Old 10-04-2007, 07:51 PM   #4156
Trader Rating: 14 (100%+)
Originally Posted by Pete Thomas View Post
I would like to confirm the droop that Juho is running on this rubber tire on carpet setup (2mm rear, 1 mm front). Is that really correct? I have never run a car with this little droop. Any feedback would be appreciated.
Thanks, Pete
That would be uptravel or "over ride height". The chassis move up 1mm in the front and 2 mm in the rear before the wheel lifts off the ground.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 10-04-2007, 09:11 PM   #4157
I'm fully aware of what droop is. The problem that I'm running into is that when I set the droop at 2 mm/1 mm respectively, it becomes virtually impossible to raise the ride height to 5 mm. If I set the ride height to 5 mm first, it is lowered when the droop is decreased. Do you see the dilemma? How can I get a ride height of 5 mm and the droop set at 2 mm/1 mm concurrently? They appear to be in conflict with each other. Any suggestions?
Thanks in advance, Pete
Pete Thomas is offline   Reply With Quote
Old 10-04-2007, 11:36 PM   #4158
JuhoL's Avatar
Pete:
Try setting it like this: First set your ride height to 5mm. Then lift the car up so that the tires barely touch ground and set the droop so that you have 6mm or 7mm of rideheight at maximum droop.
Hard to explain but easy to do when you get it
If the droop is limiting your rideheight you have no droop at all.
Associated/Reedy/LRP/Muchmore/Sanwa/Protoform/Jaco/Xenon/Parma
JuhoL is offline   Reply With Quote
Old 10-05-2007, 12:32 AM   #4159
Originally Posted by JCB View Post
Hey Guys,
What kind of rollout do I want to be at running 7 single... track is 200x100 on rubber tires...
Thanks,
I would start between 18-20mm. Since it is a large track you would probabley be safe with the higher end.
-Kane
Kane-o is offline   Reply With Quote
Old 10-05-2007, 12:59 AM   #4160
i.a.s's Avatar
Will have a look at that but checked it all seem odd didnt notice it when I had a diff in though so I will put that back in to see what is happening the belts are just so tight because of it.
i.a.s is offline   Reply With Quote
Old 10-05-2007, 01:50 AM   #4161
i.a.s's Avatar
Right I have taken a look, The spool pully is not out of round but because the hole in the center is slighly to big when the screws are tightened up they move the pully tight to one side causing the pully to run out of line. AE please send me a new pully with the hole the correct size I guess I will have to line it up carefully when putting it on.
Old 10-05-2007, 01:57 AM   #4162
tc3team's Avatar
Im not sure whats worse... spool outdrives not building up properly or tc3 plastic outdrives melting like mine did LOL
You never had any problems like that with the tc4, must be a bit annoying with a new car! Hope it all comes good
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 10-05-2007, 04:57 AM   #4163
Originally Posted by JuhoL View Post
Pete:
Thanks Juho. I will give this a try. I had a similar experience in trying to set 2mm of droop on a Tamiya 415 MRE where I essentially had no droop. This technique should work on both cars.
Thanks again, Pete
Old 10-05-2007, 08:01 AM   #4164
b-man777's Avatar
Default brian kinwald@'07 iic race
hey all:I heard that brian was at the '07 iic race and running a tc5 sedan any good pics of his sedan at the iic and can someone confirm this.Also what i know is that he's running novak brushless,but any word on what batteries he's using?Thanks
b-man777 is offline   Reply With Quote
Old 10-05-2007, 09:07 AM   #4165
Suspended
yes he was there and yes he was running a tc5 and novak...as for batteries i dont know that
i am cornholio is offline   Reply With Quote
Old 10-05-2007, 10:56 AM   #4166
JuhoL's Avatar
Brian was running a LRP speedo and a Novak motor. Not sure about the batts.
Old 10-05-2007, 11:16 AM   #4167
EricF's Avatar
I think he gets batteries from SMC. If I go to the track tonight I'll check and see.
E
EricF is offline   Reply With Quote
Old 10-05-2007, 06:52 PM   #4168
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Anybody have problems fitting their drivers into the M3x2.5 setscrews that go into the roll bar pivot and the M2x5 shcs screws that hold the anit-rollbars to the arms. My driver didn't even want to go in them except for one of the setscrews. I used a Losi, Integy, and Dubro 1/16 wrenches.
Dasupacat1 is offline   Reply With Quote
Old 10-05-2007, 07:14 PM   #4169
Verndog's Avatar
Trader Rating: 16 (100%+)
Those should all be 1.5mm hex's not 1/16th.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-06-2007, 03:58 AM   #4170
Dasupacat1's Avatar
Ok..duh.
Wow the plastic on this cars suspension is soft. Hope it doesn't hurt performance w/foams. Anybody find a good foam/carpet setup?
My car also came with the ITF chassis/top plate. Anybody try this with foams or should I swap for the std. chassis.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
