Old 10-03-2007, 05:44 PM   #4126
corallyman's Avatar
Trader Rating: 97 (100%+)
Originally Posted by Dasupacat1 View Post
Can you use Kimbrough or PRS spurs on this car?
RW Spurs will also work, that's what I have on my car.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 10-03-2007, 07:05 PM   #4127
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
I have talked to bob often as well.. And i do understand that it takes time to find the magic setup or starting point. But to be honest.. the car has 1 full indoor season on it and not much has changed in the way of results on carpet.
Like i said before maybe i am wrong about the harder arms, but walt henderson had the same idea as myself and another local driver if he was trying to stiffen him FT arms at the IIC.
I will not say the car is not good, cause it is very good but there are a few option parts associated could sell that not only would bring in some extra cash, but probably also increase the performance of the car on foam tires on carpet.
wallstreet is offline   Reply With Quote
Old 10-03-2007, 07:36 PM   #4128
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Pretty soon the only people that will be racing foam tires on their sedans will be the guys with tire deals. All others will be running rubber tires and you won't need stiffer suspension pieces. Flame suit on.
Kraig is offline   Reply With Quote
Old 10-03-2007, 07:41 PM   #4129
Super Moderator
Kraig's Avatar
Brandon and Rick, thanks for the clarifications.
Old 10-03-2007, 07:51 PM   #4130
I have racing at indoor asphalt track with high grip, my TC5 seems very oversteering with the below normal setup
Spring F-blue R-silver
Oil F/R 40 with #3 piston
ITF upper deck
F arm mount 2A2A with 0 mount shim
R arm mount 3A3A with toe in 3
Does anyone know what is best setup for tight indoor asphalt
G2B Anthony is offline   Reply With Quote
Old 10-03-2007, 07:53 PM   #4131
Verndog's Avatar
Trader Rating: 16 (100%+)
Default Servo Saver
I finally busted the threaded barrel that holds the servo saver together..(one part I didn't stock )...After getting a new one and looking more carefully as to why, I believe I over tightened it. If you snug it too far, the "saver action" is no longer. I loosened it about 1/2 turn and blue locktighted it to give a bit more of the cam action...But. Directions say nothing about where to set. Is there a rule of thumb on where to best set this to keep slop to a minimum yet retain the cam saver action?
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-03-2007, 07:59 PM   #4132
fathead's Avatar
It says in the instructions to tighten the collar until it is flush with the end of the blue barrel part
Slavich Design
fathead is offline   Reply With Quote
Old 10-03-2007, 08:31 PM   #4133
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
ITF upper deck
Based on what you have listed here, there things you can do do "tighten" the car up to get closer to understeer.
If you add 1mm of mount shim to each of the front arm mounts, this will tame the car as you have the narrowest front end. Are you using a spool on asphalt?
Brandon Melton is offline   Reply With Quote
Old 10-03-2007, 08:53 PM   #4134
carbon madness's Avatar
Whats the differnce of a spool, one-way, and the diff that comes stock with the kit?
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 10-03-2007, 09:01 PM   #4135
Verndog's Avatar
OK...now I see that. Pic is not all that clear IMO...but makes sence since that is short of completely tight. . Thats about where I ended up "this time". Hopefully it stays in one piece.
---Team Hoarders---
Old 10-03-2007, 09:22 PM   #4136
Default Shock Help
Hey All,
Just started building my TC5 and want help with achieving zero rebound with the shocks. I don't know how to approach this as I am used to building Xray shocks. Any help would be appreciated in building these shocks.
-Kane
Kane-o is offline   Reply With Quote
Old 10-03-2007, 09:30 PM   #4137
Would it be possible to use TC4 4 Degree caster blocks part #31017 on my TC5 as a bandaid fix untill my new parts come in (so I can use my car firday night)?
マイクル ユージャック
Old 10-03-2007, 10:32 PM   #4138
bvoltz's Avatar
Trader Rating: 44 (100%+)
Brandon, I know you are the expert on the car... But I added one degree of Anti Dive to the front and this help a lot with the taming down the steering... Just want to see what you think of this setting change... I'm using the setup EA gave me.. If this helps... I'm also running at 40% on the dual rate in the radio....
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-04-2007, 12:38 AM   #4139
Thank you for your help
Yes, I have using a spool on asphalt with 5cell 4.5 Brushless, tried toward & backward battery position, backward is better for tight track and increase rear traction to get more stable, but the problem is when under acceleration to come out the corner the rear traction easy to break loose. Do u have a good solution to solve this problem?
Old 10-04-2007, 06:02 AM   #4140
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
make sure your diff is tight
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
