Old 11-02-2007, 03:34 PM   #4426
I just glued the stock one together, its one piece now!
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 11-02-2007, 04:22 PM   #4427
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Ditto!
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 11-02-2007, 07:19 PM   #4428
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Anyone looking for alumn caster blocks Team Tamale has made some and were used by a few guys at the Halloween Classic. Very good quality.
EA
EAMotorsports is offline   Reply With Quote
Old 11-02-2007, 07:26 PM   #4429
Trader Rating: 68 (100%+)
Ea you got pm
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 11-02-2007, 07:35 PM   #4430
Team EAM
Anyone looking for them contact Larry at Team Tamale. He has 4, 6 and 8 degree's in stock and will have them up on his site soon.
EA
Old 11-02-2007, 07:58 PM   #4431
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
rear hubs ?
wallstreet is offline   Reply With Quote
Old 11-02-2007, 08:05 PM   #4432
I really thought there would be a lot of aluminum out for this car by now
FT B44 - FT J82
Old 11-02-2007, 08:13 PM   #4433
wallstreet's Avatar
I think there working on it. But they have to jump through all the thunder tiger hoops now. So it will take time
Old 11-03-2007, 01:54 AM   #4434
smostyn's Avatar
Trader Rating: 9 (91%+)
Originally Posted by DOTMAN View Post
Well, Titanium racing burned me again. I'm posting me rant here because this time it was the new tc5 one piece layshaft. I thought, it's one piece, they couldn't mess that upp...could they?. Well, after waiting two weeks for it to get here from the UK, I went to install it. Spur gear went on a little tight but not big issue. Then I took the pins out of the old layshaft and went to pop them in the new one. Changing the layshaft should have taken 10 minutes except the pins don't fit. After fifteen minutes of trying to force them in I realize the holes are just way too small and will need to be drilled out. Since the manual doesn't state the size of the pin i start going through all my drill bits trying to find one the size of the pin. No luck. I'm not going to bore you with the details of my quest for the right size bit, but two hours later I'm back at home with the right bit. I drill out the first hole and I'm able to press fit the pin with some needle nose pliers. Cool. So now I drill out the second and third holes when I realize...third hole? Looking at the stock shaft, the third hole was supposed to be a slot for the E clip. After looking at it for a minute I thought I could just force in another pin and use that to hold the pulleys in place instead of the E clip. Two problems though...one the pin needs to fit under the blue cap and needs to be dremeled down to fit under and two (the bigger problem) the placement of the third hole is in a spot where the pulley covers about 20% of it. Not a lot but enough to make it really difficult to get the pin in. After fighting with it for 20 more minutes, I decided the pulley was pretty snugly on the shaft already and shouldn't move to much and the blue cap should help keep it from moving too much so I through it back in the car as is.
Anyway, No more TiR products for me. I'm tired of their poorly engineered products and bad R&D. I've been burned for the last time. TiR, get your act together.
I have fit one to my TC5 nd it went together fine. There were pins in the packet that were the right size, I had mine back together in about 5 mins.
Shayne Mostyn
Meakin Park Model Raceway, the best club in SEQ
I am no longer racing. Now I plan to bash around on a larger scale.
smostyn is offline   Reply With Quote
Old 11-03-2007, 02:06 AM   #4435
zacabrandy's Avatar
Originally Posted by Hebiki View Post
hopefully AE releases their own version and it has the proper holes for the pins, etc.
Originally Posted by PitNamedGordie View Post
Ditto!
Well my TiR one piece layshaft went together in about 2 minutes, it had the pins for the holes supplied in the packet.
It also takes the slack out of the layshaft as well. Maybe you have got a bodge pack, but Im pretty sure that they would check thses kinda things before sending them out for sale.
I supposse the next flame will be about how to attach the TiR spool cups......
Cheers
Aaron
zacabrandy is offline   Reply With Quote
Old 11-03-2007, 05:05 AM   #4436
Team EAM
Originally Posted by wallstreet View Post
rear hubs ?
He's working on those as well as Front steering knuckles too.
EA
Old 11-03-2007, 01:34 PM   #4437
carbon madness's Avatar
EA
Do you have a link to his site?
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 11-03-2007, 03:02 PM   #4438
Verndog's Avatar
Trader Rating: 16 (100%+)
Google is your friend....and the stockholders as well.
http://www.teamtamale.com/
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 11-03-2007, 07:52 PM   #4439
Team Tamale c-hubs will try to post some pic
SHAUN GRIDER is offline   Reply With Quote
Old 11-04-2007, 07:51 PM   #4440
A few pages back someone listed the part numbers of the low friction belts as #31189+31190.I couldn't find those on Associated's site.Do I have the right part numbers?
outlandr91 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
