Old 11-06-2007, 12:39 PM   #4486
robk's Avatar
Trader Rating: 22 (100%+)
http://cefxraceway.net/?mainURL=/sto...b8yi/CEFX.html
30050 Associated TC5 Kydex Bumper
Old 11-06-2007, 06:48 PM   #4487
m8commando's Avatar
Originally Posted by DOTMAN View Post
Then I got screwed, mine had no pins
Check your vacuum!
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 11-06-2007, 07:25 PM   #4488
hanzo3's Avatar
Trader Rating: 55 (100%+)
Can anyone give me a part number for silver and blue springs? I am running the stock setup which is the carpet. I primarily run on asphault. Where can I find these springs at?
hanzo3 is offline   Reply With Quote
Old 11-06-2007, 08:40 PM   #4489
Learned something new tonight. The t nut for the diff is different for the aluminum outdrives than it is for the plastic ones. The one that comes with the aluminum diff kit wont fit in the wont fit in the plastic outdrives
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 11-06-2007, 11:18 PM   #4490
HappyHippo's Avatar
Originally Posted by PitNamedGordie View Post
Did you have to use a lot of shims to make it fit?
Yes you have to shim it up, when i tried it i the car felt moore "nervous"
Here we have carpet with monster grip from the first battery pack and have moore problems with tracktion rolling
HappyHippo is offline   Reply With Quote
Old 11-07-2007, 03:20 AM   #4491
Registered User
Default Which one?
Originally Posted by Kevin K View Post
I use the Parma X-ray hard foam bumper.....you only need to make the center hole for the stock plastic bumper brace and then shape it to fit your body. After I installed this I have broken far less things. Some people have used a Kydex bumpers that seem to work well.
PAR8050 or PAR 8053
The 8053 is for the T2.
Thanks!
Reznor88 is offline   Reply With Quote
Old 11-07-2007, 03:42 AM   #4492
zacabrandy's Avatar
Just a couple fo tuning questions for those in the know.
Whats the difference in handling between gaining 3 deg rear toe in by
1: Using the inboard shims only (3 deg)
2: Using 2, 1 deg shims in board and using the 1 deg hub
Handling differences between having inboard front toe out and none?
Keep in mind Im running Modified, asphalt with the ITF chassis and Top Plate.
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 11-07-2007, 08:26 AM   #4493
t4mania's Avatar
Default Wheels
Anyone using 26mm wheels on their TC5. If so what kind?
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 11-07-2007, 11:45 AM   #4494
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by EAMotorsports View Post
Anyone looking for alumn caster blocks Team Tamale has made some and were used by a few guys at the Halloween Classic. Very good quality.
EA
I got ahold of them and have a set of the 4 degs. coming. There was a slight mod they had to make to the hubs, but this first batch EA is refering to is ready for sale....and there aren't many made yet, so snooze and loose. Sounds like they may be a ways off from actual production. Not for the shy at $50.00 per pair...but hell it's racing.
I'll report back findings with some pics in a week or so.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 11-07-2007, 01:17 PM   #4495
I use Jaco's 2-stage 26mm foams that came out last year. The prisms are their newest tire but I want to use my old ones up first. I believe you can still order the 26mm.
Kane-o is offline   Reply With Quote
Old 11-07-2007, 02:30 PM   #4496
john h's Avatar
Aaron, best thing to do is try it yourself, the front toe you can do with parts in the kit, it will give you a more aggressive feel to your steering, how much and when will depend on the rest of the setup, also remember in shortens the wheelbase so try a few different wheelbases.
Rear hubs, as I haven't tried this, I asked Anthony A, what he told me was inboard toe helps add to rear grip mid corner and exiting, and outboard is more into the corner, I could have these around the wrong way it was a couple of months ago.
Main thing to do is try things, some setup changes suit your driving style better than others.
John Hansen,
ORRCA Qld Inc. http://www.orrcaqld.org.au/
john h is offline   Reply With Quote
Old 11-07-2007, 03:42 PM   #4497
Trader Rating: 139 (97%+)
Send a message via AIM to twistedone
Originally Posted by StadiumChris View Post
hey guys... Anyone know if the 64p equivalent will fit in the tc5? Worried about motor clearance. Anyone here running 19turn brushed? What hearing are you using? I need to use a taller spur for more torque on our small/medium track.
if you are running 64 pitch a 100 tooth spur and a 35 tooth pinion it will put you at 5.71 right in the ball park for the larrys track
let me know if that works out
twistedone is offline   Reply With Quote
Old 11-07-2007, 03:44 PM   #4498
t4mania's Avatar
Thanks much Kane-o!
FT T4 Dirt Oval
Old 11-07-2007, 03:49 PM   #4499
t4mania's Avatar
Default Foam vs. Rubber Tires
My local track's touring car season opens in April or May next year. This will be my first year there. Its an outdoor asphalt road course and from talking with the track owner it seems most people are running foams. Seems like a waste of money to me to burn up a set of tires in one day. I like to run rubber on asphalt but I'm afraid rubber won't be able to keep up with the foams. Any ideas or comments.
FT T4 Dirt Oval
Old 11-08-2007, 03:41 AM   #4500
zacabrandy's Avatar
Thanks John,
I havent had a car with different hubs available as this has, so I was a little unsure as to their effect.
Im happy with the car overall, and i certainly dont need to gain anymore steering. I found out I have been running with only 2 deg rear toe, by mistake, so Im going to try the 1 deg hubs and see what it does.
Thanks again for the help
Cheers
Aaron
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
