Old 11-05-2007, 03:26 PM   #4456
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by RCpurplecow View Post
you mean it should have come with the associated spool?!!!! cause I didn't get anything. Can I buy them separately? or aftermarket?
Top Racing also makes a spool for the TC5. The aluminum version is now available with the steel version slated to be released by the end of the year i think? They also make spare blades for the spool.
Contact EJ Evans (ej@topracingusa.com) for more information.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-05-2007, 03:30 PM   #4457
RCpurplecow's Avatar
thanks k spec
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 11-05-2007, 03:36 PM   #4458
unfortunately those blades are out of stock, is there another possible way of making my own blades... maybe with heatshrink?... or should i wait.
TEAM SRU
FT TC5
NoVak
rematch batteries
Old 11-05-2007, 03:52 PM   #4459
dbmartin's Avatar
purple cow you should wait, if you try to use anything else, you will ruin the outdrives. you should have got a set w/ the kit though.
btw on the spool, does anyone notice that the spool, or most likely the pulley is out of round. I tried to center it, but I think it is causing the tension on the belt to be tighter based on the rotation of the pulley/tires.
associated spool that is
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 11-05-2007, 04:02 PM   #4460
ur probably right... i should wait
TEAM SRU
FT TC5
NoVak
rematch batteries
Old 11-05-2007, 04:05 PM   #4461
beavis353's Avatar
Originally Posted by Johnny Carey View Post
JB Weld?
Funny. Be preparred to get smoked at the Novak race like SARAH EARNST smoked you at the Gate. Hope your bringing rubber tires.
beavis353 is offline   Reply With Quote
Old 11-05-2007, 04:22 PM   #4462
I don't think it's the pulley. I believe the issue is the spool doesn't center inside the pulley and since the screw holes don't center it, you're forced to try and center it by site which isn't very accurate. I believe that to be the problem. I had the same issue.
DOTMAN is offline   Reply With Quote
Old 11-05-2007, 04:25 PM   #4463
ooliganRC's Avatar
Send a message via MSN to ooliganRC
hope the blades are better than the associated ones.
the serpent ones look like they fit.. will try them soon
Corally RDX PHi, Novak Brushless, Futaba 3GR, KO Propo 2413, E-Power 4500, Full Throttle Motorsports.
"You aint going fast enough, if you aint Full Throttle"
Currently slow due to : Bad thumbs and no motors :P
ooliganRC is offline   Reply With Quote
Old 11-05-2007, 04:33 PM   #4464
Verndog's Avatar
Trader Rating: 16 (100%+)
The only issue I have with the blades is a slightly snug fit. A small flat file to the alum. outdrives will release the tiny bit of bind. Mine work flawlessly and I doubt I'll need to replace them anytime soon.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 11-05-2007, 04:35 PM   #4465
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by Nexus View Post
Rob was that you, Kev and company at the 2007 HobbyPLEX Midwest Carpet Onroad Championships??
If so good job...and to KevinK for sweeping the A1 and A2...very nice Mr. Viking.
Thanks Team Low Budget was in full effect......Rob's car was good on Foams and mine was good on Rubber tires. The Techno Viking was most pleased by this weekends performance.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-05-2007, 04:44 PM   #4466
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Yep that's it. I'm still trying to get it perfect.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-05-2007, 04:57 PM   #4467
Trader Rating: 17 (100%+)
Wrap the hub with a little scotch tape. That will allow you to center it. Then pull it out (or not) once it is bolted in. I left mine in....
Good luck
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 11-05-2007, 07:03 PM   #4468
What we have been doing is lightly sanding the blade with 400 grit sandpaper
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 11-05-2007, 10:35 PM   #4469
Default Team Tamale Aluminum C-hubs
I have a limited number of aluminum c-hubs available for thr TC5 in 4, 6, and 8 degrees. These are not up on the website yet. You can email me at teamtamale@tx.rr.com for more info.
teamtamale is offline   Reply With Quote
Old 11-05-2007, 11:02 PM   #4470
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
Default Tamale
Hey guys I've used the Tamale stuff before and can say that his stuff is absolutely top notch..
I think it will stiffen up the front of the Tc5 a bit for running foam..
main reason i just ordered mine.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
