Old 10-23-2007, 01:15 AM   #4366
Broady Racing's Avatar
Send a message via MSN to Broady Racing
Default roll out / fdr
Hi all . Looking for some help gearing our tc5 with the novak xbr system - 10.5 ex motor . We are running the same system but with the 13.5 at our track with a 39.35 roll out - fdr 5.03 - ( rubber / outdoors ) and it works great . We need to get some thoughts on the right ratio for the 10.5 . Thanks in advance .
Broady Racing is offline   Reply With Quote
Old 10-23-2007, 09:12 AM   #4367
tcfree's Avatar
Start @ ABOUT 6.1-6.3 fdr and take it from their see how warm/hot the motor is after 5min or so, The gear more or less dependin on the temp!!
Ste.
tcfree is offline   Reply With Quote
Old 10-23-2007, 06:03 PM   #4368
Has anyone purchased the aluminum outdrives? Do they come with inserts? Have any of you guys purchased any outdrives from TIR? My buddy bought the aluminum outdrives from AE and the cvds are tearing them up cause they have so much play....Any Ideas I thought maybe he threw somethin away he wasnt supposed to....
NUCRPTRACER is offline   Reply With Quote
Old 10-23-2007, 06:38 PM   #4369
nucrptracer- if your body is using the blades then h shouldnt be tearing up the outdrives but if he is not using the bone blades then all you can really say is.......ooops! the aluminuim out drives are very good from AE. it may e confusing because with the plastic out drives you dont use the blades hope his helps
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 10-23-2007, 07:24 PM   #4370
Trader Rating: 16 (94%+)
STOP running the AE Aluminum outdrives without Blades!!!
The blades are part #31238, and come with x8 in a package. I recommend buying 2-3 packages of them.
KSN
kn7671 is offline   Reply With Quote
Old 10-23-2007, 07:56 PM   #4371
I just ordered the Aluminum outdrives but i have not been able to find the spool. Oh well hopefully my home made one will hold up for a while. What set up is a good start for 19t asphalt? I may finally get to run it this weekend someplace other than in front of the house!
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 10-23-2007, 08:29 PM   #4372
Midnight's Avatar
Trader Rating: 85 (100%+)
Give losipartshouse.com a shout. THey parts are way cheap! I tried a spool this past weekend, and it felt very fast thru the corners, just take some getting use to.
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 10-23-2007, 09:13 PM   #4373
mike williams's Avatar
Trader Rating: 45 (100%+)
Hey tc5 beilevers::::i'm looking to get a tc5 and have some questions. I've had an xray t2 and corally rdx and the things that i like about them are the hop-up parts that are available. i can't seem to find them for the tc5.any advice would be appreciated. i would like to support a american company than the over seas company's.
Thanks Mike
mike williams is offline   Reply With Quote
Old 10-23-2007, 09:33 PM   #4374
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Mike what hop up parts are you looking for ?
If you are going to run rubber tire the only things your going to need to buy would be the rubber tire chassis and top deck ( itf chassis and itf top deck ) a spool and a one way . good to have both so you can try them out and see which is better on a particular layout.
As far as alumium hop ups for rubber tire that stuff is not needed as the material that is used to make the arms and caster blocks and steering knuckles are a bit soft compaired to the xray and corally stuff.. Which is very ideal for rubber tires and also are prone to less breakage.
wallstreet is offline   Reply With Quote
Old 10-23-2007, 10:33 PM   #4375
Verndog's Avatar
Trader Rating: 16 (100%+)
There not hard to find. Here is one for you.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-23-2007, 10:40 PM   #4376
Thanks Verndog. I could have sworn that i looked there!
FT B44 - FT J82
Old 10-24-2007, 02:43 PM   #4377
Hey wallstreet: point taken, but not being very sharp on the track it is nice to have some rigidity, but not a manditory thing to have. thanks for the advice and also can the associated web page be more complicated to view?? or maybe it just me, another question:is the "itf" or what ever it is called just a thinner chassis and top plate??and what difference will the spool and the one-way make comparing to each other..thanks
LOSI MF2 ....... too fast for me!!!!!!!!
Old 10-24-2007, 02:45 PM   #4378
Thanks for the help guys..........Blades on order....Have you guys ordered anything from TiR wandered how long it took to arrive in the states?
Old 10-24-2007, 03:05 PM   #4379
Does anybody have a good rubber tire carpet setup for stock 13.5 . I just put my car togther it all stock so far. OH yes what would be the best diff, spool or oneway.
ptjonesus is offline   Reply With Quote
Old 10-24-2007, 04:10 PM   #4380
Send a message via MSN to TurboT
Look for Juho Levanen's setup on the Associated website. It's a very good starting point and you can tweek it to your liking from there.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
