Old 09-19-2007, 08:31 PM   #4006
Send a message via MSN to TurboT
Default UPDATE.
Originally Posted by TurboT View Post
Nope, nothing is backwards and the rear hubs are both the same, at least with the 0 degree ones. Not sure if it changes once you start using optional 1 or 2 degrees though.
As for bending them, nope. I was just setting it up on my bench at home when I noticed the ridiculous difference in toe! I hadn't even got the car on the track yet.
Anyhow, that all being said, I drove it last night with the wonkey shim setup and it's fine. I ordered some parts for it to see if the new ones are any better but I'll drive it as is until I break it.
Another note, this thing has insane steering! I used to run my dual rate at 75 with my RDX and I had to change the setting down to 35 for the TC5! I also had to reduce my rear droop quite a bit. I'm probably only running about 1mm of droop, although I am going to increase it slightly now that I'm a little more used to it. And this is all with a mostly stock setup and RUBBER tires! Kit chassis, kit springs, no sways, and a one-way. I love it!!!
So to give a little update. I managed to break the left side rear hub in practice last week and installed a new hub today for racing. The new hub gave me correct toe settings. So I had a bad hub when I built the kit.
Also raced for the first time tonight since last spring. Qualified 2nd in the B (which is decent since we had 30 cars out and have a factory Xray and Team Full Throttle guy and a bunch of guys who used to be sponsered pretty big) but had some bad luck with back markers that resulted in me popping my transponder out. Time for a personal transponder. Our club finally updated our software, so we can finally use them.
The car is good! I can't wait to tweak it a bit more and see if I can get my laps down to a more competitive time.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 09-19-2007, 08:44 PM   #4007
bvoltz's Avatar
Trader Rating: 44 (100%+)
On the steering issue, try some Anti Dive, page 26 of the manual. I made the change from zero (2A 2A) to 1 degree (1A 2A), what a difference...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 09-20-2007, 02:46 PM   #4008
Can you guys tell me is the layshaft the sames as the input shaft? also where can I find the low friction team bomber belt?
NUCRPTRACER is offline   Reply With Quote
Old 09-20-2007, 05:54 PM   #4009
Good thought on that one. I didn't even think of trying that. I'll be practicing again soon, so I'll have to remember to try it!
Team Great Hobbies
Team Durango Canada
Exotek
Old 09-20-2007, 06:09 PM   #4010
fathead's Avatar
It will slightly increase your on power steering as well
Slavich Design
fathead is offline   Reply With Quote
Old 09-20-2007, 06:30 PM   #4011
dbmartin's Avatar
Car ran great for me, I had another GTB fire and luckily the only thing I lost was the belt melted just a bit. Only took a few minutes to replace and I was back running again.
I had much better success w/ the diffs this time, Last time out I melted the outdrives, this time I ca'd the rings and the rear diff gave no issues. I did have to tap the spool however as I could not keep the nut from backing out.
I tried a lot of different setups, we were running on a gas track.. the site that ran the 04 worlds running 3.5, the car was dialed everytime and kept getting better. If I can keep from thermalling(see pic), I'll be a very happy driver.
FSEARA - Top Photon - Jacks Hobbies
dbmartin is offline   Reply With Quote
Old 09-20-2007, 06:41 PM   #4012
CHRIS CHAVEZ's Avatar
All your missing is the BBQ sauce!! Seriously though, how the heck did that thing catch on fire?
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 09-20-2007, 06:49 PM   #4013
dbmartin's Avatar
I Just got it back from novak as a refurb and I was having thermalling issues with my other gtb. It was the first run on the speedo 2.5 minutes into the race, It lost power and then My car started smoking, then I could see fire from the drivers stand and turn marshalls scrambling. It was quite surreal. Was not overgeared, running 5 cell w/ the 3.5 fdr of 9.0.
As a bonus, I now have tinted windows
Old 09-20-2007, 07:10 PM   #4014
Just gor my TC5. What springs are best for stock rubber?
newman r/c is offline   Reply With Quote
Old 09-20-2007, 07:12 PM   #4015
dbmartin's Avatar
silver and blue
Old 09-20-2007, 07:14 PM   #4016
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
I have tried gold springs as well so those can be an option. It all depends on your track conditions and how you like the car to drive.
Kraig is offline   Reply With Quote
Old 09-20-2007, 07:37 PM   #4017
gixxerman's Avatar
I just bought a tc-5 for this years winter season. This will be my first dealing with Touring Cars, although I ran 1/10 pan car, and 1/12 scale last winter! We will be running a 13.5 li-po combination on rubber tires! Anyone have any advice and set-up tips for rubber tires!
gixxerman is offline   Reply With Quote
Old 09-21-2007, 03:43 AM   #4018
That's good, because I find it is lacking in that department a wee bit. I was also thinking of going to the 6 degree front hubs but I'm going to try one thing at a time.
Team Great Hobbies
Team Durango Canada
Exotek
Old 09-21-2007, 04:41 AM   #4019
Super Moderator
Kraig's Avatar
Turbo, what kind of surface are you running on?
Gixxerman, same question...rubber tires on what surface?
Old 09-21-2007, 07:32 AM   #4020
Midnight's Avatar
Trader Rating: 85 (100%+)
Im buying a TC5 from bvolts and I was wondering if xray springs will work on the tc5. Im selling my yokomo and didnt want to sell the springs if they would work on my new car. Also will the sway bars off the yokomo BD work on the tc5.
Midnight is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
