Old 10-17-2007, 09:34 PM   #4306
Midnight's Avatar
Trader Rating: 85 (100%+)
On the stock set up it calls for 1 shim on the arm mounts front and rear. How does this cause the care to react? Thanks
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
Old 10-17-2007, 10:54 PM   #4307
JuhoL's Avatar
Originally Posted by Verndog View Post
I sure have...the left rear especially. Running 3 deg toe, and using longer screw WITH thread lock and still lost the shims again last night. I guess I just need to check every run...period.
Its usually the ones with more shims under them that loosen up, right? You can try replacing the screws with some longer ones ( I use 12mm ). I havent had much problems with rubber tires but with foams they will loosen up a lot quicker.
Associated/Reedy/LRP/Muchmore/Sanwa/Protoform/Jaco/Xenon/Parma
JuhoL is offline   Reply With Quote
Old 10-17-2007, 11:55 PM   #4308
B4james's Avatar
On the rear you want to run shims in the rear arm mount but generally not in the rear front mount,
you want to aim for about 2.5 to 3 degrees of rear toe which will lock in the rear. I did this step late at night when probably should have been in bed and ended up putting shims at the front and back which resulted in 0 degrees and the car on rubbers was really hooky in turns. After correcting it The three degrees worked a treat.
B4james is offline   Reply With Quote
Old 10-18-2007, 09:16 AM   #4309
Midnight's Avatar
Thanks!
Old 10-18-2007, 09:21 AM   #4310
Verndog's Avatar
Trader Rating: 16 (100%+)
You've got it. And only the left side (for me), rear mount. I already have the 12mm longs in there, and the blue AE thread lock. Didn't lose the screw, but loosened enough in 3 runs to drop the shims again.
Must be the amount of shim and the fact the angle doesn't allow the screw head to seat very flat.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-18-2007, 12:59 PM   #4311
Yeah mine is the left also its driven me nuts....I am gonna try the longer screw....I wish they would make all the shims out of titanium or aluminum...the blue would be eaiser to find
NUCRPTRACER is offline   Reply With Quote
Old 10-18-2007, 01:22 PM   #4312
Wouldn't the aluminum XRAY shims work?
DOTMAN is offline   Reply With Quote
Old 10-18-2007, 04:59 PM   #4313
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
By adding more shims to the front end of the car (making it wider) the car will be more tame, easier to drive, but lose overall steering. By removing shims, the front end becomes narrower which causes the car to have more steering through the corner.
By adding shims to the rear of the arm mounts in the rear of the car, this creates more toe in. More rear toe will usually give the car more rear traction. You should never need to go more than 3 deg of rear toe for most applications and usually never less than 1.5 deg.
Brandon Melton is offline   Reply With Quote
Old 10-18-2007, 06:33 PM   #4314
Midnight's Avatar
Just got my new orion 10.5. I was using the gearchart.com but I dont think its right. I found a 94t 64p spur. Im trying to get to around 5.5 ratio. The 94t spur is smaller than the stock 87t 48p. Any how does anyone have any idea what would be a good starting point for the 94t 64p spur for the 10.5 orion. Thanks in advance
Old 10-18-2007, 06:58 PM   #4315
My buddy that works for Orion told me to start at about 5.0 fdr. Thats why i went 112/44. I would start with a 37 or 36 pinion. By the way who makes the 94 spur you are running?
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 10-18-2007, 07:06 PM   #4316
Midnight's Avatar
Im using a yokomo with two screws for now. I think I might switch to the stock 87. Does everyone have slop in the spur gear holder?
Old 10-18-2007, 07:36 PM   #4317
It sounds like it to me. I am going to see if i can get my wifes cousin to make me an aluminum one at his machine shop.
FT B44 - FT J82
Old 10-18-2007, 07:41 PM   #4318
Renuco612's Avatar
Send a message via AIM to Renuco612
Default TOOO SLOOOOOW!!!
My problem is that my car can't keep itself on the track right at the 90 degree turn after the straight away. right before the turn I let off the throttle and make the turn and then there the car goes and flips on its left side? Everything else feels okay though. Atleast I feels like it does.
Not sure if its my driving or what it can also be that though.
(I need to practice more) I think I'm running to soft. Does that sound right? It feels that I am going to slow around the turns. Seems like I have to let off the throttle way before a turn just to make it safely.
I'm running SILVER springs on the Rear and BLUE on the fronts. I was thinking of changing the rears to RED. RP 30s all the way around. What should I do differently?
TC5
Futaba 3pk
LRP Sphere Competition TC
Futaba S9550
Orion 3200 Carbon
Renuco612 is offline   Reply With Quote
Old 10-18-2007, 07:54 PM   #4319
Jea3's Avatar
What oil do you have in your shocks?
Look in my pics at the top. I have blue fronts, silver rear, RP30's, parking lot track with 150ft straigt into a hard right, then technical track. Car was smooth, and fast. I used a spool in the front, 40 wt in ft, and 25 in rear. Kit sway bars, kit shock positions, kit roll center, ROAR weight, meaning lots of added weight on the right side of the car, and balanced.
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 10-18-2007, 09:35 PM   #4320
JuhoL's Avatar
If your car is flipping it's either too stiff or the rollcenters are too high. I posted a setup on the previous page from the ISW race. Everybody's cars were flipping there. Maybe give it a try. Also check your camber, droop rideheight and tweak if the car only flipping to one side.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
