Old 10-19-2007, 11:57 PM   #4336
Midnight's Avatar
Trader Rating: 85 (100%+)
Originally Posted by wallstreet View Post
this is probably a very stupid question..
Where do the o rings go on the AE one way ?
I think inside the place where the axle goes into.
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 10-20-2007, 03:54 AM   #4337
Hoggy's Avatar
Trader Rating: 26 (100%+)
its interesting that you say the front bomber belt makes a difference I will have to get one and see for myself, has anyone tried the rear bomber belt as well?
Hoggy is offline   Reply With Quote
Old 10-20-2007, 05:55 AM   #4338
Send a message via MSN to TurboT
I believe the rear belt is too small for the TC5, if I'm not mistaken. You shouldn't need the rear belt anyway. It seems to be able to run more than loose enough. It just seems the fronts end up being too tight. I stretched my stock belt manually, and it isn't too bad, but I'm really looking forward to trying out the AE low-friction units.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 10-20-2007, 05:57 AM   #4339
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Is that correct? I have a oneway that came with the car. Wasn't aware of an oring going into the drive cups. Can someone verify this?
Dasupacat1 is offline   Reply With Quote
Old 10-20-2007, 06:05 AM   #4340
The AE one-way doesn't have grooves for the o-rings that the diffs have.
Team Great Hobbies
Team Durango Canada
Exotek
Old 10-20-2007, 01:25 PM   #4341
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
You don't have to use the o-rings in the one way. As a matter of fact when I put them in, it limited the suspension travel because the dogbone hit the o ring.
Brandon Melton is offline   Reply With Quote
Old 10-21-2007, 02:21 PM   #4342
Hebiki's Avatar
Default Checking for Chassis Tweak...
Hey guys, i was checking my car for tweak yesterday.. and I wanted to compile a checklist. Please add to this checklist if i forgot something.
Check for the following..
- chassis is flat
- bent hinge pins
- shock lengths
- droop measurements
did i miss anything else?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-21-2007, 03:03 PM   #4343
i.a.s's Avatar
just something that I check is that the shock mounts are all tight I had the rear that was loose didnt notice it for ages just couldnt understand what was wrong due to being loose it moved up on left hand bends.
i.a.s is offline   Reply With Quote
Old 10-21-2007, 07:09 PM   #4344
- chassis is flat
- bent hinge pins
- shock lengths
-left/right weight balance
-spring lengths
-shock rebound lengths
G2B Anthony is offline   Reply With Quote
Old 10-21-2007, 07:24 PM   #4345
Hebiki's Avatar
Default Updated Tweak Checklist
- chassis is flat
- bent hinge pins
- shock lengths
-spring lengths
Here's a more thorough checklist for checking tweak:
- chassis is flat
- bent hinge pins
- shock lengths
- left/right weight balance
- spring lengths
- shock rebound lengths
- shock mount
thanks for the help guys.
Hebiki Design Works
Old 10-21-2007, 07:59 PM   #4346
Verndog's Avatar
Trader Rating: 16 (100%+)
Default Aluminum outdrive and Diff nut
I setup my aluminum outdrives onto the rear diff this week and have a question. The outdrives have the wider slot for the dogbones, and the stock diff nut with plastic barrel is way small in the drive slot. Plus...to make matters worse, the plastic barrel appears to only come as a kit with the plastic outdrives.
I have it working, but would like to know if there is anything better fitting that doesn't come as a kit??
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-22-2007, 07:00 AM   #4347
There may be something from the offroad kits that fit tighter, but the plastic one works fine. There are white diff nuts that have the threads built into it rather than using a lock nut, but the size of the knubs on them probably aren't bigger. My alum outdrives have worked fine with the kit barrel. I'm not sure if the barrels are available seperatly or not, have you checked the manual for a part number to see if it's different?
Old 10-22-2007, 09:19 AM   #4348
B4james's Avatar
When runnning the aluminum outdrives you need the plastic blades which go on the driveshafts, this takes up the gap and protects the aluminum from chewing out. There is also a larger plastic t-nut but not sure of the part number
B4james is offline   Reply With Quote
Old 10-22-2007, 10:10 AM   #4349
Verndog's Avatar
I figured they would work OK...the tab is mostly to prevent turning while adjusting / tightening and that seems OK.
Yes...I checked the part number from manual, and that leads to the full set of plastic outdrives. I saw the white ones your refering to show up in a search. I may give those a try rather then throw away plastic outdrives everytime I want to replace the diff nut.
The blades are fine, I'm asking about the diff nut. If you find that part number please post it.
Thank You.
---Team Hoarders---
Old 10-22-2007, 01:52 PM   #4350
Ok i have a really dumb question with regards to the rear toe in. Is it measured per side or total. I am pretty sure it is per side but would just like to know for sure.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
