5 for some asphalt racing at Marin Hobbies and am wondering if its worth getting the ITF chassis and top plate.
Old 11-17-2007, 09:27 AM   #4588
I am running a 116t spur and 40tooth pinion (64pitch)...I have 1/4 ounce on battery side(right side) right by the front arm....
Old 11-17-2007, 09:32 AM   #4589
Man for the money and the availability of parts from almost every LHS you cant beat this car and it continually gets better and better it is not without its flaws but AE has really put together a huge comeback w/this car....I love it and I applaued AE for stepping away from shaft drive and creating such a nice car..............Stop waiting and buy a TC5.......
Old 11-17-2007, 09:35 AM   #4590
Your tweaked and goodluck getting it ballanced it will require alot of weights...I think a few pages back you will see a lipo TC5 w/ the batt lined on the side w/weights and top I think ...good luck...
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
