Team Associated TC5
#4022
Xray springs will work. I don't know about the bars.
#4024
what will the number two pistons do compared to the threes?
#4025
Anyone looking for spools, here you go: http://shopping.rcmodel.hk/product_i...ducts_id=11507
I order Tamiya parts here all the time. I know Juan Carlos and George P. was looking for one......... Hope this helps.
#4026
the pistons are #'ed 1,2,3, with the #1 having the largest holes, the #3 having the smallest. the kit setup is geared more toward foam use, hence the #3s in the kit. most of the rubber setups i have seen had the #2s in them, and my car felt much better after i changed them.
#4027
also #2 40W oil
#4028
hey thanks i will try next practice. the tc4 ones work correct?
#4029
#4031
I've actually ordered one yesterday from Losipartshouse. Look forward to seeing you at the track...
#4032
Yeah I think Im going to try my luck. I hold lap record so far. I ran my old setup from the last track and it was glued. My packs are a li flat from not using them for 7 months. I was thinking about switching over to the tc5. I cant get parts for the yokomo at the track.
How is the married life going for you?
#4033
I have not built the kit yet but will be doing so very soon. I got the only set-up I could find for rubber tires on carpet from Asc's web site, it is Juho Levanen's from the LRP Touring Car Masters race. I was thinking about building the kit based off of his set-up for a starting point.
#4035
The ITF top deck will let the car flex a bit more than the stock top deck... Its used for rubber tire racing to help the car create more traction..
When used with the ITF chassis it creates a bit more chassis flex... Its very noticable when both parts are used.
