Team Associated TC5
#4516
Hello everybody:
I ran my tc5 stock assembly last month but I´ve changed to Ryan´s setup.
You are the master Ryan. It´s alot better. I wonder if you can setup my mother in law to drive her as well as I did this morning with my car......
Thank you
Thank you
#4517
hey guys just wondering if anyone has the same issue as i do
for some reason my chassis tip up and down when on the pit board front to rear of the car i have loosened all the screws and held it flat and tighten everything back up and it still the same
just wondering if it might be the top deck or what anyone else having this issue
thanks
thanks
Pete
#4518
#4520
I had that exact same problem when I changed over to the ITF top plate and chassis. I kept loosening and tightening the top deck using the 4 inner o-rings but the chassis would still rock back and forth. I finally loosened all of the bottom screws on the chassis, flexed it from side to side a few times, and tightened it back down. The chassis laid out perfectly flat and has remained so. Hope this works for you.
Pete
Pete
#4521
Registered User
Gearing
I'm sure this has been dicussed before, but I'm looking for a starting point for gearing a 13.5 Novak Motor. I realize there is alot that goes into gearing... i just need a starting point.
I have a 64 pitch 104 tooth spur. I would prefer to run 64 pitch.
Any help would be greatly appreciated.
Thank you!
Thank you!
#4523
Thank you!
Thank you!
I am down to a 93 spur with 46 pinion and I'm at 4.04 and my mm and orion 13.5 after about 5 mins comes off at 145 degrees I love it fast and cool
let me know
#4524
thanks
thanks
1. Find the flattest surface you can get. Our track has a machinist's stone, but a thick piece of glass, good setup board will do.
2. Loosen the bulkheads top and bottom. Also loosen the shock towers from the mounts.
3. Let the car settle, you can even twist it to make sure it comes back to flat. Tighten the bulkheads bottom screws first. Just snug them, and then go a bit more, don't gorilla wrist them in.
4. Have someone push down on both bulkheads, and tighten one screw on the front bulkhead, then do the opposite diagonally on the rear bulkhead. Go back and forth from front to rear while your friend holds the car down.
5. Once the top plate is done, tighten the shock towers back down. Check the car by tapping on the lower chassis at different points. Is is clicking like it is not flat? If the car clicks at the extreme rear end behind the diff, a very small amount is normal. You may be able to help this somewhat by loosening the rear bulkhead screws on the bottom of the chassis and tightening them again. If the car is clicking in any other place, or the rear moves a lot, you may need to repeat these steps, or you have something broken or bent on the car.
I have been told taking a bit of material off of the ends of the top deck so it is not touching the bulkhead can help as well. Not everybody may agree with this however.
#4525
Help on a TC5 set up????
I see ALOT of differant set-ups and advise on the TC5 for asphalt here(a hell of alot of reading here too 151 pages). I've been racing for about 7 years and love the Associated line for touring. The last belt drivin car i had was a HPI pro 2. After that it was the TC3 and Now the Team TC4. I Race in Texas and I'm gonna be purchasing a TC5 for parking lot asphalt club racing(main track is not a huge track but big enough) and try to go to some BIG electric racing events from time to time. We run alot of 19t races here using cs-27 rubber tires. I'm throwing this out to AE DRIVERS for a set-up and parts i should start with before i buy/build it. I see everyone talking about the spool , aluminum outdrives,the 4 o'rings on the back upper deck and the ITF chassis(upper and lower) for asphalt racing scene. Can someone help me out so when i order the car i can order all the option parts that i need to start out with in the first build(gearing would help out great too,gonna stay with 48p). I was thinking of getting the Mazda speed 6 body for it aswell. If this helps i posted a nice link of the track and design (changes about every other week but, you get the idea). I'm the yellow with the blue flames i like to drive fast and tight into the turns. It has been recently resurfaced and we use grape soda on the track. Gets pretty good traction.Thanks alot for the help.
P.S. Tips on building would be great also.
www.promofo-racing.org/Elec-TC-A-Main-428.html
#4526
Great video, looks professional all the way! I have my tc5 on order and plan to race it on asphalt. Option parts I ordered was the itf chassis and top plate, aluminum outdrives, spooler kit for the front, 1* rear hubs, gold, silver and blue springs, 1.25 sway bar. Got the setup off the AE website so it should work well as a starting point and I'll make changes from there. Hope this helps!
Greg
Greg
#4527
Greg
Greg
#4528
bigdaddy,
I am running ryans setup from the nats, I added .5 degree of front tow out, and have four 0-rings installed in the back of the top plate, no sway bars.
I run mod, but the car is real agressive into the corners which fits my driving style. a little loose coming out which is why I added the tow out.
I run only cs-27's and the mazda speed body, make sure the wing is mounted as far back as possible, seems to work better. the only other difference was running ride height at 5mm in front and 5.5 in rear, I think ryans setup is 5.25 in the front
parts i am running
ae front spool
kit diff
itf chassis/top deck
40wt oil all around
everything else is box stock
hope this helps
parts i am running
ae front spool
kit diff
40wt oil all around
hope this helps
#4529
Registered User
O-Rings
What are you guys referring to with o-rings in the back of the top plate?
Please explain.
Thanks!
Please explain.
Thanks!
#4530
Have a look @ Post #4507
ste e.
