Old 09-30-2007, 05:18 PM   #4081
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by STLNLST View Post
would have loved to have had this car at every event I raced last year. This is hands down the best car I have ever driven. It doesn't require the use of other car parts to make it work and I haven't had to really change anything other than my droop and body shell. AE hit this one out of the park and racing is once again fun from week to week. For out door rubber tire there's no need to run anything but Ryan C. set up from the Reedy I can't wait to run this one the rug with rubber tire's and a oneway. My boy Harsh will be purchasing a couple as well. He buys everything in two's. You gotta buy it it when it keeps beating you....
Jav is really going blue also?
You need to bring you pice of art to swr so I can see it!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-30-2007, 07:58 PM   #4082
Do any of you guys have an idea of what would be a good starting point to run for a pinion size for 19-turn? We run a 24 x 48' oval track and the book shows no starting points for motor sizes.
Kevin is offline   Reply With Quote
Old 09-30-2007, 08:57 PM   #4083
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by DirtyDog3375 View Post
Here is my latest layout (to obtain a better balance between left and right -front to rear).
My car is 1410grams ready to race. (legal limit is 1375 grams with personal timing equipment)
It is not totally balanced but is only 13 grams out on the motor side.
I will test the new layout this weekend.
Equipment:
Servo: Futaba 451 Brushless
ESC: LRP TC spec
Rx: Futaba Fasst System
Motor: LRP 3.5t x11
Batts: LRP 4200UP Big Mama
PT: MRT Personal Transponder
I have used some duralium and titanium screws in some parts of the car.
You could get a little more weight, but it all all come from the motor side.. Micro RX and half size servo... but like I said it would come from the side you want to add 13 grams to... Just an idea...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 10-01-2007, 04:56 AM   #4084
BrainTeased's Avatar
Originally Posted by B4james View Post
take a closer look at the nut that goes into the T-nut, as even though it looks like it is in properly it actually goes in a lot deeper. The T- nut has several notches in it so take something that is the size of the nyloc nut and push it further into the t-nut with moderate force and you will have no problems with assembly, I had the same problem and this fixed it.
The mannual is not real clear on this step,
thanks all done now
Originally Posted by kn7671 View Post
Manual shows Bag D. Should be with the plastics for the Arm Mounts.
cheers found them lol i dont look hard enough sometimes, although i was tired..
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-01-2007, 05:18 AM   #4085
Trader Rating: 16 (94%+)
Originally Posted by twistedone View Post
Got a question for someone
Gearing, TC5 on carpet, foam tire, what am I in need of? oh yea
brushless orion 13.5 motor.
You need to gear the motor around a 5.0 FDR (final drive ratio) to start with when using a BL 13.5 motor, then gear up or down from there, checking motor temps after a 5-minute run.
On my TC5, I run a Novak 13.5SS with a 4.72 FDR. The spur/pinion is 104/44 (64-pitch), while motor temps are in the upper 140's after a 5-minute race. Based on what others are doing (4.0 to 4.5 FDR's), my gearing could be a little steeper.'
Just in case you don't know how to calc the FDR, divide your spur gear by your pinion (104 / 44) then multiply by 2 (TC5 internal trans ratio). For Example: 104/44 = 2.36. Next, multiply 2.36 x 2 = 4.72.
KSN
kn7671 is offline   Reply With Quote
Old 10-01-2007, 08:28 AM   #4086
Trader Rating: 139 (97%+)
Send a message via AIM to twistedone
Default TC5 GEAR CHART
Kn thank you very much
LOOK AT THIS GEAR CHART HELPS ME OUT
IF YOU FULL SIZE COPY SEND ME PM WITH EMAIL ADDRESS
twistedone is offline   Reply With Quote
Old 10-01-2007, 10:52 AM   #4087
ooliganRC's Avatar
Send a message via MSN to ooliganRC
or just go to www.gearchart.com like the rest of us do....and print it off ya self
ooliganRC is offline   Reply With Quote
Old 10-01-2007, 11:04 AM   #4088
HarshGuy's Avatar
Originally Posted by Advil View Post
Harsh now believes in the POWER of the FORCE! LMAO!
Yea, I will NEVER doubt the power of the force again
I'm not sure what I'm gonna do, I'll actually probably just sit tight for a while into the carpet season, only have 1 more asphalt race left at SWR on the 20th ....then it's gonna be hit and miss with carpet, I gotta get my diving schedule (I want to get my advanced certification by this time next year) and Jacob's mountain bike race schduled nailed down (I have volunteered to work on their website and be a photographer at the races) then see what/where I can do some carpet racing.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 10-01-2007, 11:26 AM   #4089
HarshGuy's Avatar
That website ROCKS ...I hear the more you use it, the more hot chicks are attracted to you.
Old 10-01-2007, 12:11 PM   #4090
STLNLST's Avatar
Trader Rating: 21 (100%+)
Won't be racing at speedworld anytime soon so you're out of luck. Get your parents to bring you to Stockton or Norcal during the carpet season.
STLNLST is offline   Reply With Quote
Old 10-01-2007, 12:12 PM   #4091
Blisster's Avatar
Originally Posted by Brandon Melton View Post
Make sure to get some extra blades, in a decent size impact the blade can break.
Are these the little plastic do-hickeys that came with the kit? I wasn't 100% sure what they were for so i didn't put 'em on the bones. So do you jsut clip them to the end of the bones so they slide deeper into the outdrive?
WCERacing.com for R/C videos, news and more!
CRC T-Fource
AE TC5
CEN Matrix C-1 FRE
Blisster is offline   Reply With Quote
Old 10-01-2007, 12:21 PM   #4092
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Yes. They prevent wear and tear on the bones and outdrives.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-01-2007, 03:24 PM   #4093
Yeah.... That would be different, then everyone would be blue after the main guys lol
Nice
I dont need to see it that bad, someone races one, just wanted to see your car with all the upgrades and all...... I will start racing at stockton, actually I dont know yet, have to get that all planned
Old 10-01-2007, 03:29 PM   #4094
Trader Rating: 18 (100%+)
Never again will you mock the POWER of the Jedi Mind Hack. LMAO!
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 10-01-2007, 04:23 PM   #4095
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
If you do not use the plastic C shaped blades with the spool, it will not last long at all. The steel bones will eat the aluminum in about 2 battery packs. The blade just snaps on over the pin and goes into the spool. DO NOT run the spool without them.
Brandon Melton is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
