Old 10-22-2007, 01:54 PM   #4351
Trader Rating: 14 (100%+)
per side
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 10-22-2007, 02:00 PM   #4352
HappyHippo's Avatar
Anye one who knows witch shop has parts i stock, tryed Hong Kong but all are out of stock on Spool kit/oneway kit
HappyHippo is offline   Reply With Quote
Old 10-22-2007, 02:14 PM   #4353
stonedgti's Avatar
Trader Rating: 15 (100%+)
Can someone tell me what happens when you change the ball stud location on the steering block do? How will it effect the handing when I use the outer hole.
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 10-22-2007, 02:29 PM   #4354
corallyman's Avatar
Trader Rating: 99 (100%+)
Verndog,
I don't know if you know this or not but when you buy replacement plastic diff halves you get 2 full sets of parts. That means 2 barrels as well. I think that I paid 4.95 for the whole bag from stormer which is very good pricing. Chances are if the barrels were bought seperately they wouldn't be much cheaper. So you could pay the 5.00 get the 2 parts you need and sell/give away the other parts if not needed to a friend.
Steve
corallyman is offline   Reply With Quote
Old 10-22-2007, 03:09 PM   #4355
robk's Avatar
Trader Rating: 22 (100%+)
More steering
Old 10-22-2007, 04:33 PM   #4356
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by corallyman View Post
Verndog,
Steve
True...I guess I have enough now (3 extra). Just seemed a bit sad to pay the $5.00, a couple dollars shipping for 2 of those POS plastic diff nut retainers. I thought of using just the nut, and a ground down driver on the other side to hold while adjusting. Problem with that, you have to pull both sides to adjust instead of one.
They really should at least include them with the diff rebuild kit...putting in just the nut is a bit useless.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-22-2007, 06:22 PM   #4357
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Got a simple set up question...I've searched the forum and can't find my answer.
What difference does having toe in at the rear hub have as opposed to toe in at the arm mounts?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-22-2007, 06:27 PM   #4358
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
i do not have the answer for you , but i know there is a huge difference.
Inboard toe vs Outboard toe
Josh Cyrul answered this question with extreme detail. Its somewhere on rctech. He explained it so it was very easy to understand.
Maybe post on one of his threads to see if he might post the differences again.
wallstreet is offline   Reply With Quote
Old 10-22-2007, 06:47 PM   #4359
robk's Avatar
Inboard toe can make the car transfer more weight fore and aft. Outboard toe is used a lot with foam since the car doesn't dive so bad.
Also, inboard toe will shorten the car as you add toe.
Old 10-22-2007, 06:49 PM   #4360
I searched for "Inboard toe vs Outboard toe" and found some more info. I'll see if I can Josh Cyrul's posts.
Old 10-22-2007, 06:50 PM   #4361
Hmm...Thanks.
Old 10-22-2007, 06:51 PM   #4362
wallstreet's Avatar
So inboard toe for rubber tire then roberto king ?
Old 10-22-2007, 07:10 PM   #4363
Trader Rating: 69 (100%+)
On the arm actually will make the rear spring a little stiffer that why at times guys will say more toe freed up the car on the onboard setting if you have 2 car put more outboard compared to inboard and feel the difference with the same springs also with the inboard you are changing the wheel base.
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 10-22-2007, 07:10 PM   #4364
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
robk is right, it will give overall more steering. If you want the technical answer so that you feel a little more understanding here it is.
The outside hole gives less ackerman, what this means is that the inside and outside tire turn at a very similar rate (angle). Using the inside hole means that the outside tire will turn at a lesser rate than the inside tire. More ackerman means less angle of the outside tire leading to less steering.
However, sometime running the outside hole makes the car twitchy and difficult to drive consistently, especially on foam tires.
The forward and backward holes on the bellcrank do the same thing. The forward of the two holes is the most aggressive, giving "less" ackerman. It goes in this order
1B most aggressive
1A
2B
2A least aggressive
Brandon Melton is offline   Reply With Quote
Old 10-22-2007, 10:08 PM   #4365
stonedgti's Avatar
Thanks for the answers guys. I'll try both out to try and feel the difference.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
