Old 10-02-2007, 01:35 PM   #4111
Rick Hohwart's Avatar
Originally Posted by thunderbt3 View Post
Are the IIC setups going to be posted up on website? It would be good to see some more carpet/rubber setups
This one is easy. Juho's LRP Masters set-up is what we always use. We could add more, but they would all be the same :-)
Rick Hohwart is offline   Reply With Quote
Old 10-02-2007, 02:57 PM   #4112
Trader Rating: 16 (94%+)
What is everyone doing about keeping the diff's lubed?
After one day of racing/practice, all the lube has been spun out of the diff, leaving the diff balls relatively unprotected. Upon inspection all the diff grease is all over the belt pulley and the center of the chassis.
KSN
kn7671 is offline   Reply With Quote
Old 10-02-2007, 03:33 PM   #4113
mo
mo's Avatar
I am using the Schumacher diff lube for the Mi2/3. It is a bit thicker than the stealth lube and makes the diff last longer.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 10-02-2007, 04:27 PM   #4114
racing_jason's Avatar
so any ideas on when they will post some of the carpet foam set ups?i am in desperate need of some lol
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 10-02-2007, 08:33 PM   #4115
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Rick, so how much rear toe-in were you guys running on your rubber cars? For some reason, when I look at the setup sheet (Juho) it says 3.5 at the top but at the bottom it says 3. What am I missing?
Kraig is offline   Reply With Quote
Old 10-03-2007, 07:19 AM   #4116
It must be a misprint. We used 3 degrees although I did try 3.5 degrees when the traction was lower. Once it increased I went back to 3.
Old 10-03-2007, 08:47 AM   #4117
Shev's Avatar
Is anyone using the Titanium Racing layshaft?? I tried it tonight (putting it in the car) and the front belt is too close to the spur gear. Has anyone else had any issues? Cheers
Fraser Coast RC Car Club/FCRCCC
XRay T4... F104X1... M11X... SMC... FANTOM...
"fast.... but rough!"
http://www.actionrc.com.au
Shev is offline   Reply With Quote
Old 10-03-2007, 10:44 AM   #4118
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Brandon, what was more popular this past weekend...spool or one-way?
Some people went back and forth between spools and one ways. Everyone ended up on the oneway for IIC. The track doesn't have any breaking points. If on a smaller track or somewhere where brakes are needed, use a spool. I personally liked the way the spool felt, but if you tapped the boards it would break the drive blade on occasion causing it to eat the spool up. My car steered just as much with the spool.
Brandon Melton is offline   Reply With Quote
Old 10-03-2007, 02:16 PM   #4119
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Hey Shev,
Give me a holla.
I run the TIR layshaft as you know.
- Leonard.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 10-03-2007, 02:26 PM   #4120
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Can you use Kimbrough or PRS spurs on this car?
Dasupacat1 is offline   Reply With Quote
Old 10-03-2007, 02:30 PM   #4121
Trader Rating: 17 (100%+)
Kimbrough= yes
PRS I don't know as I have not tried it. From the looks of the bolt pattern any gear should fit.
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 10-03-2007, 03:10 PM   #4122
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
As far as making stiffer arms... I am all for it. There must be some reason the companies who are very sucessful on foam tires such as xray and corally have all come out with extra hard arms that the foam tire guys use .. Why would corally and xray waste time , effort and money in designing and testing something that "ISNT NEEDED". I know i am not an engineer, but many many racers who have looked over and checked out my car have all said the same things.. those arms need to be stiffer. The soft arms that come with the FT TC5 is part of why the TC5 is amazing on rubber tires. ( also why xray came out with softer arms for the rubber tire cars )
Dont get me wrong this car is very good but it is just a few $$ Hop Up $$ parts away from being incredible.. Hop Up parts are also a nice way for associated to cash in . Especially when there are tons of people hoping and wishing for them.
wallstreet is offline   Reply With Quote
Old 10-03-2007, 03:34 PM   #4123
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
I use PRS gears on my TC5 and they work just fine.
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 10-03-2007, 03:56 PM   #4124
I can't help but be bothered by the fact that Rick stated that the AE Team racers have been struggling with carpet racing on the TC5. After all, wasn't the TC5 designed to be a carpet car? Anyway, I agree, it doesn't take much R&D to mold/cast new arms, lipo batt trays, aluminum hubs, stiffer carbon steering knuckels, aluminum wheelbase spacers, etc... to take the TC5 platform up a level.
KSN
Old 10-03-2007, 04:36 PM   #4125
corallyman's Avatar
Trader Rating: 98 (100%+)
That isn't what Rick said, the car is good on carpet with rubber tires. It even has a big international race win by Juho. Rick said that the team is having some issues with carpet foam racing caused by setup and driving.
I had a 25 minute conversation with the designer of the car (Bob S.) when the team was in Seattle for the Asfault National's @ SIR, and I know that he would not settle for this car being any less than it can be. Just give the guys a little time to figure out what it might need.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
