Old 09-23-2007, 08:21 AM   #4036
Midnight's Avatar
Trader Rating: 85 (100%+)
Thanks very much
Midnight is offline   Reply With Quote
Old 09-23-2007, 11:45 AM   #4037
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
The car will work with the stock parts as well. So you don't have to go out and buy that to make the car work.
Kraig is offline   Reply With Quote
Old 09-23-2007, 02:18 PM   #4038
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
kraig are you running the ITF stuff
wallstreet is offline   Reply With Quote
Old 09-23-2007, 02:48 PM   #4039
Send a message via MSN to TurboT
This is very true. I'm running the stock stuff except for a one-way, softer springs and 6-degree front hubs. The car is a rocket and very hooked up, with just enough looseness to be fast around the corners.
I run stock rubber with TakeOff CS22s on all four corners.
Had an awesome practice/race day today and was able to try a few different things. I'm not sure the ITF decks are really necessary to make this car fast. I know that the Corally RDX fast guys ended up using the thicker foam chassis for their hot setups, allowing the suspension to do all the work.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 09-23-2007, 06:23 PM   #4040
Super Moderator
Kraig's Avatar
wallstreet, no I am not.
Old 09-23-2007, 07:59 PM   #4041
wallstreet's Avatar
are you going to in the future ?
Old 09-23-2007, 08:47 PM   #4042
Super Moderator
Kraig's Avatar
Only if you are going to buy them for me.
Honestly, I don't forsee running them in the near future but I wouldn't rule it out. I am going to try some other changes to the car to see if I can get it like I want it. We both know where it is at right now.
Old 09-23-2007, 09:56 PM   #4043
Renuco612's Avatar
Send a message via AIM to Renuco612
Default Wobbling TC5
I get this funny vibration and rattling when I let the car go full throttle and turn left and right at 100% EPA. I tried putting it on a work stand and tried it that way but I still hear it. the only time I don't hear it was when I adjusted the steering down to 30% EPA.
So I took off the steering horn and tried it without the wheels moving but just the servo turning and and now everything sounds good. No rattling and No vibration. Once i attached the servo horn again it did it again.
I checked and theres nothing rubbing on anything or atleast thats what I see. Can someone please help me.
I took off the front wheels and set the Steering EPA at 100% and this time I don't get the wobbling and rattling sound. But once I put the wheels back on I get the wobbling and rattling again. So then I have to set the Steering EPA back at 30% or lower.
Renuco612 is offline   Reply With Quote
Old 09-24-2007, 05:50 AM   #4044
revsinc's Avatar
Hi everbody,
I have just finish putting together the kit, and it seems to me the front belt is to tight ? Has any body drill additional slots on the cam to loosen it up a bit more, or does it free up with a few runs,
I will be given the car its first run tomorrow night ( stock on carpet)
For the life of me could not fiqure out how to get the shocks together with all them foam spacers ?? so i took them out .
cheers
revsinc is offline   Reply With Quote
Old 09-24-2007, 06:55 AM   #4045
Trader Rating: 14 (100%+)
renuco - The rattling is normal. It happens to mine too. You're just pushing the CVD up to its angle limit
revsinc - The belts will loosen up as you run your car, the drivetrain on my car is pretty free. I've only run it for about 10-12 runs
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 09-24-2007, 07:22 AM   #4046
Trader Rating: 16 (94%+)
Originally Posted by revsinc View Post
Hi everbody,
cheers
You should be able to adjust the belt tightness enough to make it looser than the kit instructions, and some runtime will help them get looser too.
As for the shocks, those silly instructions aren't very clear. I think you run one or the other, not both. BUT most carpet setups I've seen are not running any foam on the shocks (no rebound). I've been running mine without the foam and it works good.
KSN
kn7671 is offline   Reply With Quote
Old 09-24-2007, 09:07 AM   #4047
robk's Avatar
Trader Rating: 22 (100%+)
yokomo BD-516L Front Drive Belt (Low Friction Type)=replacement for front belt
Yokomo USA has these if nobody else has them, which seemed to be the case last week.
As far as the shocks, I have HPI bladders in mine, and they work fine. I have no foam right now. The stock bladders are big, and sometimes I think it makes it hard to assemble the shocks. I imagine any bladder like Tamiya, HPI, Yokomo etc. could be used. Just don't use Corally, they are not very good, too soft IMO.
Old 09-24-2007, 09:00 PM   #4048
I had my belts set on the loosest possible setting and the front was still twangy-tight. I ended up manually stretching it out by pulling it and it is now at a tollerable looseness on the loosest settings. The back one was fine, though.
That being said, two other guys I race with had no issues with their belts being tight, and mine is setup exactly like theirs for tightness.
Team Great Hobbies
Team Durango Canada
Exotek
Old 09-27-2007, 08:06 AM   #4049
racing_jason's Avatar
hey i have a quick question. my dad was mounting a mazda speed 6 and to get wheet clearence we had to go way up on the fender? has anyone else had this probblem or are you just retarted?
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 09-27-2007, 08:17 AM   #4050
The body lines for the wheels/fenders are just a guideline. They will have be adjusted for each car differently depending on right height, type or tires used, wheelbase and width.
KSN
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
